Hello, I am new to arduino so i am relying on what has been done and using my ability to copy and paste. I am trying to measure rotational speed with a inductive prox probe if5793 and plot it versus time in excel. The speed I am testing ranges from 15-1000 rpm. I have used the code from jurs here.
I made a few simple modifications, like sampling every 1 second, and printing current time to the serial monitor. However, i am getting some aliasing every 12-15 seconds or so, the rpm reading will return -1, or a value that is slightly higher than the previous 15 measured values. Here is my code. Any advice would be appreciated! Thank you.
#define TENMINUTES (1000L) // ten minutes are 600000 milliseconds #define REEDPIN 2
volatile int reedCount_ISR;
long int mytime = 0;
long int oldtime = 0;
long int diftime =0;
long int rpm =0;
void reedSwitch_ISR()
reedCount_ISR++;
// setup whatever your sensors will need
pinMode(REEDPIN,INPUT_PULLUP);
attachInterrupt(0,reedSwitch_ISR, FALLING);
Measure 'diftime' in milliseconds instead of seconds. Then you will have values around 1000 (998 to 1002, for example) instead of numbers around 1 (0, 1, or 2) to divide by.
Note: You should clear reedCount_ISR while interrupts are still disabled.
const unsigned long ONE_SECOND = 1000UL;
const byte REEDPIN = 2;
volatile unsigned reedCount_ISR;
unsigned long mytime, oldtime, diftime = 0;
unsigned long lastReadingTime;
long int rpm = 0;
reedCount_ISR++;
pinMode(REEDPIN, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(REEDPIN), reedSwitch_ISR, FALLING);
mytime = millis();
if (mytime - lastReadingTime >= ONE_SECOND)
lastReadingTime += ONE_SECOND; // remember the time
// Read and write volatile variables only with interrupts disabled.
noInterrupts();
unsigned reedCount = reedCount_ISR;
reedCount_ISR = 0;
interrupts();
diftime = mytime - oldtime;
oldtime = mytime;
rpm = 60000UL * reedCount / diftime;
Serial.print(mytime/1000);
Serial.print("\t");
Serial.println(reedCount);
Serial.print("\t");
Serial.println(rpm);
Thank you kind sir! this is working a little better now. at slow speed 120rpm and below, the reading is good. however 120-2000 there is always a value that is off. I think it has something to do with the sampling rate of the interrupt and the rpm. I know serial.print is not reccomended for interups - perhaps this is causing the issue? i've tried chaining the sapling range and using micros with no succus.
