Ok so all of the hardware work is done, the pins are wired correctly and voltages are set. The problem im having is with the t6963c Library. When I load the example sketch and try to compile it I get errors referring to missing parts of the t6963 Class "t6963 class Has no member 'setpixel'" and tons of other errors of missing things too. Anyone experience this or know what to do to fix it?
Which t6963c library are you using? http://code.google.com/p/arduino-t6963c/downloads/list ?
That library has not been updated for Arduino 1.0 yet. Change "WProgram.h" in T6963.h and T6963.cpp to "Arduino.h". That fixes it.
Yes that is the library im using. The example sketch is the 240x64 example.
I fixed what you suggested in a few spots where that file was referenced and it compiled ok. Thank you so much for your help!
