Syntax help ....
Can someone please explain (teach) the following syntax…
  PORTD |= (1 << SR_OE);                      // temporarily disable the SR outputs
{{ some code here to update the shift register data }}
  PORTD |=  (1 << SR_LE);                     // set latch pin LOW
  PORTD &= ~(1 << SR_LE);                     // set latch pin HIGH - SR outputs now have new data
  PORTD &= ~(1 << SR_OE);                     // re-enable the SR outputs
I’m confused with the |, &. and ~
i have to look it up myself when i need it but there is a great lesson on stack overflow which explains it all extensively, check the first answer.
short:
// Setting a bit
number |= 1UL << n;
// Clearing a bit
number &= ~(1UL << n);
// Toggling a bit
number ^= 1UL << n;
// Checking a bit
bit = (number >> n) & 1U;
You can refer to the language reference:
&= (compound bitwise and)
~ (bitwise not)
