Hello Folks,
I have a sketch with RTC, I2C, 5v pump on a relay. Want to water my plant every day at a given time, the sketch has no errors, but when it's time to water it does not signal relay to run the pump...
Welcome to the forum
Please post it here, using code tags when you do
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
RTC_DS1307 RTC;
#define RELAY_PIN 2
bool newData; //new data on serial
bool watering = false; //status if watering is allowed or not
bool wateredtoday = false;
int wateringhour = 1533; // water at 9:00 o'clock in the morning (24h time format!)
float wateringlength = 4000; //10 sec default watering (pumping time)
const int relaypin = 2;
lcd.init(); // initialize the lcd
lcd.init();
lcd.backlight();
pinMode(RELAY_PIN, OUTPUT);
Wire.begin();
RTC.begin();
//Refreshing time
//remove "!", compile, upload to refresh the time in the RTC module
//the time will be set to the time of the compilation
if (!RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
Serial.println("Irrigation system.");
//Fancy startup
lcd.clear();
lcd.setCursor(0, 0); //Defining positon to write from first row,first column .
lcd.print("Watering System");
lcd.setCursor(0, 1);
lcd.print("Start in 5..."); //You can write 16 Characters per line .
delay(1000); //wait 3 sec
lcd.print("Start in 4..."); //You can write 16 Characters per line .
lcd.print("Start in 3..."); //You can write 16 Characters per line .
lcd.print("Start in 2..."); //You can write 16 Characters per line .
lcd.print("Start in 1..."); //You can write 16 Characters per line .
printtime();
checkSerial();
checktime();
executecommand();
void checkSerial() {
//First we check if there is data on the serial port, i.e. we sent a command
if (Serial.available() > 0) {
newData = true;
//if there is a command, then we step inside and go through the possible commands
if (newData == true) {
watering = true; //change the boolean, so the watering will be ENABLED
watering = false; //change the boolean, so the watering will be DISABLED
newData = false;
void executecommand() //execute the commands, i.e. checking which flag is en/dis-abled
if (watering == true) {
//start pump
digitalWrite(relaypin, HIGH);
//---print info on LCD
lcd.clear();
lcd.print("Watering");
lcd.print("Running"); //You can write 16 Characters per line .
//---Run pump for some time (defined in the beginning of the code as a variable)
delay(wateringlength);
//---Shut down pump, set pin to LOW
digitalWrite(relaypin, LOW);
//---Clean screen
lcd.clear();
//---Disable watering
watering = false;
//--Change the value of the bool, so we'll know that the watering had happened
wateredtoday = true;
//do not do anything
void printtime() {
//it is just a basic RTC and LCD exercise: reading the date and time and printing it with some formatting
DateTime now = RTC.now();
//--First line
lcd.clear();
lcd.print(now.year());
lcd.setCursor(4, 0);
lcd.print(".");
lcd.setCursor(5, 0);
lcd.print(now.month());
lcd.setCursor(7, 0);
lcd.print(".");
lcd.setCursor(8, 0);
lcd.print(now.day());
lcd.setCursor(11, 0);
lcd.print("water");
//--Second line
lcd.print(now.hour()); //You can write 16 Characters per line .
lcd.setCursor(2, 1);
lcd.print(":");
lcd.setCursor(3, 1);
lcd.print(now.minute());
lcd.setCursor(5, 1);
lcd.print(":");
lcd.setCursor(6, 1);
lcd.print(now.second());
lcd.setCursor(10, 1);
//if the watering had happened, then we print it on the screen.
if (wateredtoday == true) {
lcd.print("true");
lcd.print("false");
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
void checktime() {
//Here, we check the time, so we can see if the watering should be started
//after the watering time occured, we switch the variable back to false so when the
//time occurs again (i.e. it is 9:00 in the morning) the watering will be started again
if (now.hour() == (wateringhour + 1)) {
//Serial.println("Watered");
//If it is time to water, and we haven't watered, we enable watering
if (now.hour() == wateringhour && wateredtoday == false) {
//Serial.println("Not watered");
watering = true;
- Check your braces
Thank you I will try it...
- Say what ? 1533 water at 9:00 o'clock in the morning
- Suggest you slow down and revisit every line of code, ask yourself, does this line of code make sense ?
I change the actual time to water trying to see if it will run pump, instead of waiting 24hrs.
Hello, I don't understand the (wateringhour +1)
Also, I'm new to Arduino...
- Put some Serial.print statements at strategic locations to check to see if variables are what you think they are.
What's the purpose, if I want to water at 0900 for 10 seconds?
Correct, I didn't write it, so I'm open to cleaning it up
I don't have the unit with me, will have to try the bracket change tonight.
Thank you for your time and knowledge, I'm still learning
#include <Wire.h>
#include <RTClib.h>
RTC_DS1307 RTC;
#define RELAY_PIN 2
lcd.init();
lcd.backlight();
Wire.begin();
RTC.begin();
//Refreshing time
//Fancy startup
lcd.clear();
printtime();
checkSerial();
checktime();
executecommand();
newData = true;
newData = false;
//start pump
lcd.clear();
//---Clean screen
lcd.clear();
watering = false;
void printtime() {
//--First line
lcd.clear();
lcd.print(".");
lcd.print(".");
lcd.print("water");
//--Second line
lcd.print(":");
lcd.print(":");
lcd.print("true");
lcd.print("false");
Serial.print('/');
Serial.print('/');
Serial.print(' ');
Serial.print(':');
Serial.print(':');
void checktime() {
watering = true;
Sounds good, Thank you
