Syncing to cloud AND using deep sleep
Posting the solution here for others as I've been pulling my hair out (OK, I didn't have that much beforehand) as I have been having trouble with an ESP8266 updating variable data back to the ArdunioCloud AND using deepSleep.
I want to use a battery powered ESP to read a temp sensor and upload the value to ArduinoCloud then go into deep sleep for 30 mins to conserve battery. After 30 mins have past then wakeup and repeat. Everything is OK except that the values in AudinoCloud were not updating. I had read the issues that others were having as I was experiencing the same issues myself, eg -
  1. ESP wakes up, connected to cloud, reads sensor value from local device but updated data doesn't appear in Cloud.
  2. OR, the Cloud doesn't show that device ever connected.
  3. OR, the Cloud does show that device connected, but variable value doesn't update.
  4. If I remove the deepsleep function from my code with no other changes then everything works fine and the Cloud updates. Uncomment the deepSleep function and the issue returns. Doesn't matter if the sleep is for 60 seconds or 10 minutes.
  5. etc, etc. etc
The final solution is actually in the documentation (OK, like most others I didn't RTFM). I found this issue as the Cloud data was remaining at the same value even though it was showing that the ESP had updated it (testing via an OnChange function). The initial clue is here - Cloud Variables | Arduino Documentation under the heading Variable Lifecycle. I was testing and waiting for the ArdinoCloud.Connected() to return true, but as it turned out that just means that the ESP is connected but doesn't actually yet upload/sync any data to the Cloud. If you read the text under 'Connected' Lifecycle you can see why that was the case, the local variable was being overwritten by the value in the cloud which was then getting synced hence it never changed. The 'Synchronized' state is the one that you want, not 'Connected'.
To make it all work and not have to worry about doing loops, or testing for Cloud connectivity, or testing updates using OnChange functions, etc, etc you need to read this - Event & Callbacks | Arduino Documentation in particular look at the Full Example. This sets up 3 call back functions which will call doThisOnConnect(), doThisOnSync() or doThisOnDisconnect(). Your main loop only needs to have ArduinoCloud.update(). The code that I want to use goes into the doThisOnSync() function therefore only after the ESP wakes up, connects to wifi, connects to the ArduinoCloud and enters a synced state is the doThisOnSync() function called and hence my code runs. My code then reads the temp from the local sensor, sets the applicable variable (ie the one that's synced with the ArduinoCloud), calls ArduinoCloud.update() once to make sure it's updated then calls the deepSleep function. It then wakes 30 mins later and the process repeats and the ArdunioCloud variable updates successfully each time.
Obviously since using the deepSleep function the doThisOnDisconnect() function is never used.
Hope this helps someone else.
Amazing what you discover when the documentation is read. Congrats, we are probably all guilty of that at least some of the time. It sounds like it makes perfect sense now.
