Syntax question on type declarations
I was looking through some code in the libraries and I saw a structure declaration as such:
typedef struct  {
  uint8_t nbr        :6 ;             // a pin number from 0 to 63
  uint8_t isActive   :1 ;             // true if this channel is enabled, pin not pulsed if false
} ServoPin_t   ;
What is the :6 and the :1?
Vince,
Those are called bit fields. It means that 'nbr' is an unsigned integer that is 6 bits long, and 'isActive' is 1 bit wide.
Regards,
-Mike
Thanks, Mike.
