Synchronus Motor via PWM and Interrupt
Hello!
I am currently trying to operate a 3~ 24V Synchronus motor via PWM. For that, I have a print with 3 half - bridges with the IR2104 controller on it, what works very well with the motor if you send a 3 phase 0-5V PWM.
To test the motor, I've written the following program:
int n = 0;
int x = 0;
int r[16] = {64,88,109,123,128,123,109,88,64,40,19,5,0,5,19,40};
int s[16] = {119,103,81,56,32,13,2,1,9,25,47,72,96,115,126,127};
int t[16] = {9,1,2,13,32,56,81,103,119,127,126,115,96,72,47,25};    //These 3 arrays contain the previously calculated 3~ PWM, from 0 to 128.
int rpin = 10;
int spin = 11;
int tpin = 12;
  pinMode(rpin, OUTPUT);
  pinMode(spin, OUTPUT);
  pinMode(tpin, OUTPUT);
if(x>=25)       //Changing that variable makes the frequency (and motor rpm) go up or down.
  x=0;
  if(n>=16) n=0;
  analogWrite(rpin,r[n]);
  analogWrite(spin,s[n]);
  analogWrite(tpin,t[n]);
  n=n+1;
  delay(1);
  x++;
In principle that works well, but because that program works with delay I can't combine it with other programs. So I wanted to write a program which uses a timer interrupt, so I downloaded the library "Timer1" and wrote a new one:
#include "TimerOne.h"
int ledpin=13;
int alle_x_millisekunden=100;
int x=0;
int y=0;
int rpin = 10;
int spin = 11;
int tpin = 12;
int periode=5;
void setup()   {
               Timer1.initialize(alle_x_millisekunden*1000);
               Timer1.attachInterrupt(motor);
void motor() {
               if(y>=periode)
                  y=0;
                  if(x>=16) x=0;
                  analogWrite(rpin, r[x]);
                  analogWrite(spin, s[x]);
                  analogWrite(tpin, t[x]);
                  x++;
               y++;
void loop()    {
                    // Main program
Unfortunately, it dosen't work that way and the motor is frozen in one position. However, if I set one output pin to 13 and wath the LED, it looks like a sinus :?
Can anyone help me? (Please excuse my not so good English)
Greets, Se11001
