Ich habe Probleme mit der T6963 Library in Verbnindung mit der IDE 1.6.4
Der Compiler zeigt folgende Fehlermeldung:
In file included from MS_HomeControl_V43.ino:92:0:
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/T6963.h:109:23: error: 'prog_char' has not been declared
void WriteStringPgm(prog_char * str);
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/T6963.h:131:44: error: 'prog_uchar' has not been declared
void drawPic(unsigned int, unsigned int, prog_uchar *, unsigned int, unsigned int);
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/T6963.h:132:45: error: 'prog_uchar' has not been declared
void drawAnim(unsigned int, unsigned int, prog_uchar**, int, unsigned int, unsigned int);
In file included from MS_HomeControl_V43.ino:93:0:
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/page1.h:23:8: error: 'prog_uchar' does not name a type
extern prog_uchar page1bmp[]; //AVR-GCC, WinAVR
In file included from MS_HomeControl_V43.ino:94:0:
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/page2.h:23:8: error: 'prog_uchar' does not name a type
extern prog_uchar page2bmp[]; //AVR-GCC, WinAVR
In file included from MS_HomeControl_V43.ino:95:0:
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/page3.h:23:8: error: 'prog_uchar' does not name a type
extern prog_uchar page3bmp[]; //AVR-GCC, WinAVR
In file included from MS_HomeControl_V43.ino:96:0:
C:\Program Files (x86)\Arduino\libraries\T6963_Lib/page4.h:23:8: error: 'prog_uchar' does not name a type
extern prog_uchar page4bmp[]; //AVR-GCC, WinAVR
Vielleicht ist es möglich durch eine Änderung im T6963.h File den Fehler zu beheben.
