Syntax for "Structure"
Corrosion due to absence from programming has hit me. A flooding of the celler sent all my books to the dumpster.
What is the syntax for a structure containing variables of the type int1, int2, int3?
Arduino Struct
Thanks a lot!
I copied the example and this compiles well.
Code:
struct motor_struct
  byte motor_I_O_pin;
  byte motor_id;
  byte motor_dir;
How do I create an array of 3 such structures?
This doesn't compile:
int motor_array[3] motor_struct
How do I acces the array?
Thanks. Managed to declare the struct. Next wish is to create an array of 3 such structss. It doesn't work.
Code is:
int motor_array[3] int motor_struct;
Error code is:
Combined_20190722a:69: error: expected initializer before 'int'
exit status 1
motor_struct motor_array[3];
Accessing the array
  motor_array[0].motor_I_O_pin;
  motor_array[1].motor_I_O_pin;
  motor_array[2].motor_I_O_pin;
When I checked, Mr. Google wasn't generating out-of-office replies. Any C++ site has all the details on declaring structs, arrays of structs, and how and why to use structs.
A struct to hold 3 ints is rather useless. An array would serve the same purpose.
A struct is useful when the types of data to relate are not all the same type.
@Romonaga Lots of thanks! That pulled plug!
A sample of the large code that compiles fault free:
struct motor_struct
  byte sensor_pin;
  byte motor_fwd;
  byte motor_bwd;
motor_struct motor_stop_array[4];//Due to motors defined as  1,2,4
  bool status;
  motor_stop_array[motorX - 1].sensor_pin = x_limit_pin;
  motor_stop_array[motorY - 1].sensor_pin = y_limit_pin;
  motor_stop_array[motorZ - 1].sensor_pin = z_limit_pin;
  reset_end_stop(motorX);
  reset_end_stop(motorY);
  reset_end_stop(motorZ);
  digitalWrite( 2, LOW);// digital x-step
  digitalWrite( 3, LOW);
  digitalWrite( 4, LOW);
  digitalWrite( 5, HIGH);// digital x-dir
  digitalWrite( 6, HIGH);
  digitalWrite( 7, HIGH);
  digitalWrite( 8, HIGH);//disable motorpower
  digitalWrite(CNC_stop_ack, HIGH);//Take down acknowledge
  pinMode(2, OUTPUT); //x-step
  pinMode(3, OUTPUT); //y-step
  pinMode(4, OUTPUT); //z-step
  pinMode(5, OUTPUT); //x-dir
  pinMode(6, OUTPUT); //y-dir
  pinMode(7, OUTPUT); //z-dir
  pinMode(8, OUTPUT); //z-dir
  pinMode(13, OUTPUT);
  pinMode(CNC_stop_req, INPUT_PULLUP);//A3
  pinMode(CNC_stop_ack, OUTPUT);//D12
  pinMode(x_limit_pin, INPUT_PULLUP);//D9
  pinMode(y_limit_pin, INPUT_PULLUP);//D10
  pinMode(z_limit_pin, INPUT_PULLUP);//D11
  status = mylcd.begin(LCD_COLS, LCD_ROWS);
  if (status) // non zero status means it was unsuccesful
    status = -status; // convert negative status value to positive number
    // begin() failed so blink error code using the onboard LED if possible
    hd44780::fatalError(status); // does not return
  mylcd.clear();
  // Print start message to the LCD
  mylcd.print("Started ");
void reset_end_stop(int motor)
  motor_stop_array[motor - 1].motor_fwd = false;
  motor_stop_array[motor - 1].motor_bwd = false;
boolean no_stop (int motor, int dir)
  if ( dir == fwd)
    return (motor_stop_array[motor - 1].motor_fwd);
    return (motor_stop_array[motor - 1].motor_bwd);
  return (true);//This sould not happend
void motor_end_check (int motor, int dir)
  bool tmp;
  tmp = !digitalRead(motor_stop_array[motor - 1].sensor_pin);
  if ( tmp)// Sensor is activated, set stop flag
    if ( dir == fwd)
      motor_stop_array[motor - 1].motor_fwd = tmp;
    else//bwd
      motor_stop_array[motor - 1].motor_bwd = tmp;
@PaulS
Of cource. Why wouldn't Google point out something? It just didn't hit me, search for C-language syntax there. On the other hand, I dislike clicking on unknown links in Google as well as several members dislike downloading
attached files in the topics.
Check the code extract. I'm home due to the help above.
