Hello,
I'm working on a project - building several sequencers - and I'm having some trouble keeping the Arduinos synced.
I read some topics about Arduino clock syncing, but I'm not sure if those solutions serve my purpose.
I want to upload the same code to every Arduino and later decide - using an on/ off switch - which one will be the master and which one(s) will be the slave(s).
The slaves are initialized first and then they wait - while loop - until the "syncPin" gets HIGH.
The first sync stage works great but after some time, after entering the loop function, everything starts to get ou of sync.
At the moment I'm using one Arduino Uno and one Arduino Mega, would be enough to use two similar boards, like two Mega's?
//analog pin - will read pot "tempo"
int const analogInMaster=0;
//analog pin - will receive master voltage "tempo"
int const analogInSlave=1;
int pinTempo;
int tempo;
//review pins
int pinTestMaster;
int const pinSync=3;
bool IamMaster;
bool doneSync=0;
int const pinLed=5;
//debug
//master
pinTestMaster=HIGH;
//debug
//slave
//pinTestMaster=LOW;
pinMode(pinLed,OUTPUT);
//pinMode(pinTestMaster,INPUT);
if(pinTestMaster==HIGH){
//Serial.println("teste");
IamMaster=1;
else if(pinTestMaster==LOW){
IamMaster=0;
if(IamMaster==1){
pinTempo=analogInMaster;
pinMode(pinSync,OUTPUT);
digitalWrite(pinSync,HIGH);
delay(100);
digitalWrite(pinSync,LOW);
else if(IamMaster==0){
pinTempo=analogInSlave;
pinMode(pinSync,INPUT);
while(doneSync==0){
//Serial.println(digitalRead(pinSync));
if(digitalRead(pinSync)==HIGH){
doneSync=1;
delay(10);
delay(100);
//testing sync
digitalWrite(pinLed,HIGH);
digitalWrite(pinLed,LOW);
//Serial.println(analogRead(pinTempo));
tempo=map(analogRead(pinTempo), 0 , 1023, 60, 800);
tempo=60000/tempo;
delay(50);
delay(tempo-50);
Thank you in advance.
Kind regards,
Marco
