Hello everyone!
Please, I need suggested to my problem!
I have a communication radio model KENWOOD TR-7950. The LCD burned! The radio have a LCD driver to receive the serial message from microcontroller of radio, process the code and print in the LCD.
I trying get this serial message and decode with arduino and than plot in the OLED display, for example.
I have all information I need to do that from a LCD driver datasheet. I have a clock signal, serial signal and I have a "load" signal indicating when the message finish.
I'm using external interrupt to read the message.
I connect the CLOCK SIGNAL in the PORT 0 (2 arduino board) and the LOAD SIGNAL in the PORT 1 (3 arduino board). The SERIAL signal I put in the digital pin as input.
I'm configure external interrupt for CLOCK signal in PORT 0 in rising mode, because I need read the SERIAL data in rising of clock.
I also configured external interrupt for LOAD signal in PORT 1 in rising mode, because when have HIGH level in this signal, just finish the message.
When have the interruption in CLOCK signal I'm read the SERIAL digital port. When have the interrupt in LOAD signal, I'm process all the data receive to try work and plot in the LCD.
The problem is:
sometimes the digital read of serial signal in the clock interruption is wrong. I have a wrong read and plot random number in the display. When I'm compare with oscilloscope I can confirm this wrong read
The signal of CLOCK is 32 bits in four times of 8 bits. For each 8 bits I have the SERIAL signal.
The time between each rising edge is approximately 100kHz
For example: in this case, the data is 10100010. I can receive wrong like 10000010.. A bit wrong...
The code is very simple...
#define CLOCK 2 // CLOCK IN I/O 2
#define SERIAL 4 // SERIAL IN I/O 4
#define LOAD 3 // LOAD IN I/O 3
volatile int SerialData[32];
volatile int i = 0;
ISR (INT0_vect) // CLOCK INTERRUPT
SerialData[i] = digitalRead(SERIAL);
i++;
} //end ISR
ISR (INT1_vect){ // LOAD INTERRUPT
for(int z=0; z<32; z++){
Serial.print(SerialData[z]); // PLOT BITS TO DEBUG IN SERIAL MONITOR - 32 BITS,
Serial.print('\n');
Serial.println(i); // PLOT NUMBER OF INTERACTION TO CHECK IF IS ACCORDING TO 32 BITS RECEIVE AND READ
Serial.begin(115200); // SERIAL IN 11520
pinMode(CLOCK, INPUT); // CLOCK AS INPUT - HAVE PULLDOWN IN HARDWARE
pinMode(SERIAL, INPUT); // SERIAL AS INPUT - HAVE PULLUP IN HARDWARE
pinMode(LOAD, INPUT); // LOAD AS INPUT - HAVE PULLUP IN HARDWARE
EICRA |= (1 << ISC01) | (1 << ISC00); //EXTERNAL INTERRUPT PORT 0 IN RISING
EICRA |= (1 << ISC10) | (1 << ISC11); //EXTERNAL INTERRUPT PORT 1 IN RISING
EIMSK |= (1 << INT0);
EIMSK |= (1 << INT1);
sei(); //TURN ON THE INTERRUPTS
//interrupts ();
Check the LOAD signal in the scope. When I have the rising in LOAD input. The message finish.
How can I improove the signal read to can not have a wrong bit?
The time of instructions of Arduino UNO is too low?
Thanks for ALL SUGGESTION
