Syntax error - Unqualified id before "break"
I'm sure it's a simple syntax error but I'm too inexperienced to find it any help is greatly appreciated here is my code:
#include <IRremote.h>      //must copy IRremote library to arduino libraries
#include <Servo.h>
#define plus 0xFFA25D   //clockwise rotation button, set to power button
#define minus 0xFFE21D  //counter clockwise rotation button, set to func/stop button
#define code1 0xFFA25D        //code received from first led button
#define code2 0xFFE21D        //code received from second led button
int RECV_PIN = 11;       //IR receiver pin
int led1 = 2;            //grn
int led2 = 4;   //red
int itsONled[] = {0,0,0,0}; //turns off lights at start
Servo servo;
int val;                //rotation angle
bool cwRotation, ccwRotation;  //the states of rotation
IRrecv irrecv(RECV_PIN);
decode_results results;
  irrecv.enableIRIn(); // Start the receiver
  servo.attach(9);     //servo pin
  pinMode(led1, OUTPUT); //sets the pin defined as led1 as an output
  pinMode(led2, OUTPUT); // sets the pin defined as led2 as an output
  if (irrecv.decode(&results))
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
    if (results.value == plus){
      cwRotation = !cwRotation;      //toggle the rotation value
      ccwRotation = false;         //no rotation in this direction
    if (results.value == minus)
      ccwRotation = !ccwRotation;   //toggle the rotation value
  if (cwRotation && (val != 175))  {
    val++;                         //for colockwise button
  if (ccwRotation && (val != 0))  {
    val--;                         //for counter colockwise button
  servo.write(val);
  delay(20);          //General speed
break;  ERROR OCCURS ON THIS LINE
case code1
if (irrecv.decode(&results)) {
unsigned int value = results.value;
switch(value) {
case code1:
if(itsONled[1] == 1) { // if first led is on then
digitalWrite(led1, LOW); // turn it off when button is pressed
itsONled[1] = 0; // and set its state as off
} else { // else if first led is off
digitalWrite(led1, HIGH);
// turn it on when the button is pressed
itsONled[1] = 1; // and set its state as on
case code2:
if(itsONled[2] == 1) {
digitalWrite(led2, LOW);
itsONled[2] = 0;
digitalWrite(led2, HIGH);
itsONled[2] = 1;
Where is the switch or statement you are breaking out from?
Indent the code, it will be easier to see what is going on
I'm really not fully sure how the break works, I'm trying to do a completely separate action unrelated to my first loop
The 'break;' statement only works inside a 'while', 'do/while', 'for' or 'switch/case' statement.
Your 'case' statements will only work inside a 'switch' statement.
