Hello, I'm trying to fing a gsm module that works on T-Mobile so I can send text messages. I founds a lot of gsm modules But I don't know which one will work. I'm looking at what frequencies does T-Mobile uses and it is all over the place. Plus the whole 4G lte and the 5G. I'm nore sure what to really use for a module. I'm in the USA and I need help to figure out which module I can use on a arduino. Can you help me out please?
The cellular frequency has nothing to do with sending a SMS Text message. Next, you want to give this a read. You will need the called out shield or similar.
If you want to play around with just sending a SMS Text from your home PC there is a simple script (.vbs) you can run. Possibly with your Arduino on a serial port.
Cellular carriers use a text message gateway you may need. For T-Mobile it should be number@tmomail.net. The following assumes a Windows operating system. If you want to try an experiment copy the following code and paste it into notepad.
CreateMailMessage "number@tmomail.net", _
"test message from VBScript", _
Sub CreateMailMessage(strTo, strSubject, strBody)
Set appOutlook = CreateObject("Outlook.Application")
Set msg = appOutlook.CreateItem(olMailItem)
With msg
.To = strTo
.Subject = strSubject
.Body = strBody
.Send
End With
End Sub
Save the file to for example your desktop on your PC and save it as a .vbs file type. File > Save As > File Name (pick a name followed by .vbs) File Type .vbs. Saved on your desktop just double click the saved file and check your phone for a text. Modify the code for whatever text you want to send. I never tried calling the code up using an Arduino. There should be a way tpo go about it.
If your device will be in wifi range and the SMS target phone service provider allows SMSs via email (the text message gateway that @Ron_Blain mentioned), then you don't need a GSM module: all you need is an ESP8266, ESP32, or other Arduino with wifi.
Hello all, Thank you for the reply back. My problem is not coding. My problem is I do not know which shield or module would work on the Tmobile network. I boughta few that was cheap thinking they would work. Because they stated it will work on the Tmobile network and that was a lie. I do not know which one will work on the USA T-mobile network.
Just about any of them should work with the proper coding. This may go much better with a link to any modules you have and include the code you are using. T-Mobile in the US should use the number@tmomail.net so you use yout ten digit number with @tmomail.net which is the T-Mobile gateway. Just about any shield should work. Did you read through the link I provided earlier?
Well the first one won't work on T-Mobile USA because as it says on the PCB legend it's 900-1800 dual band which are European GSM bands! Tmo would be 800-1700.
That may be true as they may well have switched off their GSM already. But the USA does not use the 900/1800 spectrum anywhere AFAIK. The equivalent is 800/1900 (sorry not 1700). So a 900/1800 device will not see any base station transmissions in the USA. When we used to only have quad band GSM handsets for international roaming, they did 900/1800 in EU and 800/1900 in USA. For my sins I spent some unhappy times selling small GSM base stations to TMO both in UK and USA.
Hello all Thank you for the reply back. As I'm searching for a gsm module or shield. To use on the Tmobile network. I'm finding it hard to find one. I have no clue what Gsm module will work.
