# 問題 'T' does not name a type
**URL:** <https://forum.arduino.cc/t/t-does-not-name-a-type/329988>\
**Category:** 中文 (Chinese)\
**Created:** [August 17, 2015, 1:52am UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988 "2015-08-17T01:52:12Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![chan40](https://avatars.discourse-cdn.com/v4/letter/c/f04885/32.png) [@chan40](https://forum.arduino.cc/u/chan40)\
**Post date:** [August 17, 2015, 1:52am UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988/1 "2015-08-17T01:52:12Z")
</div>
下面這是我使用的程式碼
// Based on I2Cdevlib, MPU6050\_raw
// Experiments to verify if any data loss when writing MPU6050 outputs to EEPROM
#include "I2Cdev.h"
#include "MPU6050.h"
#include \<EEPROM.h\>
#include "eeprom\_anything.h"
// Arduino Wire library is required if I2Cdev I2CDEV\_ARDUINO\_WIRE implementation
// is used in I2Cdev.h
#if I2CDEV\_IMPLEMENTATION == I2CDEV\_ARDUINO\_WIRE
#include "Wire.h"
#endif
MPU6050 accelgyro;
int16\_t ax, ay, az;
int16\_t gx, gy, gz;
// [eeprom]
struct accelData{
int16\_t ax;
int16\_t ay;
int16\_t az;
accelData acc;
int accIdx = 0;
int accMem = 0;
int max = 1024 / sizeof(acc);
// join I2C bus (I2Cdev library doesn't do this automatically)
Wire.begin();
#elif I2CDEV\_IMPLEMENTATION == I2CDEV\_BUILTIN\_FASTWIRE
Fastwire::setup(400, true);
#endif
// initialize serial communication
// (38400 chosen because it works as well at 8MHz as it does at 16MHz, but
// it's really up to you depending on your project)
Serial.begin(38400);
// initialize device
Serial.println("Initializing I2C devices...");
accelgyro.initialize();
// verify connection
Serial.println("Testing device connections...");
Serial.println(accelgyro.testConnection() ? "MPU6050 connection successful" : "MPU6050 connection failed");
//writeEEPROM();
dumpEEPROM();
void writeEEPROM()
// read raw accel/gyro measurements from device
accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
// waive the first 100 sensor data
if (accIdx \>= 200 && accIdx \< max + 200)
Serial.print("Idx: "); Serial.print(accIdx-200);
Serial.print(", ax: "); Serial.print(ax); acc.ax = ax;
Serial.print(", ay: "); Serial.print(ay); acc.ay = ay;
Serial.print(", az: "); Serial.println(az); acc.az = az;
accMem = EEPROM\_writeAnything(accMem, acc);
accIdx ;
## void dumpEEPROM() { accelData accTmp; int tmpMem = 0; for (int i=0; i\<max; i ) { tmpMem = EEPROM\_readAnything(tmpMem, accTmp); Serial.print("Idx: "); Serial.print(i); Serial.print(", ax: "); Serial.print(accTmp.ax); Serial.print(", ay: "); Serial.print(accTmp.ay); Serial.print(", az: "); Serial.println(accTmp.az); } }
這是我出現的error
MPU6050\_EEPROM:20: error: 'T' does not name a type
MPU6050\_EEPROM:20: error: ISO C++ forbids declaration of 'value' with no type [-fpermissive]
MPU6050\_EEPROM:21: error: 'T' has not been declared
跪求各位大神幫幫我 ~~~~
**Author:** ![liuzengqiang](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/liuzengqiang/32/213605_2.png) [@liuzengqiang](https://forum.arduino.cc/u/liuzengqiang)\
**Post date:** [September 3, 2015, 5:01am UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988/2 "2015-09-03T05:01:03Z")
</div>
把eeprom\_anything.h内容贴出来吧
**Author:** ![sonnyyu](https://avatars.discourse-cdn.com/v4/letter/s/71e660/32.png) [@sonnyyu](https://forum.arduino.cc/u/sonnyyu)\
**Post date:** [September 7, 2015, 3:04am UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988/3 "2015-09-07T03:04:27Z")
</div>
> liudr:
```arduino
#include <EEPROM.h>
#include <Arduino.h>  // for type definitions
template <class T> int EEPROM_writeAnything(int ee, const T& value)
    const byte* p = (const byte*)(const void*)&value;
    unsigned int i;
    for (i = 0; i < sizeof(value); i++)
	  EEPROM.write(ee++, *p++);
    return i;
template <class T> int EEPROM_readAnything(int ee, T& value)
    byte* p = (byte*)(void*)&value;
    unsigned int i;
	  *p++ = EEPROM.read(ee++);
    return i;
[http://playground.arduino.cc/Code/EEPROMWriteAnything](http://playground.arduino.cc/Code/EEPROMWriteAnything)
**Post date:** [September 8, 2015, 5:31am UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988/4 "2015-09-08T05:31:16Z")
</div>
不知道什么神人六七年前写的程序了，有问题只能后果自负。我对Template不熟悉，不好意思。
**Post date:** [May 6, 2021, 6:03pm UTC](https://forum.arduino.cc/t/t-does-not-name-a-type/329988/5 "2021-05-06T18:03:00Z")
</div>
