Hi all,
I'm very new to the Arduino and have been trying to make a trigger box that will accept and/or generate a reference TTL pulse at a given frequency and produce two synchronous pulses with different frequencies and duty cycles. An example would be:
Reference/Input TTL pulse frequency: 30 Hz
Output 1: 15 Hz (input / 2)
Output 2: 3 Hz (input / 10)
I do not have extremely rigid values in mind for the input or output frequencies but I'd like Output 1 to trigger about 10-15 times a second and output 2 to fire about 3 or 4 times a second. The length of the trigger pulses needs to be relatively short ~5 ms. For the TTL pulses to act as triggers I believe I'd need them to have a peak voltage of 3-5V. Also, ideally I want to be able to change all of these values easily in the code, if need be i.e. divide by 5 instead of 10, divide by 4 instead of 2 etc.
I'm really not sure where to start with the code or if using a full-blown Arduino is really the way to go. I have tried to read into using a counter/divider such as the one below, instead of an Arduino:
http://docs-europe.electrocomponents.com/webdocs/0fde/0900766b80fde40c.pdf
however, I can't get my head around how to program these for different output frequencies and whether or not this chip could do whatI need to do. Also, I feel like changing the frequency divider in Arduino code would be a lot easier than changing the wiring of the chip, so the Arduino would probably give me more flexibility. As I said, my electronics knowledge is very poor. Hence why I'm trying to learn through small Arduino projects.
In summary, if anyone has any ideas of the best way to output two synchronous TTL pulses, both with frequencies a function of an input/reference pulse, then I'd be really grateful. If anyone could explain how I could achieve the same output pulses using a simple counter/divider chip, then please let me know if you think that using an Arduino is overkill.
Many thanks!
