Syntax or code error(s)?
Hard time trying to solve this, help please.Im posting my code with comments on my problems, which should make them easier to understand. Attached schematic of my setup.
I need to control my motor soon PowerON it goes to Compressor Limit switch and stops
Stay here for a certain time, after which it moves to another switch and stops.
After another interval, the cycle repeats.
int Motor = 0;
int CompressorHome = 1;            //  Compressor Contacts
int HeaterHome = 2;
int TimerSwitch = 3;
int TimerLED = 4;
int CompressorState;
int HeaterState;
  pinMode (0, OUTPUT);
  pinMode (1, INPUT);
  pinMode (2, INPUT);
  pinMode (3, INPUT);
  pinMode (4, OUTPUT);
  CompressorState = digitalRead ( CompressorHome );
  if ( CompressorState == HIGH )
    digitalWrite(Motor, HIGH);      //  go to CompressorHome and stop Motor
  delay (10000);  //  so far, so good, motor starts, stops at CompressorHome
  /*  first try
    if ( HeaterState = LOW )
    digitalWrite(Motor, HIGH);      //  go to HeaterHome and stop Motor
    delay (10000);
    //  motor stops at Compressor, doesnt restart
  /*  next try
  HeaterState = digitalRead ( HeaterHome );
  delay (10000);
  //  motor doesnt restart, Im lost
//  now I tried with this, manually moved the shaft off home position
//reapplied power; 10s later LED coes ON, another 10s motor moves to home.
// LED remains ON, motor doesnt move.
digitalWrite ( TimerLED,HIGH);
delay (10000);
// LED goes ON, shouldnt motor start for 1s?
digitalWrite (Motor, HIGH);
delay (1000);
/*  first try
Code error
You should avoid using pins 0 and 1.
You initialize your variables to label pins, you should use them for pinMode so you don't confuse yourself when you change the wiring. So-
pinMode(Motor, OUTPUT);
You check HeaterState before it is ever given a value. In the beginning when you initialize
int HeaterState;
you can just start it off with LOW
int HeaterState = 0;
See reply #1
AWOL:
See reply #1
noticed that immediately
INTP:
I should have said that code is for a tiny45. I know these are Rx and Tx ona 328.
Now that you point that out, question:
if I program a 328 using these pins as INPUTs or OUTPUTs, can I reprogram the chip?
I usually do as you suggest
int HeaterState;
Delta_G:
That HeaterState variable is global. So it's automatically initialized to 0 == LOW
Wont forget; now if the pin state changes, would the variable also? or do I have to with a statement?
THANKs to ALL; after tryinf a few changes I got it running though I have a few doubts. Im posting my new code with appropiate comments.
int Motor = 13;
int CompressorHome = 12;            //  Compressor Contacts
int HeaterHome = 11;                //  Heater Contacts
int TimerLED = 10;                  // indicates Timer code is running
int TimerSwitch = 9;                //  selects  Timer code
  pinMode (Motor, OUTPUT);
  pinMode (CompressorHome, INPUT);
  pinMode (HeaterHome, INPUT);
  pinMode (TimerSwitch, INPUT);
  pinMode (TimerLED, INPUT);
void advance()  //  Motor spins too fast at 5vdc,
//  so I use pulses, for better control
  digitalWrite(13, HIGH);
  delay(25);
  digitalWrite(13, LOW);
  advance();
  if (digitalRead (CompressorHome) == LOW)
    digitalWrite (Motor, LOW);   //  stops at CompressorHome
    delay (10000); //  waits 20s
    digitalWrite (Motor, HIGH); //  heads for HeaterHome
    delay (1000); //   without this delay, motor starts but immediately goes OFF
    //  OK, motor starts, Arduino checks next if "loop?", HeaterHome is still HIGH
    //  shouldnt it loop and execute "advance();"?
digitalWrite(13, HIGH); You have given pin 13 a nice name. Why don't you use it?
HeaterHome is still HIGHYour code never checks the state of HeaterHome
    delay (10000); //  waits 20sWhy confuse yourself, and us, by including comments that don't match the code ?
Put the motor on a PWM capable pin and use analogWrite() to control the speed by outputting a PWM signal.
