I have two UNO WiFi Rev2s and I monitor the system time on both. One of them is very consistent in keeping close to the actual time using Epoch time as a reference.
The other one is a different matter. In the 5 hours since the program started and had the system time initially set it has already advanced ahead of Epoch time by about 18 seconds. I can deal with this but the accuracy difference between the two is considerable. Is this due to the crystal or its associated circuitry? I know back in 2019 there was a component issue related to the crystal:
But both my Arduinos are only a couple years old and should not be included in that manufacturing blip.
I am not in any way learned on microprocessor hardware design but was wondering if after setTime() completes an update to the processor is millis() responsible for the time advancement and does this in conjunction with the crystal?
EDIT: I realize you are using a WiFiRev2 and I believe that there is a crystal on that device. I'm not certain what the specification is.
Correct, but with the Nano Every there is no external crystal oscillator but an internal oscillator. (OSC20M) This system clock is divided down to run TimerB3 which is the timer used by millis( )
From my review of the data sheet, I believe the spec on the OSC20M oscillator is +/- 2% so if you are seeing 18 seconds in 18000 seconds you are well within spec. There are registers for setting a calibration of the main clock, but you will need to spend some time deep in the data sheet for the 4809 to figure it out.
We have discussed this previously, but you may you may want to explore using the fork of the time library which uses the 4809 real time counter driven by the crystal instead of the system clock and the millis() timer.
