Syntax question in code
I have a question about syntax in the code snippet below:
What is meaning of using the "%" percent sign in Arduino code? I have seen this in other code but I have not been able to discover the use for this or maybe I am just not looking in the correct places.
Thanks in advance for any assistance.
Jim
Snippet:
// Removes noise from sensor data
int average(int rawIn, int *averageArray) {
long total = 0;
static int i;
i = (i + 1) % 16;
averageArray = rawIn;
  • for (int j = 0; j < 16; j++) total += averageArray[j];*
  • total += total % 16;*
  • return total >> 4 ;*
It's the Modulo operator and returns a number between 0 and (n-1),
where 'n' is the value to the right of the '%'.
For example:
x x%n (where n=5)
0 0
1 1
2 2
3 3
4 4
5 0
6 1
7 2
8 3
9 4
10 0
As Rusty says, it's the modulo (or mod) operator, also known as the remainder of integer division.
21 / 10 is 2.
21 % 10 is 1.
-j
Thanks to both of you but.......Is it 21/10 = 2 or 1? How can it be both?
Let me see. If we divide 21 by 10, it will not divide evenly and have a remainder of .5 so we round up to get 2?
As an integer, using the %(Modulo) since no fractions or decimals are allowed, then we round it to 1? :wink:
Jim
There is no rounding: integer division truncates, modulo gives an integer remainder (which of course could be zero).
I showed the division operator for comparison; it seems to have added confusion instead. oops.
-j
The modulus operator gives you the remainder after integer division:
21 / 10 = 2 (remember, it's truncating integer division)
21 % 10 = 1 (the remainder that you would get from the above division)
