Tablet repair (FPC-replacement)
Hi i just wanted to ask someone more experienced than My or better request to look with an expert eye . My issue concerns conector visible on uploaded jpg's .is that worth a while of replacing it or is it too much.damage already (to much mess all around that pcb board)
Details
-it is on motherboard connector that is a root for flex cable wiring guided to LCD/LCM Panel itself .
Thank You For Bothering of out My Quesion .
Best of Luck .
You can try, but you'll need professional equipment. But if you go to a multimedia shop, I think they would repair it.
If you have a heat gun to solder (I forgot the real name), it shouldn't be a problem.
Without knowing your skill set or the tools you have available, it’s difficult to provide a definitive answer.
The way I approach situations like this is to first assess whether I feel confident in my ability to repair it, and then consider the risk of causing further damage. If I can afford to replace it in case things go wrong, I’ll attempt the repair. Otherwise, I’d recommend having it professionally repaired or simply replacing it.
Oh Thank You . I Have Already My Answer. And Iam Grateful and suprized that You Gave Me it so Fast. .
Generally I have following things : solder station with both iron and gun , flux , fluxwire, heat-tape, and tweezers.
I Got some experience , not much but with tablet at stake it schould be sufficient . :sparkling_heart: Marry Christmas ! :four_leaf_clover:
I'd give it a shot.
Good Luck and maybe by the new year it will be working. Merry Christmas and a Happy New Year!
