Syntax for inline assembly code
Hi i'm using an inline assembly routine, trying to write a byte to EEPROM, but i keep getting an error that says "undefined reference to `EEDR'"
#include <EEPROM.h>
int i;
byte countlow, counthigh, on, off;
  // inc duty cycle every 4096 cycles
  on = 10;
  off = 90;
  counthigh = 16;
  countlow = 0;
  EEAR = 0x01;				// EEPROM addres reg
  for (i = 0; i < 400000; i++) {
    digitalWrite(pwm, HIGH);
    delayMicroseconds(on);
    asm volatile (
      "dec %0 \n\t"    			// countlow -= 1
      "brne 1f \n\t"			// skip 1 if countlow != 0
      "dec %1 \n\t"		    	// counthigh -= 1
      "1: \n\t"
      : "=r" (countlow), "=r" (counthigh)
    digitalWrite(pwm, LOW);
    delayMicroseconds(off);
    asm volatile (
      "lds r24, (counthigh) \n\t"
      "brne 2f \n\t" 			// skip 7 if counthigh != 0
      "inc %1 \n\t"			    // on += 1
      "dec %0 \n\t"			    // off -= 1 (PWM duty cycle += 1)
      "ldi r24, 0x10 \n\t"
      "sts (counthigh), r24 \n\t"	// count = 4096
      "out EEDR, %1 \n\t"		// EEPROM data reg     <---undefined reference to `EEDR'
//      "sbi EECR, "EEMPE"
//      "sbi EECR, EEPE"
      "2: \n\t"
      : "=r" (off), "=r" (on)
      : "r24"
what microcontroller are you using?
Atmega16u2
Obvious:
first of all: you write "inline assembly code" not "inline" functions (which is a different topic).
Imagine this:
you enclose assembly code inside C-code. You use MCU instructions. All fine, the compiler knows the instructions.
But it does not know how to deal with "EEDR"! Even you know it is a symbolic name for a registers - the assembler (called from compiler) does not know any register.
So, for your assembly code (like an *.S file), you had to define what "EEDR" is, e.g. an address value. EEDR is nothing what be known by any compiler (actually here the assembler): it is a name for something where you do not resolve what the name is (a register address here).
Simple way to solve: provide instead of EEDR the real physical address of this register, e.g. 0x0123ABCD.
If you do not like it: you need an include file, even for this assembly code, which defines what EEDR is.
Bingo now it's compiling. i thought the assembler knew that. THANX
Sure, BTW: it is not the compiler, it is the assembler who has to know what EEDR means (called from compiler in order to deal with your MCU instructions).
the way that this is usually done is to pass the symbolic value to the asm code from the C code (where it is "known.")
Something like:
    asm volatile (
      "out %[eedr], %1 \n\t"
      "2: \n\t"
      : "=r" (off), "=r" (on), [port]
      : [eedr] "I" (_SFR_IO_ADDR(EEDR)
      : "r24"
See: https://www.eit.lth.se/fileadmin/eit/courses/edi021/avr-libc-user-manual/inline_asm.html
ok didn't know i could do that. but i don't get what is the meaning of the [port] part. The compiler doesn't like it.
oops. Copy/paste error on my part. Should've been (I think):
"2: \n\t"
      : "r24"
