Syntax question for: SPI.transfer(buffer, size)
I got a shift register working. WOO HOO. No I am trying to daisy chain.
Three 74HC165 Parallel-In-Serial-Out (PISO) shift registers are Daisy chained.
I want to transfer 24 bytes at a time.
The Arduino reference shows syntax:
But no example is given.
My attempt at the syntax is:
SPI.transfer(optionSwitch, 16);
Which gets this syntax error:
/home/wolfv/Documents/Arduino/demo/PISO/PISO.ino: In function 'void loop()':
/home/wolfv/Documents/Arduino/demo/PISO/PISO.ino:27:32: error: invalid conversion from 'uint16_t {aka short unsigned int}' to 'void*' [-fpermissive]
SPI.transfer(optionSwitch, 16); //
In file included from /home/wolfv/Documents/Arduino/demo/PISO/PISO.ino:7:0:
/opt/arduino-1.6.7/hardware/teensy/avr/libraries/SPI/SPI.h:787:21: error:   initializing argument 1 of 'static void SPIClass::transfer(void*, size_t)' [-fpermissive]
inline static void transfer(void *buf, size_t count) {
The following sketch is modified from Nick Gammon’s excellent tutorial on Gammon Forum : Electronics : Microprocessors : Using a 74HC165 input shift register
The sketch is for two shift registers, which will be expanded to three when I get another shift register:
#include <SPI.h>
const uint8_t LATCH = 9;
void setup ()
  SPI.begin ();
  Serial.begin (115200);
  Serial.println ("Begin switch test.");
  pinMode (LATCH, OUTPUT);
  digitalWrite (LATCH, HIGH);
uint16_t  optionSwitch;
uint16_t  oldOptionSwitch;
void loop ()
  digitalWrite (LATCH, LOW);
  SPI.transfer(optionSwitch, 16); //error: invalid conversion from 'uint16_t {aka short unsigned int}' to 'void*' [-fpermissive]
  uint16_t mask = 1;
  for (uint8_t i = 0; i < 16; i++)
    if ((optionSwitch & mask) != (oldOptionSwitch & mask))
      Serial.print ("Switch ");
      Serial.print (i);
      Serial.print (" ");
      Serial.print ((optionSwitch & mask) ? "closed" : "opened");
      Serial.print (", optionSwitch=");
      Serial.println (optionSwitch, BIN);
    mask <<= 1;
  oldOptionSwitch = optionSwitch;
  delay (10);   // debounce
What is the correct syntax for SPI.transfer(buffer, size)?
Thank you.
The function takes a pointer to the first byte and a number of bytes. You can send your unsigned int with:
 SPI.transfer(&optionSwitch, 2);
The '&' operator is generally read as 'address of'. It returns the address of a variable rather than the value it contains.
Thanks johnwasser. That worked :) .
May I chime in here, because I have the exact same question? I'm not understanding from the exchange above.
The documentation in the SPI reference page says that in SPI.transfer(buffer, size), buffer is an array. In the above it appears that the required data type for the buffer is an integer. Can you guys explain this? I get the part about the argument being a pointer.
Also, what are the limitations on size? I have 32 bits of data to read. Can I set size to 32 once the data type question is answered?
Hi Philblaze,
This should work:
#include <SPI.h>
uint32_t buffer;  //32 bits of data
uint8 size = 4;   //number of bytes
SPI.transfer(&buffer, size);
In this case, “array” means a sequence of bits (not a C array like buffer = {0,1, … ,31} ).
Philblaze: The documentation in the SPI reference page says that in SPI.transfer(buffer, size), buffer is an array. In the above it appears that the required data type for the buffer is an integer. Can you guys explain this?
The actual argument is "void *" which basically mean "the address of some byte in memory". If you are using a simple variable you prepend the '&' operator to get the address of the variable. If you are passing an array or a pointer you just use the name. The "rvalue" of an array name (the value when it is on the right side of an assignment operator) is the address of the first byte of the array. The "rvalue" of a pointer is the contents of the pointer which is the address of the byte to which the pointer points.
Philblaze: Also, what are the limitations on size? I have 32 bits of data to read. Can I set size to 32 once the data type question is answered?
32 bits would be 4 bytes so set the size to 4. You can't use the array-form for reading, only for writing. The size is an unsigned int so you are limited to 65535 bytes. Of course you are also limited by available SRAM. Doesn't look like they support data in FLASH so to do that you'd need to write your own loop.
Thanks so much. It's still not working correctly, but I'm trying not to ask a whole bunch of noob questions. I've been working in Labview for the last 15 years and haven't touched text based programming much since the 6502 in assembly.
The important thing I've gleaned from this is that the array form cant be used for reads which is all I want to do. I don't need to send data.
It's more important to me that I understand how this all works rather than just finding some code that works.
It can work for arrays too.
A tutorial on C arrays and pointers would explain how.
#include <SPI.h>
uint32_t buffer[ELEMENT_COUNT];  //32 bits of data per element
int i;        //buffer index
SPI.transfer(&buffer[i], size);
Or did you want one bit per array element? You can convert a 32 bit buffer to an array of bools using:
  • for loop
  • bitwise operator
  • shift operator <<
SPI.transfer(buffer, N) transfers N 8bit bytes from the buffer to the SPI interface. It does NOT set the size of each SPI data elements to N bytes (or bits); the AVR SPI peripheral only supports 8bit transfers. Because of the way that SPI works, transferring 2 8-bit bytes MIGHT be equivalent to sending a 16bit transaction (I'm not sure whether that works with cascaded 74hc595-like chips.)
Philblaze: The important thing I've gleaned from this is that the array form cant be used for reads which is all I want to do.
Think of the SPI interface as a shift register. When you pull the SlaveSelect line low the slave's shift register is connected to the master's shift register. On each clock the master presents a bit to the slave via MOSI (Master Out/Slave In) line and the slave presents a bit to the master via MISO (Master In/Slave Out). After eight clocks the transfer is complete and the master and slave have exchanged one byte of information. If you are only sending you just ignore the data you received. If you are only receiving you load the register with data that the slave will ignore, typically zero.
I have the following code, just for testing and i know variables are declared in the wrong place etc.
for the first transfer I want it to send 32 zeros to the SPI bus, and I thought I would output to serial to see what is being done.
However all i see in the serial monitor screen is a “y” with a few dots above it.
sizeof(Start) comes back as 4, which seems correct.
can any one point out where my issues might be as I am not seeing what is expected.
I want to be able to pass a 32bit value to the SPI bus in hex format.
#include <SPI.h>
  SPI.begin();
  uint32_t Start = 0x00000000;
  SPI.transfer(&Start, sizeof(Start));
  int num = sizeof(Start);
  Serial.print(num);
  //SPI.transfer(&LED, sizeof(LED));
  uint32_t LED = 0xffffffff;
  uint32_t LEDoff = 0xe0000000;
  SPI.transfer(&LED, 4);
  SPI.transfer(&LEDoff, 4);
  Serial.write(LED);
  Serial.write(LEDoff);
all i see in the serial monitor screen is a "y" with a few dots above it.
I'm pretty sure that's what a 0 looks like when you try to display/write it (which is what serial.write() will do) instead of converting it to a number. If you want to see the value, use Serial.print()
Ahh good to know i will try that :) thank you
OK so I have this code now
LED = (0x00000000);
  Serial.print(LED);
  Serial.print("\n");
  LED = (0xEF000000);
  Serial.print(LED);
  Serial.print("\n");
  Serial.print(LED);
  Serial.print("\n");
  Serial.print(LED);
  Serial.print("\n");
and the serial out put is
0 4009754624 4294967295 4294967295
So taking this a step at a time
  1. the "0" is correct it = 0x00000000
  2. the "4009754624" is also correct it = 0xef000000
  3. 4294967295 is not correct it = 0xffffffff
So why is the value of LED changing between the SPI.tranfers? What am i missing in the code? any thoughts welcome.
Oh I get it now, when using buffer it overwrites the buffer with the return data.
Just been reading up on it :)
westfw: SPI.transfer(buffer, N) transfers N 8bit bytes from the buffer to the SPI interface. It does NOT set the size of each SPI data elements to N bytes (or bits); the AVR SPI peripheral only supports 8bit transfers. Because of the way that SPI works, transferring 2 8-bit bytes MIGHT be equivalent to sending a 16bit transaction (I'm not sure whether that works with cascaded 74hc595-like chips.)
I have a bit of code like this (lines omitted to make easy reading) for running apa102 LED as I have described above
include spi.h uint_32_t LED;
SPI.begin()
LED = 0x00000000 // 32bits of zeros is needed to initialize the strip. SPI.transfer(&LED, 4) //I know i could / should use "sizeoff but I have a fixed size variable of 32bit
LED = oxEFFF0000 // this is code for brightness of 15, Blue level 255, Green level 0, red level 0 (4 bytes) SPI.transfer(&LED, 4)
LED = 0xEF0000FF SPI.transfer(&LED, 4) // this is brightness of 15, blue 0, green 0, red 255.
I not sure how to see what data is being pushed out the SPI, I am expecting that each "SPI.tranfer" is sending 32bits of information. Is there any easy way to look at what the output is giving? (I don't have access to an oscilloscope of logic tester)
I have seen mentioned about using the SPI.begintranfer() and endtransfer() but haven't seen any code examples with this or if it is needed.
