I have broken up my code into four Tabs. Each section of code works interdependently, but I can't seem to reference sections of codes with in other Tabs (i.e GOSUB routines in simple speak).
void Setup and void Loop can only be used once, so I have used alternatives like void LCDsetup1() and void LCDloop2() in other Tabs. Is this the correct way to call up a particular function with in the main function?
Any sample code that uses Tabs that I could review? :-[
You will need to declare the shared functions. Typically, this is done with header files but they are not required.
Let's say you have a function in one of your tabs...
void LCDsetup( void )
// Prepare the LCD display
That you want to call from setup in your Sketch. Your Sketch might look something like this...
void LCDsetup( void );
void setup( void )
// Call LCDsetup in the other tab
LCDsetup();
void loop( void )
Does that help?
Thanks for the reply.
Do I need to include th relevant "include" statements a "int" declarations in the appropriate TAB, or can they be included in one main TAB?
i.e. if I have two TABS - (TAB A and TAB B), can I declare all of the int declarations in TAB A, even though though TAB B has the appropriate code :-[instructions?
That may not make sense....but
Best thing to do is experiment...
