I am building an arduino based tachometer for my car. I can get an rpm signal off the crank shaft positioning sensor or the trigger wire to the ignition coil. Either way , I will need to convert a 12v signal to 5v so it can be read by the arduino. I know there are a number of different ways to do this using resisters , diodes and zener diodes. I'm just not sure what is the best way to do it , for what I'm trying to do. Any help would be appreciated, thanks.
I'd use a voltage divider (two resistors) and a pair of diodes. The "12V" in a car can be somewhat unpredictable and it's best to play it safe.
A pair of resistors will knock-down the voltage by a known percentage/ratio but it won't protect the Arduino from an unexpected high voltage.
A diode requires one resistor anyway (to protect the diode from excess current.
A 2nd diode can protect the Arduino from negative spikes.
Thanks for your reply. I think I understand what your telling me to do. Is this correct(see link)? Thanks
https://drive.google.com/file/d/0B-7DDOBC2ZbPTGNmeGNxNHppeUE/view?usp=sharing
If you're grabbing the coil negative, the only safe way to go is with an opto-isolator. there are quite a few examples around of using one of these to 'convert' 12v to a 5v signal.
If you're going from the CAS, you need to know what kind of sensor it is. A hall or optical sensor is relatively simple to get to 5v, usually with just a pullup resistor. If it's a VR sensor though, you're going to need a VR conditioner, don't try to fudge it or you'll fry your input.
The opto-isolator off the coil negative trigger method seems to be the best solution. Thanks for your suggestion. I don't have any opto-isolators to hand at the moment so it will be a week or so before I can test it.
can't you get this data and more from the obdII port?
Take a look at the circuit posted here if you want a nice reliable setup: Trigger Signal Conditioning - Page 3 - Speeduino
This has been designed to work with (amongst other things) a coil negative feed which is in a fairly noisy environment.
The part labelled IC1 down the bottom is just a connector, if you wired in the following way, it should work:
Pin 1 - Coil Negative
Pin 2 - +12v
Pin 3 - N/A
Pin 4 - N/A
Pin 5 - 5v at arduino
Pin 6 - Ground at arduino
Pin 7 - N/A
Pin 8 - Arduino input
Note that R2 should be a fairly strong resistor, 2W if possible.
doughboy - I bought an obd2 adpater for arduino but i couldn't get it to work
noisymime - Thanks that is perfect , I'll order all the parts today. It dosent say what kind of capacitor c1,c2,c3,c4 should be? Does it not matter? Also is there a name for this particular type of circuit as I would like to learn exactly how it works, Thanks
I have made a board specifically for grabbing tach signal from coil negative. Works really well. Its about 20x20mm size and a few cheap components. let me know if you want one of these. I can supply you with a compatible code snippet as well.
Tobbera - Thanks for the offer. I'll try to make one myself first and if I fail I'll let you know.
conors891:
C1 and C3 are quite small, 0.001uF or so
C2 and C4 are standard 0.22uF ones.
Standard ceramic capacitors will be fine.
This is still just a basic opto-isolator circuit with some added protection (resistor and diode) and decoupling (The caps). There's not really a name for it at all.
Thanks, I have ordered all the parts and I shall get building/testing when they arrive.
I have built the circuit on a breadboard. I just need to type up a quick testing sketch. Do the capacitors need to be polarized? I am using non polarized capacitors. Thanks
I have tested this on my car and it seems to be working. I thought you would have to multiply the frequency by 60 to get the resulting rpm but it seems to be 24. Not sure why this is but once it's a constant for all values it dosent matter. Thanks for all you help
Tobbera, How much you asking for that board?
Hi. You can have it shipped for USD $40.
Regards
Tobias
