* Soldering IRON controller for hakko t12 tips built on atmega328 microcontroller running 16 MHz
* The controller is using interrupts from the Timer1 to generate high-frequence PWM signal on port D10
* to silently heat the IRON and periodically check the IRON temperature on overflow interrupts
* Timer1 runs with prescale 1 through 0 to 255 and back and its frequency is 31250 Hz.
* The owerflow interrupt running as folows:
* First, the current through the IRON is checked
* then the power, supplien to the IRON interrupted and the controller waits for 32 timer interrupts (about 1 ms)
* then the IRON temperature is checked and the power to the IRON restored
* then the controller waits for check_period Timer1 interrupts to restart the all procedure over again
* Code modifications by Sasiskas (Youtube channel)
// Edit the configuration file to select appropriate display type
#include <EEPROM.h>
#include "config.h"
#include "encoder.h"
#include "cfg.h"
#include "iron_tips.h"
#include "vars.h"
// Rotary encoder interface
const uint8_t R_MAIN_PIN = 2; // Rotary Encoder main pin (right)
const uint8_t R_SECD_PIN = 4; // Rotary Encoder second pin (left)
const uint8_t R_BUTN_PIN = 3; // Rotary Encoder push button pin
const uint8_t probePIN = A0; // Thermometer pin from soldering IRON
const uint8_t checkPIN = A1; // Iron current check pin
const uint8_t termisPIN = A2; // The thermistor pin to check ambient temperature
const uint8_t tiltswPIN = A3; // The tilt/reed/vibro switch pin
const uint8_t buzzerPIN = 11; // The simple buzzer to make a noise
const uint8_t heaterBIT = 0b00000100; // The Heater pin, D10, is 2-nd bit on the PORTB register
// The variables for Timer1 operations
volatile uint16_t tmr1_count; // The count to calculate the temperature and the current check periods
volatile bool iron_off; // Whether the IRON is switched off to check the temperature
const uint32_t temp_check_period = 20; // The IRON temperature check period, ms
//------------------------------------------ class BUZZER ------------------------------------------------------
class BUZZER {
public:
BUZZER(uint8_t buzzerP) { buzzer_pin = buzzerP; }
void activate(bool on) { this->on = on; }
void init(void) { pinMode(buzzer_pin, OUTPUT); noTone(buzzer_pin); }
void shortBeep(void) { if (on) tone(buzzer_pin, 3520, 160); }
void lowBeep(void) { if (on) tone(buzzer_pin, 880, 160); }
void doubleBeep(void) { if (on) { tone(buzzer_pin, 3520, 160); delay(300); tone(buzzer_pin, 3520, 160); } }
void failedBeep(void) { if (on) { tone(buzzer_pin, 3520, 160); delay(170);
tone(buzzer_pin, 880, 250); delay(260);
private:
uint8_t buzzer_pin;
bool on = true;
//------------------------------------------ class PID algoritm to keep the temperature -----------------------
/* The PID algorithm
* Un = Kp*(Xs - Xn) + Ki*summ{j=0; j<=n}(Xs - Xj) + Kd(Xn - Xn-1),
* Where Xs - is the setup temperature, Xn - the temperature on n-iteration step
* In this program the interactive formula is used:
* Un = Un-1 + Kp*(Xn-1 - Xn) + Ki*(Xs - Xn) + Kd*(Xn-2 + Xn - 2*Xn-1)
* With the first step:
* U0 = Kp*(Xs - X0) + Ki*(Xs - X0); Xn-1 = Xn;
* PID coefficients history:
* 10/14/2017 [768, 32, 328]
class PID {
public:
PID(void) {
Kp = 2009;
Ki = 16;
Kd = 2048;
void resetPID(int temp = -1); // reset PID algorithm history parameters
// Calculate the power to be applied
int32_t reqPower(int temp_set, int temp_curr);
int16_t changePID(uint8_t p, int k); // set or get (if parameter < 0) PID parameter
private:
void debugPID(int t_set, int t_curr, int32_t kp, int32_t ki, int32_t kd, int32_t delta_p);
int16_t temp_h0, temp_h1; // previously measured temperature
bool pid_iterate; // Whether the iterative process is used
int32_t i_summ; // Ki summary multiplied by denominator
int32_t power; // The power iterative multiplied by denominator
int32_t Kp, Ki, Kd; // The PID algorithm coefficients multiplied by denominator
const uint8_t denominator_p = 11; // The common coefficient denominator power of 2 (11 means divide by 2048)
void PID::resetPID(int temp) {
temp_h0 = 0;
power = 0;
i_summ = 0;
pid_iterate = false;
if ((temp > 0) && (temp < 1000))
temp_h1 = temp;
temp_h1 = 0;
int16_t PID::changePID(uint8_t p, int k) {
switch(p) {
case 1:
if (k >= 0) Kp = k;
return Kp;
case 2:
if (k >= 0) Ki = k;
return Ki;
case 3:
if (k >= 0) Kd = k;
return Kd;
default:
return 0;
int32_t PID::reqPower(int temp_set, int temp_curr) {
if (temp_h0 == 0) {
// When the temperature is near the preset one, reset the PID and prepare iterative formula
if ((temp_set - temp_curr) < 30) {
if (!pid_iterate) {
pid_iterate = true;
power = 0;
i_summ = 0;
i_summ += temp_set - temp_curr; // first, use the direct formula, not the iterate process
power = Kp*(temp_set - temp_curr) + Ki*i_summ;
// If the temperature is near, prepare the PID iteration process
int32_t kp = Kp * (temp_h1 - temp_curr);
int32_t ki = Ki * (temp_set - temp_curr);
int32_t kd = Kd * (temp_h0 + temp_curr - 2*temp_h1);
int32_t delta_p = kp + ki + kd;
power += delta_p; // power kept multiplied by denominator!
if (pid_iterate) temp_h0 = temp_h1;
temp_h1 = temp_curr;
int32_t pwr = power + (1 << (denominator_p-1)); // prepare the power to delete by denominator, round the result
pwr >>= denominator_p; // delete by the denominator
return pwr;
//------------------------- class FastPWM operations using Timer1 on pin D10 at 31250 Hz ----------------------
class FastPWM {
public:
FastPWM() { }
void init(void);
void duty(uint8_t d) { OCR1B = d; }
void off(void) { OCR1B = 0; PORTB &= ~heaterBIT; }
void FastPWM::init(void) {
pinMode(10, OUTPUT); // Use D10 pin for heating the IRON
PORTB &= ~heaterBIT; // Switch-off the power
tmr1_count = 0;
iron_off = false; // The volatile global variable
noInterrupts();
TCNT1 = 0;
TCCR1B = _BV(WGM13); // Set mode as phase and frequency correct pwm, stop the timer
TCCR1A = 0;
ICR1 = 256;
TCCR1B = _BV(WGM13) | _BV(CS10); // Top value = ICR1, prescale = 1; 31250 Hz
TCCR1A |= _BV(COM1B1); // XOR D10 on OC1B, detached from D09
OCR1B = 0; // Switch-off the signal on pin D10;
TIMSK1 = _BV(TOIE1); // Enable overflow interrupts @31250 Hz
interrupts();
//------------------------------------------ class soldering IRON ---------------------------------------------
class IRON : protected PID {
public:
IRON(uint8_t sensor_pin, uint8_t check_pin, uint8_t ambient_pin, uint8_t tilt_pin) {
sPIN = sensor_pin;
cPIN = check_pin;
aPIN = ambient_pin;
tPIN = tilt_pin;
h_counter = h_max_counter;
typedef enum { POWER_OFF, POWER_ON, POWER_FIXED, POWER_COOLING } PowerMode;
void init(void);
void switchPower(bool On);
bool isOn(void);
uint16_t presetTemp(void) { return temp_set; }
uint16_t currTemp(void) { return h_temp.read(); }
uint16_t tempAverage(void) { return h_temp.average(); }
uint16_t tempDispersion(void) { return h_temp.dispersion(); }
uint16_t powerDispersion(void) { return h_power.dispersion(); }
uint8_t getMaxFixedPower(void) { return max_fixed_power; }
int16_t changePID(uint8_t p, int k) { return PID::changePID(p, k); }
bool checkIron(void); // Check the IRON, return true if the iron is not connected
void keepTemp(void); // Keep the IRON temperature, called by Timer1 interrupt
uint8_t appliedPower(void); // Power applied to the IRON in percents
void setTemp(uint16_t t); // Set the temperature to be kept (internal units)
void lowPowerMode(uint16_t t); // Activate low power mode (setup temp. or 0 to return to standard mode)
uint8_t getAvgPower(void); // Average applied power
void fixPower(uint8_t Power); // Set the specified power to the the soldering IRON
void initTempHistory(void) { h_counter = h_max_counter; h_temp.init(); mode = POWER_OFF; }
bool isCold(void) { return (mode == POWER_OFF); }
int16_t ambientTemp(void);
void adjust(uint16_t t);
bool isIronTiltSwitch(bool reed);
void checkSWStatus(void);
private:
FastPWM fastPWM; // Power the iron using fast PWM through D10 pin using Timer1
uint8_t sPIN, cPIN, aPIN, tPIN; // The sensor PIN, current check PIN, ambient temperature PIN, tilt switch PIN
uint16_t temp_set; // The temperature that should be kept
uint16_t temp_low; // Low power mode temperature
uint8_t fix_power = 0; // Fixed power value of the IRON (or zero if off)
uint32_t check_iron_ms = 0; // The time in ms when check the IRON next time
uint32_t check_tilt_ms = 0; // The time in ms when check the tilt switch next time
bool disconnected; // Whether no current through the IRON (the iron disconnected)
int h_counter; // Put the temperature and power to the history, when the counter become 0
uint8_t applied_power = 0; // The applied power to the IRON, used in checkIron()
volatile PowerMode mode = POWER_OFF; // Working mode of the IRON
volatile bool chill; // Whether the IRON should be cooled (preset temp is lower than current)
HISTORY h_power; // The history data of power applied values
HISTORY h_temp; // The history data of the temperature
EMP_AVERAGE current; // The average value for the current through the IRON
EMP_AVERAGE tilt; // The average value of tilt port
volatile EMP_AVERAGE amb_int; // The internal reading of ambient temperature
bool tilt_toggle = false; // The tilt switch changed state
const uint8_t max_power = 210; // maximum power to the IRON
const uint8_t max_fixed_power = 120; // Maximum power in fixed power mode
const uint16_t min_curr = 10; // The minimum current value to check the IRON is connected
const uint32_t check_period = 503; // Check the iron period in ms
const uint16_t h_max_counter = 500 / temp_check_period; // Put the history data twice a second
const uint8_t emp_k = 2; // The exponential average coefficient
const uint8_t emp_tilt = 3; // The exponential average coefficient for tilt pin
const uint16_t iron_cold = 25; // The internal temperature when the IRON is cold
void IRON::init(void) {
pinMode(sPIN, INPUT);
pinMode(aPIN, INPUT);
pinMode(tPIN, INPUT);
fastPWM.init(); // Initialization for 31.5 kHz PWM on D10 pin
mode = POWER_OFF;
fix_power = 0;
applied_power = 0;
disconnected = true; // Do not read the ambient temperature when the IRON disconnected
check_iron_ms = 0;
resetPID();
h_power.init();
h_temp.init();
current.length(emp_k);
tilt.length(emp_tilt);
amb_int.length(4);
void IRON::setTemp(uint16_t t) {
if (mode == POWER_ON) resetPID();
temp_set = t;
uint16_t ta = h_temp.average();
chill = (ta > t + 5); // The IRON must be cooled
temp_low = 0; // disable low power mode
void IRON::lowPowerMode(uint16_t t) {
if ((mode == POWER_ON && t < temp_set) || t == 0)
temp_low = t; // Activate low power mode
uint8_t IRON::getAvgPower(void) {
uint16_t p = h_power.average();
return p & 0xff;
uint8_t IRON::appliedPower(void) {
uint8_t p = getAvgPower();
return map(p, 0, max_power, 0, 100);
void IRON::switchPower(bool On) {
if (!On) {
fastPWM.off();
fix_power = 0;
if (mode != POWER_OFF)
mode = POWER_COOLING;
return;
resetPID(analogRead(sPIN));
h_power.init();
mode = POWER_ON;
bool IRON::isOn(void) {
return (mode == POWER_ON || mode == POWER_FIXED);
bool IRON::checkIron(void) {
if (millis() < check_iron_ms)
return disconnected;
check_iron_ms = millis() + check_period;
uint16_t curr = 0;
if (applied_power == 0) { // The IRON is switched-off
fastPWM.duty(127); // Quarter of maximum power
for (uint8_t i = 0; i < 5; ++i) { // Make sure we check the current in active phase of PWM signal
delayMicroseconds(31);
uint16_t c = analogRead(cPIN); // Check the current through the IRON
if (c > curr) curr = c; // The maximum value
fastPWM.off();
if (curr > min_curr * 2) // Do not put big values in to the history
curr = min_curr * 2; // This is enough to ensure the IRON is connected
curr = current.average(curr); // Calculate exponential average value of the current
curr = analogRead(cPIN);
disconnected = (curr < min_curr);
if (mode == POWER_OFF || mode == POWER_COOLING) { // If the soldering IRON is set to be switched off
fastPWM.off(); // Surely power off the IRON
// This routine is used to keep the IRON temperature near required value and is activated by the Timer1
void IRON::keepTemp(void) {
uint16_t ambient = analogRead(aPIN); // Update ambient temperature
amb_int.update(ambient);
uint16_t t = analogRead(sPIN); // Read the IRON temperature
volatile uint16_t t_set = temp_set; // The preset temperature depends on usual/low power mode
if (temp_low) t_set = temp_low;
if ((t >= temp_max + 20) || (t > (t_set + 100))) { // Prevent global over heating
if (mode == POWER_ON) chill = true; // Turn off the power in main working mode only;
if (t < temp_max) { // Do not save to the history readings when the IRON is disconnected
if (--h_counter < 0) {
h_temp.update(t);
int32_t p = 0;
switch (mode) {
case POWER_OFF:
case POWER_COOLING:
if (h_temp.average() < iron_cold)
mode = POWER_OFF;
case POWER_ON:
if (chill) {
if (t < (t_set - 2)) {
chill = false;
resetPID();
p = PID::reqPower(t_set, t);
p = constrain(p, 0, max_power);
case POWER_FIXED:
p = fix_power;
default:
applied_power = p & 0xff;
if (h_counter == 1) {
h_power.update(applied_power);
fastPWM.duty(applied_power);
void IRON::fixPower(uint8_t Power) {
if (Power == 0) { // To switch off the IRON, set the Power to 0
fix_power = 0;
fastPWM.off();
return;
if (Power > max_fixed_power)
Power = max_fixed_power;
fix_power = Power;
mode = POWER_FIXED;
* Return ambient temperature in Celsius
* Caches previous result to skip expensive calculations
int16_t IRON::ambientTemp(void) {
static const uint16_t add_resistor = 10030; // The additional resistor value (10koHm)
static const float normal_temp[2]= { 10000, 25 }; // nominal resistance and the nominal temperature
static const uint16_t beta = 3950; // The beta coefficient of the thermistor (usually 3000-4000)
static int32_t average = -1; // Previous value of ambient temperature (readings on aPIN)
static int cached_ambient = ambient_tempC; // Previous value of the temperature
uint16_t a_temp = amb_int.read(); // Average value of ambient temperature
if (abs(a_temp - average) < 20)
return cached_ambient;
average = a_temp;
if (average < 975) { // prevent division by zero
// convert the value to resistance
float resistance = 1023.0 / (float)average - 1.0;
resistance = (float)add_resistor / resistance;
float steinhart = resistance / normal_temp[0]; // (R/Ro)
steinhart = log(steinhart); // ln(R/Ro)
steinhart /= beta; // 1/B * ln(R/Ro)
steinhart += 1.0 / (normal_temp[1] + 273.15); // + (1/To)
steinhart = 1.0 / steinhart; // Invert
steinhart -= 273.15; // convert to Celsius
cached_ambient = round(steinhart);
} else { // about -30 *C, perhaps, the IRON is disconnected
void IRON::adjust(uint16_t t) {
if (t > temp_max) t = temp_max; // Do not allow over heating
temp_set = t;
// If any switch is short, its status is 'true'
void IRON::checkSWStatus(void) {
if (millis() > check_tilt_ms) {
check_tilt_ms = millis() + 100;
if (!disconnected) { // Current through the IRON is registered
uint16_t avg = tilt.read();
if (300 < avg && avg < 700) { // Middle state
avg = tilt.average(analogRead(tPIN));
if (avg < 300 || avg > 700) { // Toggle state
tilt_toggle = true;
tilt.update(analogRead(tPIN));
bool IRON::isIronTiltSwitch(bool reed) {
bool ret = tilt_toggle;
if (reed) {
return tilt.read() < 300;
return ret;
//------------------------------------------ class SCREEN ------------------------------------------------------
class SCREEN {
public:
SCREEN* next; // Pointer to the next screen
SCREEN* nextL; // Pointer to the next Level screen, usually, setup
SCREEN* main; // Pointer to the main screen
SCREEN* no_iron; // Pointer to the screen when the IRON was disconnected
SCREEN() {
next = nextL = main = no_iron = 0;
update_screen = 0;
scr_timeout = 0;
time_to_return = 0;
virtual void init(void) { }
virtual SCREEN* show(void) { return this; }
virtual SCREEN* menu(void) { if (this->next != 0) return this->next; else return this; }
virtual SCREEN* menu_long(void) { if (this->nextL != 0) return this->nextL; else return this; }
virtual void rotaryValue(int16_t value) { }
bool isSetup(void) { return (scr_timeout != 0); }
void forceRedraw(void) { update_screen = 0; }
virtual SCREEN* returnToMain(void) {
if (main && scr_timeout && (millis() >= time_to_return)) {
scr_timeout = 0;
return main;
return this;
void resetTimeout(void) {
if (scr_timeout > 0)
time_to_return = millis() + scr_timeout*1000;
void setSCRtimeout(uint16_t t) {
scr_timeout = t;
resetTimeout();
bool wasRecentlyReset(void) {
uint32_t to = (time_to_return - millis()) / 1000;
return((scr_timeout - to) < 15);
protected:
uint32_t update_screen; // Time in ms when the screen should be updated
uint32_t scr_timeout; // Timeout is sec. to return to the main screen, canceling all changes
uint32_t time_to_return; // Time in ms to return to main screen
//---------------------------------------- class mainSCREEN [the soldering IRON is OFF] ------------------------
class mainSCREEN : public SCREEN {
public:
mainSCREEN(IRON* Iron, DSPL* DSP, RENC* ENC, BUZZER* Buzz, IRON_CFG* Cfg) {
pIron = Iron;
pD = DSP;
pEnc = ENC;
pBz = Buzz;
pCfg = Cfg;
virtual void init(void);
virtual SCREEN* show(void);
virtual void rotaryValue(int16_t value); // Setup the preset temperature
private:
IRON* pIron; // Pointer to the IRON instance
DSPL* pD; // Pointer to the DSPLay instance
RENC* pEnc; // Pointer to the rotary encoder instance
BUZZER* pBz; // Pointer to the simple buzzer instance
IRON_CFG* pCfg; // Pointer to the configuration instance
uint32_t clear_used_ms; // Time in ms when used flag should be cleared (if > 0)
uint32_t change_display; // Time in ms when to switch display between preset temperature and tip name
bool used; // Whether the IRON was used (was hot)
bool cool_notified; // Whether there was cold notification played
bool show_tip; // Whether show the tip name instead of preset temperature
const uint16_t period = 1000; // The period to update the screen
const uint32_t cool_notify_period = 120000; // The period to display 'cool' message (ms)
const uint16_t show_temp = 20000; // The period in ms to show the preset temperature
void mainSCREEN::init(void) {
pIron->switchPower(false);
uint16_t temp_set = pIron->presetTemp();
int16_t ambient = pIron->ambientTemp();
temp_set = pCfg->tempToHuman(temp_set, ambient); // The preset temperature in the human readable units
if (pCfg->isCelsius())
pEnc->reset(temp_set, temp_minC, temp_maxC, 1, 5);
pEnc->reset(temp_set, temp_minF, temp_maxF, 1, 5);
used = !pIron->isCold();
cool_notified = !used;
if (used) { // the IRON was used, we should save new data in EEPROM
pCfg->savePresetTempHuman(temp_set);
clear_used_ms = 0;
forceRedraw();
pD->clear();
pD->msgOff();
show_tip = false;
change_display = millis() + show_temp;
void mainSCREEN::rotaryValue(int16_t value) {
uint16_t temp = pCfg->humanToTemp(value, ambient);
pIron->setTemp(temp);
pD->tSet(value, pCfg->isCelsius());
uint32_t ms = millis();
update_screen = ms + period;
change_display = ms + show_temp;
show_tip = false;
SCREEN* mainSCREEN::show(void) {
SCREEN* nxt = this;
if (no_iron && pIron->checkIron()) { // Check that the IRON is connected
nxt = no_iron;
if (millis() < update_screen) return nxt;
update_screen = millis() + period;
if (clear_used_ms && (millis() > clear_used_ms)) {
clear_used_ms = 0;
used = false;
if (millis() > change_display) {
show_tip = !show_tip;
change_display = millis() + 2000;
if (!show_tip) change_display += show_temp;
// if (show_tip) {
// pD->tip(pCfg->tipName(), true);
// } else {
pD->tSet(temp_set, pCfg->isCelsius());
pD->msgOff();
uint16_t temp = pIron->tempAverage();
uint16_t tempH = pCfg->tempToHuman(temp, ambient);
if (pIron->isCold()) {
if (used)
pD->msgCold();
pD->tCurr(tempH,pCfg->isCelsius());
if (used && !cool_notified) {
pBz->lowBeep();
cool_notified = true;
clear_used_ms = millis() + cool_notify_period;
return nxt;
//---------------------------------------- class tipSCREEN [tip is disconnected, choose new tip] ---------------
class tipSCREEN : public SCREEN {
public:
tipSCREEN(IRON* Iron, DSPL* DSP, RENC* ENC, IRON_CFG* Cfg) {
pIron = Iron;
pD = DSP;
pEnc = ENC;
pCfg = Cfg;
virtual void rotaryValue(int16_t value); // Select the tip
private:
uint8_t old_tip; // previous tip index
void tipSCREEN::init(void) {
old_tip = pCfg->tipIndex();
pEnc->reset(old_tip, 0, pCfg->tipsLoaded(), 1, 1, true);// Select the tip by the rotary encoder
forceRedraw();
pD->clear();
pD->msgSelectTip();
void tipSCREEN::rotaryValue(int16_t value) {
if (value == old_tip) return;
uint8_t index = pCfg->nextTip(old_tip, value > old_tip);
uint16_t temp = pIron->presetTemp(); // Preset temperature in internal units
temp = pCfg->tempToHuman(temp, ambient); // The temperature in human readable units (Celsius o Fahrenheit)
index = pCfg->selectTip(index);
old_tip = index;
pEnc->write(index);
temp = pCfg->humanToTemp(temp, ambient); // Translate previously set temperature in human readable units into internal value
pIron->setTemp(temp); // Install previously set temperature into the IRON by new tip calibration
forceRedraw();
SCREEN* tipSCREEN::show(void) {
SCREEN* nxt = this;
if (no_iron && !pIron->checkIron()) { // Check that the IRON is disconnected
nxt = no_iron;
pIron->initTempHistory(); // The new tip is connected, reset the temp history
pD->tip(pCfg->tipName(), false);
pD->markCalibrated('*', pCfg->isCalibrated());
return nxt;
//---------------------------------------- class actSCREEN [Toggle tip activation ] ----------------------------
class actSCREEN : public SCREEN {
public:
actSCREEN(IRON* Iron, DSPL* DSP, RENC* ENC, IRON_CFG* Cfg) {
pIron = Iron;
pD = DSP;
pEnc = ENC;
pCfg = Cfg;
virtual SCREEN* menu(void);
private:
const uint16_t period = 10000; // The period to update the screen
void actSCREEN::init(void) {
char *n = pCfg->tipName();
int8_t global_index = pCfg->index(n); // Find current tip in the global tip array by the name
if (global_index < 0) global_index = 0;
pEnc->reset(global_index, 0, pCfg->tipsLoaded(), 1, 1, true);// Select the tip by the rotary encoder
pD->clear();
pD->msgActivateTip();
void actSCREEN::rotaryValue(int16_t value) {
forceRedraw();
SCREEN* actSCREEN::menu(void) {
uint8_t tip = pEnc->read();
bool active = pCfg->toggleTipActivation(tip);
forceRedraw();
return this;
SCREEN* actSCREEN::show(void) {
if (millis() < update_screen) return this;
bool active = pCfg->isTipActive(tip);
char tip_name[tip_name_sz+1];
pCfg->name(tip_name, tip);
tip_name[tip_name_sz] = '\0';
pD->clear();
pD->tip(tip_name, false);
pD->markActivated('x', active);
return this;
//---------------------------------------- class workSCREEN [the soldering IRON is ON] -------------------------
class workSCREEN : public SCREEN {
public:
workSCREEN(IRON* Iron, DSPL* DSP, RENC* Enc, BUZZER* Buzz, IRON_CFG* Cfg) {
update_screen = 0;
pIron = Iron;
pD = DSP;
pBz = Buzz;
pEnc = Enc;
pCfg = Cfg;
virtual void rotaryValue(int16_t value); // Change the preset temperature
virtual SCREEN* returnToMain(void); // Automatic power-off
private:
void adjustPresetTemp(void);
void hwTimeout(uint16_t low_temp, bool tilt_active);
BUZZER* pBz; // Pointer to the simple Buzzer instance
bool ready; // Whether the IRON have reached the preset temperature
bool lowpower_mode = false; // Whether hardware low power mode using tilt switch
uint32_t lowpower_time = 0; // Time when switch to standby power mode
uint32_t auto_off_notified; // The time (in ms) when the automatic power-off was notified
uint16_t tempH = 0; // The preset temperature in human readable units
const uint16_t period = 1000; // The period to update the screen (ms)
void workSCREEN::init(void) {
bool is_celsius = pCfg->isCelsius();
tempH = pCfg->tempToHuman(temp_set, ambient);
if (is_celsius)
pEnc->reset(tempH, temp_minC, temp_maxC, 1, 5);
pEnc->reset(tempH, temp_minF, temp_maxF, 1, 5);
pIron->switchPower(true);
ready = false;
lowpower_time = 0;
time_to_return = 0;
pD->clear();
pD->tSet(tempH, is_celsius);
pD->msgOn();
uint16_t to = pCfg->getOffTimeout() * 60;
this->setSCRtimeout(to);
auto_off_notified = 0;
forceRedraw();
void workSCREEN::rotaryValue(int16_t value) { // Setup new preset temperature by rotating the encoder
tempH = value;
ready = false;
pD->msgOn();
uint16_t temp = pCfg->humanToTemp(value, ambient); // Translate human readable temperature into internal value
SCREEN::resetTimeout();
SCREEN* workSCREEN::show(void) {
SCREEN* nxt = this;
int tempH = pCfg->tempToHuman(temp, ambient);
uint8_t p = pIron->appliedPower();
pD->percent(p);
uint16_t td = pIron->tempDispersion();
uint16_t pd = pIron->powerDispersion();
int ap = pIron->getAvgPower();
uint16_t low_temp = pCfg->lowTemp(); // 'Standby temperature' setup in the main menu
if ((abs(temp_set - temp) < 3) && (pIron->tempDispersion() <= 10) && (ap > 0)) {
if (!ready) {
pBz->shortBeep();
ready = true;
pD->msgReady();
if (low_temp)
lowpower_time = millis() + (uint32_t)pCfg->lowTimeout() * 1000;
update_screen = millis() + (period << 2);
return this;
bool tilt_active = false;
if (low_temp) {
tilt_active = pIron->isIronTiltSwitch(pCfg->isReedType());
// If the automatic power-off feature is enabled, check the IRON status
if (low_temp && ready && pCfg->getOffTimeout()) { // The IRON has reaches the preset temperature
hwTimeout(low_temp, tilt_active); // Use hardware tilt switch to turn low power mode
if (!lowpower_mode && pCfg->isAmbientSensor())
adjustPresetTemp();
if (ready) {
if (scr_timeout > 0 && (to < 100)) {
pD->timeToOff(to);
if (!auto_off_notified) {
pBz->shortBeep();
auto_off_notified = millis();
} else if (lowpower_mode) {
pD->msgStandby();
} else if (SCREEN::wasRecentlyReset()) {
pD->msgWorking();
pD->msgReady();
pD->msgOn();
resetTimeout();
return nxt;
SCREEN* workSCREEN::returnToMain(void) {
scr_timeout = 0;
pBz->doubleBeep();
return main;
return this;
void workSCREEN::adjustPresetTemp(void) {
uint16_t presetTemp = pIron->presetTemp(); // Preset temperature (internal units)
uint16_t temp = pCfg->humanToTemp(tempH, ambient); // Expected temperature of IRON in internal units
if (temp != presetTemp) { // The ambient temperature have changed, we need to adjust preset temperature
pIron->adjust(temp);
void workSCREEN::hwTimeout(uint16_t low_temp, bool tilt_active) {
uint32_t now_ms = millis();
if (tilt_active) { // If the IRON is used, Reset standby time
lowpower_time = now_ms + (uint32_t)pCfg->lowTimeout() * 1000; // Convert timeout to milliseconds
if (lowpower_mode) { // If the IRON is in low power mode, return to main working mode
pIron->lowPowerMode(0);
lowpower_time = 0;
ready = false;
pD->msgOn();
} else if (!lowpower_mode) {
if (lowpower_time) {
if (now_ms >= lowpower_time) {
uint16_t temp_low = pCfg->lowTemp();
uint16_t temp = pCfg->humanToTemp(temp_low, ambient);
pIron->lowPowerMode(temp);
auto_off_notified = false;
lowpower_mode = true;
resetTimeout(); // Activate automatic power-off
return;
//---------------------------------------- class powerSCREEN [fixed power to the IRON] -------------------------
class powerSCREEN : public SCREEN {
public:
powerSCREEN(IRON* Iron, DSPL* DSP, RENC* Enc, IRON_CFG* CFG) {
pIron = Iron;
pD = DSP;
pEnc = Enc;
pCfg = CFG;
on = false;
virtual SCREEN* menu_long(void);
private:
uint32_t update_screen; // Time in ms to update the screen
bool on; // Whether the power of soldering IRON is on
const uint16_t period = 1000; // The period in ms to update the screen
void powerSCREEN::init(void) {
uint8_t p = pIron->getAvgPower();
uint8_t max_power = pIron->getMaxFixedPower();
pEnc->reset(p, 0, max_power, 1);
on = true; // Do start heating immediately
pIron->fixPower(p);
pD->clear();
pD->pSet(p);
SCREEN* powerSCREEN::show(void) {
SCREEN* nxt = this;
nxt = no_iron;
pD->tCurr(temp,pCfg->isCelsius());
pD->percent(p);
return nxt;
void powerSCREEN::rotaryValue(int16_t value) {
pD->pSet(value);
pIron->fixPower(value);
on = true;
update_screen = millis() + (period * 2);
SCREEN* powerSCREEN::menu(void) {
on = !on;
if (on) {
uint16_t pos = pEnc->read();
pIron->fixPower(pos);
pD->clear();
pD->pSet(pos);
pIron->fixPower(0);
pD->clear();
pD->pSet(0);
forceRedraw();
return this;
SCREEN* powerSCREEN::menu_long(void) {
pIron->fixPower(0);
if (nextL) {
return nextL;
return this;
//---------------------------------------- class errorSCREEN [the soldering IRON error detected] ---------------
class errorSCREEN : public SCREEN {
public:
errorSCREEN(IRON* Iron, DSPL* DSP, BUZZER* Buzz) {
pIron = Iron;
pD = DSP;
pBz = Buzz;
virtual void init(void) { pIron->switchPower(false); pD->clear(); pD->msgFail(); pBz->failedBeep(); }
private:
DSPL* pD; // Pointer to the display instance
//---------------------------------------- class configSCREEN [configuration menu] -----------------------------
class configSCREEN : public SCREEN {
public:
configSCREEN(IRON* Iron, DSPL* DSP, RENC* Enc, IRON_CFG* Cfg, BUZZER* Buzz) {
pIron = Iron;
pD = DSP;
pEnc = Enc;
pCfg = Cfg;
pBz = Buzz;
SCREEN* calib; // Pointer to the calibration SCREEN
SCREEN* activate; // Pointer to the tip activation SCREEN
private:
IRON_CFG* pCfg; // Pointer to the config instance
BUZZER* pBz; // Pointer to the buzzer instance
uint8_t mode; // Which parameter to change
bool tune; // Whether the parameter is modifying
bool changed; // Whether some configuration parameter has been changed
bool cels; // Current Celsius/Fahrenheit;
bool buzzer; // Buzzer ON/OFF
bool reed; // The hardware switch type: reed/tilt
bool ambient; // The ambient temperature sensor enabled/disabled
uint8_t off_timeout; // Automatic switch-off timeout in minutes
uint16_t low_temp; // Standby temperature
uint8_t low_timeout; // Standby timeout
const uint16_t period = 10000; // The period in ms to update the screen
void configSCREEN::init(void) {
mode = 0;
// 0 - C/F, 1 - buzzer, 2 - switch type, 3 - ambient, 4 - standby temp, 5 - standby time,
// 6 - off-timeout, 7 - tip calibrate, 8 - atcivate tip, 9 - tune, 10 - save, 11 - cancel
pEnc->reset(mode, 0, 11, 1, 0, true);
tune = false;
changed = false;
cels = pCfg->isCelsius();
buzzer = pCfg->isBuzzer();
reed = pCfg->isReedType();
ambient = pCfg->isAmbientSensor();
off_timeout = pCfg->getOffTimeout();
low_timeout = pCfg->lowTimeout();
pD->clear();
pD->setupMode(0, false, 0);
this->setSCRtimeout(30);
SCREEN* configSCREEN::show(void) {
switch (mode) {
case 0: // C/F
pD->setupMode(mode, false, cels);
case 1: // buzzer
pD->setupMode(mode, tune, buzzer);
case 2: // switch type
pD->setupMode(mode, tune, reed);
case 3: // ambient temperature sensor
pD->setupMode(mode, tune, ambient);
case 4: // standby temp
pD->setupMode(mode, tune, low_temp);
case 5: // standby timeout
pD->setupMode(mode, tune, low_timeout);
case 6: // off-timeout
pD->setupMode(mode, tune, off_timeout);
default:
pD->setupMode(mode, false, 0);
return this;
void configSCREEN::rotaryValue(int16_t value) {
if (tune) { // tune the temperature units
changed = true;
switch (mode) {
case 1: // Buzzer
buzzer = value;
case 2: // Switch type
reed = value;
ambient = value;
case 4: // standby temperature
if (value > 0)
value += 179;
low_temp = value;
case 5: // Standby Time
low_timeout = value;
case 6: // tuning the switch-off timeout
if (value > 0) value += 2; // The minimum timeout is 3 minutes
off_timeout = value;
default:
mode = value;
forceRedraw();
SCREEN* configSCREEN::menu(void) {
if (tune) {
tune = false;
pEnc->reset(mode, 0, 11, 1, 0, true); // The value has been tuned, return to the menu list mode
switch (mode) {
case 0: // C/F. In-line editing
cels = !cels;
changed = true;
forceRedraw();
return this;
case 1: // Buzzer
pEnc->reset(buzzer, 0, 1, 1, 0, true);
pEnc->reset(reed, 0, 1, 1, 0, true);
pEnc->reset(ambient, 0, 1, 1, 0, true);
uint16_t v = low_temp;
if (v > 0) v -= 179;
pEnc->reset(v, 0, 120, 1, 5, false);
pEnc->reset(low_timeout, 10, 255, 1, 5, false);
int v = off_timeout;
if (v > 0) v -= 2;
pEnc->reset(v, 0, 28, 1, 5, false);
case 7:
if (calib) return calib;
case 8: // Activate tip
if (activate) return activate;
case 9: // Tune potentiometer
if (next) return next;
case 10: // Save configuration data
menu_long();
case 11: // Return to the main menu
if (main) return main;
return this;
tune = true;
forceRedraw();
return this;
SCREEN* configSCREEN::menu_long(void) {
if (nextL) {
if (changed) {
pCfg->setLowPower(low_temp, low_timeout, reed);
pCfg->saveConfig(off_timeout, cels, buzzer, ambient);
pBz->activate(buzzer);
return nextL;
return this;
//---------------------------------------- class calibSCREEN [ tip calibration ] -------------------------------
#define MCALIB_POINTS 8
class calibSCREEN : public SCREEN {
public:
calibSCREEN(IRON* Iron, DSPL* DSP, RENC* Enc, IRON_CFG* Cfg, BUZZER* Buzz) {
pIron = Iron;
pD = DSP;
pEnc = Enc;
pCfg = Cfg;
pBz = Buzz;
private:
bool calibrationOLS(uint16_t* tip, uint16_t min_temp, uint16_t max_temp);
uint8_t closestIndex(uint16_t temp);
void updateReference(uint8_t indx);
uint16_t calib_temp[2][MCALIB_POINTS]; // The calibration data: real temp. [0] and temp. in internal units [1]
uint8_t ref_temp_index = 0; // Which temperature reference to change: [0-MCALIB_POINTS]
uint16_t tip_temp_max = 0; // the maximum possible tip temperature in the internal units
uint16_t preset_temp; // The preset temp in human readable units
bool ready; // Ready to enter real temperature
const uint16_t t_diff = 60; // The adjustment could be in the interval [t_ref-t_diff; t_ref+2*t_diff]
const uint32_t period = 1000; // Update screen period
const uint16_t start_int_temp = 200; // Minimal temperature in internal units, about 100 degrees Celsius
void calibSCREEN::init(void) {
// Prepare to enter real temperature
uint16_t min_t = 50;
uint16_t max_t = 600;
if (!pCfg->isCelsius()) {
min_t = 122;
max_t = 1111;
pEnc->reset(0, min_t, max_t, 1, 5, false);
tip_temp_max = temp_max / 2;
for (uint8_t i = 0; i < MCALIB_POINTS; ++i) {
calib_temp[0][i] = 0; // Real temperature. 0 means not entered yet
calib_temp[1][i] = map(i, 0, MCALIB_POINTS-1, start_int_temp, tip_temp_max); // Internal temperature
ready = false; // Not ready to enter real temperature
ref_temp_index = 0;
pD->tRef(ref_temp_index);
preset_temp = pIron->presetTemp(); // Save the preset temperature in human readable units
preset_temp = pCfg->tempToHuman(preset_temp, ambient);
pD->clear();
pD->msgOff();
forceRedraw();
SCREEN* calibSCREEN::show(void) {
int16_t temp = pIron->tempAverage(); // Actual IRON temperature
if (ready) {
pD->tSet(tempH,pCfg->isCelsius());
} else { // Show the current Iron temperature
if (!pIron->isOn()) p = 0;
pD->percent(p);
if (! ready && abs(temp_set - temp) < 4 && pIron->tempDispersion() <= 20) {
pBz->shortBeep();
pD->msgReady();
ready = true;
pEnc->write(tempH);
if (ready && !pIron->isOn()) { // The IRON was switched off by error
pD->msgOff();
ready = false;
return this;
void calibSCREEN::rotaryValue(int16_t value) { // The Encoder rotated
if (ready) { // change the real value for the temperature
pD->tCurr(value,pCfg->isCelsius());
SCREEN* calibSCREEN::menu(void) { // Rotary encoder pressed
if (ready) { // The real temperature has been entered
uint16_t r_temp = pEnc->read();
uint16_t temp = pIron->tempAverage(); // The temperature of the IRON in internal units
pD->msgOff();
if (!cels) // Always save the human readable temperature in Celsius
r_temp = map(r_temp, temp_minF, temp_maxF, temp_minC, temp_maxC);
calib_temp[0][ref_temp_index] = r_temp;
calib_temp[1][ref_temp_index] = temp;
if (r_temp < temp_maxC - 20) {
updateReference(ref_temp_index); // Update reference temperature points
++ref_temp_index;
// Try to update the current tip calibration
uint16_t tip[3];
if (calibrationOLS(tip, 150, 600)) {
pCfg->applyCalibration(tip);
if ((r_temp >= temp_maxC - 20) || ref_temp_index >= MCALIB_POINTS) {
return menu_long(); // Finish calibration
} else { // Continue calibration
uint16_t temp = calib_temp[1][ref_temp_index];
} else { // Toggle the power
if (pIron->isOn()) {
pD->msgOff();
pD->msgOn();
ready = false;
forceRedraw();
return this;
SCREEN* calibSCREEN::menu_long(void) { // Save new tip calibration data
uint16_t tip[3];
if (calibrationOLS(tip, 150, temp_maxC)) {
uint8_t near_index = closestIndex(temp_tip[2]);
tip[2] = map(temp_tip[2], temp_tip[1], calib_temp[0][near_index],
tip[1], calib_temp[1][near_index]);
if (tip[2] > temp_max) tip[2] = temp_max;
pCfg->saveCalibrationData(tip, ambient_tempC);
pCfg->savePresetTempHuman(preset_temp);
uint16_t temp = pCfg->humanToTemp(preset_temp, ambient);
if (nextL) return nextL;
return this;
* Calculate tip calibration parameter using linear approximation by Ordinary Least Squares method
* Y = a * X + b, where
* Y - internal temperature, X - real temperature. a and b are double coefficients
* a = (N * sum(Xi*Yi) - sum(Xi) * sum(Yi)) / ( N * sum(Xi^2) - (sum(Xi))^2)
* b = 1/N * (sum(Yi) - a * sum(Xi))
bool calibSCREEN::calibrationOLS(uint16_t* tip, uint16_t min_temp, uint16_t max_temp) {
long sum_XY = 0; // sum(Xi * Yi)
long sum_X = 0; // sum(Xi)
long sum_Y = 0; // sum(Yi)
long sum_X2 = 0; // sum(Xi^2)
long N = 0;
uint16_t X = calib_temp[0][i];
uint16_t Y = calib_temp[1][i];
if (X >= min_temp && X <= max_temp) {
sum_XY += X * Y;
sum_X += X;
sum_Y += Y;
sum_X2 += X * X;
++N;
if (N <= 2) // Not enough real temperatures have been entered
return false;
double a = (double)N * (double)sum_XY - (double)sum_X * (double)sum_Y;
a /= (double)N * (double)sum_X2 - (double)sum_X * (double)sum_X;
double b = (double)sum_Y - a * (double)sum_X;
b /= (double)N;
for (uint8_t i = 0; i < 3; ++i) {
double temp = a * (double)temp_tip[i] + b;
tip[i] = round(temp);
return true;
// Find the index of the reference point with the closest temperature
uint8_t calibSCREEN::closestIndex(uint16_t temp) {
uint16_t diff = 1000;
uint8_t index = MCALIB_POINTS;
if (X > 0 && abs(X-temp) < diff) {
diff = abs(X-temp);
index = i;
return index;
void calibSCREEN::updateReference(uint8_t indx) { // Update reference points
uint16_t expected_temp = map(indx, 0, MCALIB_POINTS, temp_minC, temp_maxC);
uint16_t r_temp = calib_temp[0][indx];
if (indx < 5 && r_temp > (expected_temp + expected_temp/4)) { // The real temperature is too high
tip_temp_max -= tip_temp_max >> 2; // tip_temp_max *= 0.75;
if (tip_temp_max < temp_max / 4)
tip_temp_max = temp_max / 4; // Limit minimum possible value of the highest temperature
} else if (r_temp > (expected_temp + expected_temp/8)) { // The real temperature is biger than expected
tip_temp_max += tip_temp_max >> 3; // tip_temp_max *= 1.125;
if (tip_temp_max > temp_max)
tip_temp_max = temp_max;
} else if (indx < 5 && r_temp < (expected_temp - expected_temp/4)) { // The real temperature is too low
tip_temp_max += tip_temp_max >> 2; // tip_temp_max *= 1.25;
} else if (r_temp < (expected_temp - expected_temp/8)) { // The real temperature is lower than expected
return;
// rebuild the array of the reference temperatures
for (uint8_t i = indx+1; i < MCALIB_POINTS; ++i) {
//---------------------------------------- class tuneSCREEN [tune the potentiometer ] --------------------------
class tuneSCREEN : public SCREEN {
public:
//tuneSCREEN(IRON* Iron, DSPL* DSP, RENC* ENC, BUZZER* Buzz) {
tuneSCREEN(IRON* Iron, DSPL* DSP, RENC* ENC, BUZZER* Buzz, IRON_CFG* CFG) {
pIron = Iron;
pD = DSP;
pEnc = ENC;
pBz = Buzz;
pCfg = CFG;
private:
bool arm_beep; // Whether beep is armed
uint8_t max_power; // Maximum possible power to be applied
void tuneSCREEN::init(void) {
pEnc->reset(15, 0, max_power, 1, 5); // Rotate the encoder to change the power supplied
arm_beep = false;
pD->clear();
pD->msgTune();
forceRedraw();
void tuneSCREEN::rotaryValue(int16_t value) {
forceRedraw();
SCREEN* tuneSCREEN::show(void) {
pD->tCurrTune(tempH,pCfg->isCelsius());
pD->tCurr(temp);
uint8_t power = pEnc->read(); // applied power
if (!pIron->isOn())
power = 0;
power = map(power, 0, max_power, 0, 100);
pD->percent(power);
if (arm_beep && (pIron->tempDispersion() < 5)) {
pBz->shortBeep();
arm_beep = false;
return this;
SCREEN* tuneSCREEN::menu(void) { // The rotary button pressed
pIron->fixPower(0);
pIron->fixPower(power);
return this;
SCREEN* tuneSCREEN::menu_long(void) {
pIron->fixPower(0); // switch off the power
return this;
//---------------------------------------- class pidSCREEN [tune the PID coefficients] -------------------------
class pidSCREEN : public SCREEN {
public:
pidSCREEN(IRON* Iron, RENC* ENC) {
pIron = Iron;
pEnc = ENC;
private:
void showCfgInfo(void); // show the main config information: Temp set and PID coefficients
uint8_t mode; // Which temperature to tune [0-3]: select, Kp, Ki, Kd
uint32_t update_screen; // Time in ms when update the screen (print nre info)
int temp_set;
const uint16_t period = 500;
void pidSCREEN::init(void) {
mode = 0; // select the element from the list
pEnc->reset(1, 1, 4, 1, 1, true); // 1 - Kp, 2 - Ki, 3 - Kd, 4 - temp
showCfgInfo();
Serial.println("");
void pidSCREEN::rotaryValue(int16_t value) {
if (mode == 0) { // No limit is selected, list the menu
showCfgInfo();
switch (value) {
case 1:
Serial.println("Kp");
case 2:
Serial.println("Ki");
case 4:
Serial.println(F("Temp"));
case 3:
default:
Serial.println("Kd");
switch (mode) {
case 1:
Serial.print(F("Kp = "));
pIron->changePID(mode, value);
case 2:
Serial.print(F("Ki = "));
case 4:
Serial.print(F("Temp = "));
temp_set = value;
pIron->setTemp(value);
case 3:
default:
Serial.print(F("Kd = "));
Serial.println(value);
SCREEN* pidSCREEN::show(void) {
char buff[60];
int temp = pIron->currTemp();
uint8_t pwr = pIron->getAvgPower();
sprintf(buff, "%3d: power = %3d, td = %3d, pd = %3d --- ", temp_set - temp, pwr, td, pd);
Serial.println(buff);
return this;
SCREEN* pidSCREEN::menu(void) { // The rotary button pressed
if (mode == 0) { // select upper or lower temperature limit
mode = pEnc->read();
if (mode != 4) {
int k = pIron->changePID(mode, -1);
pEnc->reset(k, 0, 10000, 1, 10);
pEnc->reset(temp_set, 0, 970, 1, 5);
} else { // upper or lower temperature limit just setup
mode = 0;
return this;
SCREEN* pidSCREEN::menu_long(void) {
bool on = pIron->isOn();
pIron->switchPower(!on);
if (on)
Serial.println("The iron is OFF");
Serial.println("The iron is ON");
return this;
void pidSCREEN::showCfgInfo(void) {
Serial.print(F("Temp set: "));
Serial.print(temp_set, DEC);
Serial.print(F(", PID: ["));
for (uint8_t i = 1; i < 4; ++i) {
int k = pIron->changePID(i, -1);
Serial.print(k, DEC);
if (i < 3) Serial.print(", ");
Serial.print("]; ");
//=================================== End of class declarations ================================================
DSPL disp;
RENC encoder(R_MAIN_PIN, R_SECD_PIN, R_BUTN_PIN);
IRON iron(probePIN, checkPIN, termisPIN, tiltswPIN);
IRON_CFG ironCfg(MAX_CUSTOM_TIPS); // See config.h
BUZZER simpleBuzzer(buzzerPIN);
TIPS tips;
mainSCREEN offScr(&iron, &disp, &encoder, &simpleBuzzer, &ironCfg);
tipSCREEN selScr(&iron, &disp, &encoder, &ironCfg);
workSCREEN wrkScr(&iron, &disp, &encoder, &simpleBuzzer, &ironCfg);
errorSCREEN errScr(&iron, &disp, &simpleBuzzer);
powerSCREEN pwrScr(&iron, &disp, &encoder, &ironCfg);
configSCREEN cfgScr(&iron, &disp, &encoder, &ironCfg, &simpleBuzzer);
calibSCREEN tipScr(&iron, &disp, &encoder, &ironCfg, &simpleBuzzer);
actSCREEN actScr(&iron, &disp, &encoder, &ironCfg);
//tuneSCREEN tuneScr(&iron, &disp, &encoder, &simpleBuzzer);
tuneSCREEN tuneScr(&iron, &disp, &encoder, &simpleBuzzer, &ironCfg);
//pidSCREEN pidScr(&iron, &encoder);
SCREEN *pCurrentScreen = &offScr;
//SCREEN *pCurrentScreen = &pidScr;
* The timer1 overflow interrupt handler.
* Activates the procedure for IRON current check or for IRON temperature check
* Interrupt routine on Timer1 overflow, @31250 Hz, 32 microseconds is a timer period
* keepTemp() function takes 353 mks, about 12 ticks of TIMER1;
* We should wait for 33 timer ticks before checking the temperature after iron was powered off
const uint32_t period_ticks = (31250 * temp_check_period)/1000-33-12;
ISR(TIMER1_OVF_vect) {
if (iron_off) { // The IRON is switched off, we need to check the temperature
if (++tmr1_count >= 33) { // about 1 millisecond
TIMSK1 &= ~_BV(TOIE1); // disable the overflow interrupts
iron.keepTemp(); // Check the temp. If on, keep the temperature
tmr1_count = 0;
iron_off = false;
TIMSK1 |= _BV(TOIE1); // enable the the overflow interrupts
} else { // The IRON is on, check the current and switch-off the IRON
if (++tmr1_count >= period_ticks) {
tmr1_count = 0;
OCR1B = 0; // Switch-off the power to check the temperature
iron_off = true;
TIMSK1 |= _BV(TOIE1); // enable the overflow interrupts
// the setup routine runs once when you press reset:
// Serial.begin(115200);
disp.init();
// Load configuration parameters
ironCfg.init();
iron.init();
uint16_t temp = ironCfg.tempPresetHuman();
int16_t ambient = 0;
for (uint8_t i = 0; i < 10; ++i) {
int16_t amb = iron.ambientTemp();
if (amb == ambient) break;
ambient = amb;
temp = ironCfg.humanToTemp(temp, ambient);
iron.setTemp(temp);
simpleBuzzer.activate(ironCfg.isBuzzer());
// Initialize rotary encoder
encoder.init();
attachInterrupt(digitalPinToInterrupt(R_MAIN_PIN), rotEncChange, CHANGE);
// Initialize SCREEN hierarchy
offScr.next = &wrkScr;
offScr.nextL = &cfgScr;
offScr.no_iron = &selScr;
wrkScr.next = &offScr;
wrkScr.nextL = &pwrScr;
wrkScr.main = &offScr;
errScr.next = &offScr;
errScr.nextL = &offScr;
pwrScr.nextL = &wrkScr;
pwrScr.no_iron = &errScr;
cfgScr.next = &tuneScr;
cfgScr.nextL = &offScr;
cfgScr.main = &offScr;
cfgScr.calib = &tipScr;
cfgScr.activate = &actScr;
tipScr.nextL = &offScr;
tuneScr.next = &cfgScr;
tuneScr.main = &offScr;
selScr.nextL = &cfgScr;
selScr.no_iron = &offScr;
actScr.main = &offScr;
actScr.nextL = &offScr;
pCurrentScreen->init();
// Encoder interrupt handler
static void rotEncChange(void) {
encoder.encoderIntr();
// The main loop
static int16_t old_pos = encoder.read();
SCREEN* nxt = pCurrentScreen->returnToMain();
if (nxt != pCurrentScreen) { // return to the main screen by timeout
pCurrentScreen = nxt;
int16_t pos = encoder.read();
if (old_pos != pos) {
pCurrentScreen->rotaryValue(pos);
old_pos = pos;
if (pCurrentScreen->isSetup())
pCurrentScreen->resetTimeout();
uint8_t bStatus = encoder.buttonCheck();
switch (bStatus) {
case 2: // int32_t press;
nxt = pCurrentScreen->menu_long();
case 1: // short press
nxt = pCurrentScreen->menu();
case 0: // Not pressed
default:
nxt = pCurrentScreen->show();
if (nxt && pCurrentScreen != nxt) { // Be paranoiac, the returned value must not be null
iron.checkSWStatus();
