TA12-100-WITH DISPLAY LCD 16X2 1602
Dear Friends, I have to visualize the current passing through the TA12-10 sensor. Usage, Arduino Genuino Uno, with the I2C connection. There are three sensor pins but only 2 are used, of which S goes to pin A0 or other analog and G goes connected to GND.
I checked the address of the LCD 1602 TYPE and it is as per algorithm 0x27. Now I can not understand where I'm wrong, since the library I use, works perfectly with all types of sensors. Where am I wrong? Thank you
The code
//Baseado no exemplo da biblioteca EmonLib
/*-importacao Necessaria*/
#include <Wire.h>
//Carrega as bibliotecas
#include "EmonLib.h"
/*Declaracao de Constates e Objetos*/
// seta o Endereco do Display LCD  0x27
// Seta os pinos do I2C usado (padrao da biblioteca)
//                    addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0X27, 16,2);  // Set the LCD I2C address
EnergyMonitor emon;
//Tensao da rede AC 110 Volts e na verdade (127 volts)
int tensao = 127;
//desvio medio
double ruido =0.005;
//Pino do sensor
int sensor= 0;
double Irms =0;
double media =0;
void setup()   {
  Serial.begin(9600);  //Serial
// inicializa o lcd de 20 caracters e 4 linhas
lcd.begin(16,2);
//lcd.begin(16,2);
  //Pino, calibracao - Corrente Constante= Ratio/BurdenR. = x.
  emon.current(sensor, 12);
  //descarta os 5 primeiros valores de leitura.
  //(costuma ter muito ruido)
  for(int index =0; index <5; index++){
    media =media+ emon.calcIrms(1480);
    delayMicroseconds(1);
    media =0;
// ------- Um breve blink de backlight (luz de fundo  -------------
    //liga
    lcd.backlight();
    delay(250);
    //desliga
    lcd.noBacklight();
    delay(250);
    //finaliza com a luz de fundo ligada
    lcd.backlight();
       Irms =0;
       media =0;
        //Calcula a media da corrente fazendo 10 amostragem
        for(int index =0; index <100; index++){
        //ruido do sensor (desvio)
        Irms = media /100;
        Irms = Irms - ruido;
        //Trata possiveis desvios de ruido
        if(Irms < ruido || Irms < 0){
            Irms =0;
        lcd.clear();
        //Reposiciona o cursor na linha 0 e coluna 0
        lcd.setCursor(0,0);
        //Escreve
        //Mostra o valor da corrente
        Serial.print("Corrente : ");
        // Irms
        Serial.print(Irms, 3);
        Serial.print(" A ");
        lcd.print("Corrente :");
        lcd.print(Irms, 3);
        lcd.print("A");
        //Pula para segunda linha na posicao 0
        lcd.setCursor(0,2);
       //Escreve
        //Calcula e mostra o valor da potencia
        Serial.print(" Potencia (Consumo) : ");
        Serial.print(Irms * tensao);
        Serial.println(" Watts ");
        lcd.print("Potencia (Consumo) : ");
        lcd.setCursor(0,3);
        lcd.print(Irms * tensao);
        lcd.print(" Watts ");
        //Aguarda 8 segundos para reiniciar o loop
        delay(2000);
