Hi
I just found this topic and it has almost everything I need.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1287600441/0
Here is the code
#include <Flash.h>
const int rpmSteps = 6; // Number of entries for rpm
const long rpmFactor = 1000; // Difference between entries for rpm
const int rpmMin = 2000; // Value of the first entry for rpm
const int rpmMax = rpmMin + (rpmSteps - 1) * rpmFactor; // Value of the last entry for rpm
const int tpsSteps = 7; // Number of entries for tps
const long tpsFactor = 10; // Difference between entries for tps
const int tpsMin = 0; // Value of the first entry for tps
const int tpsMax = tpsMin + (tpsSteps - 1) * tpsFactor; // Value of the last entry for tps
FLASH_TABLE(int, font_table, rpmSteps /* width of table */,
{100, 10, 0, 0, 0, 0}, // 100 %
{100, 60, 40, 30, 20, 10}, // 90 %
{100, 80, 70, 50, 30, 30}, // 80 %
{100, 90, 80, 80, 70, 60}, // 70 %
{100, 100, 90, 80, 80, 70}, // 60 %
{100, 100, 100, 90, 80, 80}, // 50 %
{100, 100, 100, 100, 100, 100}); // 40 %
void setup(void) {
Serial.println (magicnumber(6700, 17));
Serial.println (magicnumber(3100, 33));
delay (4000);
int magicnumber (int rpm, int tps) {
int rpmIL, rpmIH;
int tpsIL, tpsIH;
long rpmOffset, tpsOffset;
// Find right table indices to work on
if (rpm < rpmMin) {
rpmIL = rpmIH = 0;
rpmOffset = 0;
else if (rpm > rpmMax) {
rpmIL = rpmIH = rpmSteps - 1;
rpmOffset = 0;
else {
rpmIL = (rpm - rpmMin) / rpmFactor;
rpmIH = rpmIL + 1;
rpmOffset = (rpm - rpmMin) % rpmFactor;
if (tps < tpsMin) {
tpsIL = tpsIH = 0;
tpsOffset = 0;
else if (tps > tpsMax) {
tpsIL = tpsIH = tpsSteps - 1;
tpsOffset = 0;
else {
tpsIL = (tps - tpsMin) / tpsFactor;
tpsIH = tpsIL + 1;
tpsOffset = (tps - tpsMin) % tpsFactor;
// Interpolate the values
long fLL = font_table[tpsIL][rpmIL];
delayMicroseconds (0);
long fLH = font_table[tpsIL][rpmIH];
long fHL = font_table[tpsIH][rpmIL];
long fHH = font_table[tpsIH][rpmIH];
return (((fLL * (rpmFactor - rpmOffset)
+ fLH * rpmOffset) * (tpsFactor - tpsOffset))
+ ((fHL * (rpmFactor - rpmOffset)
+ fHH * rpmOffset) * tpsOffset))
/ (rpmFactor * tpsFactor);
I'am wondering one thing. The code says that digital pin 7 is input for tps (throttle position sensor, 0-5v output). I would say that we should use analog input because signal is 0-5v. Also I would like to use digital output as PWM output. Now it only prints the value to serial monitor.
To do
- input pin change
- pwm output, frequency somewhere between 40-100 Hz
- table from % to 0-255
EDIT:
-input pin change done
const int tpsSteps = A0;
