Tachometer (RPM for a motor) with 28 BYJ 48
Hello guys,
I wanted to realize a tachometer for my bike. I have a 5V signal input, and with this signal I want to drive a stepper motor to indicate me the RPM of my motor.
I want the motor to move around 270° for the 5V input.
For that I bought a 28BYJ-48 5v (arround 4096 steps for the output) stepper motor which I drive with a ULN2003.
My configuration is like this :
Arduino Pin 8 : Motor pin Blue
Arduino Pin 9 : Motor pin Pink
Arduino Pin 10 : Motor pin Yellow
Arduino Pin 11 : Motor pin Orange
Many problems come to me.
I tried different king of librairies : Stepper.h, CustomStepper.h and AccellStepper.h but I have problem with every one.
To begin this is a test code with stepper.h library
#include <Stepper.h>
const int stepsPerRevolution = 64; //Input step
//Motor definition
Stepper myStepper(stepsPerRevolution, 8,10,9,11);
 //Spped of the motor
 myStepper.setSpeed(60);
 //4 moves of 90°
 for (int i = 0; i<=3; i++)
 myStepper.step(-512);
 delay(2000);
 //3 moves of 120°
 for (int i = 0; i<=2; i++)
 myStepper.step(682);
 delay(2000);
Problem with that : My motor turns only in one side. The 90° movement work well but for the other side the motor vibrates but doesn’t move. I tried to move the pin (maybe wrong connection for the coils) but nothing change.
After that I tried the same simple example with the CustomStepper.h library
#include <CustomStepper.h>
//Define motor
CustomStepper stepper(8,9,10,11, (byte[]){8, B1000, B1100, B0100, B0110, B0010, B0011, B0001, B1001}, 4075.7728395, 12, CW);
  //Define a speed for motor
  stepper.setRPM(14);
  //Number of steps to the motor
  stepper.setSPR(4075.7728395);
   if (stepper.isDone())
     //Intervalo entre acionamentos
     delay(2000);
    // Clockwise direction
     stepper.setDirection(CW);
     //Rotation angle
     stepper.rotateDegrees(720.0);
    stepper.run();
     delay(2000);
    // CounterClockwise direction
     stepper.setDirection(CCW);
     //Rotation angle
     stepper.rotateDegrees(360.0);
    stepper.run();
I remark that in clockwise direction, we need to double the angle rotation to have the angle that we need : If we want 90° we need to put 180°. In CounterClockWise direction it’s fine. The fluidity of the movement is also better in CCW direction.
When I load this code, there is a random functionning. Sequence like that.
  • 1 turn CW
  • 1 turn CCW
  • 1 turn CCW
  • 2 turn CW
  • 1 turn CCW
  • 1 turn CW
  • ETC …
I wanted to manage simple application but I had a lot of trouble with this stepper. Does anyone as solution to just pilot this motor to position correctly.
Thanks a lot
You have to connect the wires correctly - a stepper has two coils, A and B, and you need to sequence them like A+, B+, A-, B- (or equivalent). With unipolar motors like yours there's no easy way to work out which of the 4 wires corresponds to which winding, and there are 24 ways to connect the wires, 16 of which will not work.
Hi, How are you providing power for the stepper. If you are using the 5V from the controller it will probably be causing the arduino to reset.
What arduino are you using?
Tom.... :)
Hi.
As you can see from the replies above, tell all about your setup when asking questions. Showing a diagram of how things are wired will also help (that is how you did wire it, not how you planned to wire it, pointing to some instructions found online).
Do you understand how the stepper motor works, and how it is controlled ? Do you understand the possible settings of the stepper libraries in those sketches ?
It's no huge problem if you don't understand these things yet, but that would be the first things to solve. It seems to me like you might be missing steps. This could be caused by steps that are taken too fast.
You do know that that stepper has a gear attached, and that the number of steps per revolution you see is different from that of the actual motor. Also tell the library the correct properties of your motor, i wonder if this is correct:
//Motor definition
Hello guys,
TomGeorge: Hi, How are you providing power for the stepper. If you are using the 5V from the controller it will probably be causing the arduino to reset.
Tom.... :)
I'm providing power from an external power supply.
My arduino board is the UNO SMD model.
Concerning the declaration. I know that my motor has a gear attached. The 64 for steps I declared concern the steps in entry. That why I put 64 instead of 4096 (64 steps * 64 (gear ratio)).
I put the sequence 8,10,9,11 to feed the coils with the sequence A+ / B+ / A- / B-
That's why I don't understand why it doesn't work properly.
Can you please post a picture of your project?
Tom..... :)
Actually I just found a problem. I opened the motor and one of the coil wire was cut. So I resoldered the wire and things work better.
The two library I was talking works. Now I will try to make some modifications and try the AccellStepper library to have a better fluidity.
Hello guys !
I worked on my project during the weekend and I still have some trouble to fix.
There is my code :
// Pinout motor definition
CustomStepper stepper(8,10,9,11, (byte[]){8, B1000, B1100, B0100, B0110, B0010, B0011, B0001, B1001}, 4075.7728395, 12, CW);
int value = 0;
int value_degree = 0;
int degree_rotation = 0;
int previous = 0;
int Signal = A0;
  pinMode (Signal,INPUT);                    // Analog Input signal (0 to 5V)
  stepper.setRPM(14);                        // Motor speed
  stepper.setSPR(4075.7728395);              // Number of steps for a revolution (360°)
  value = analogRead(Signal);               // Read analog value : return value between 0 and 1024
  value_degree = value*360.0L/1024L;        // Convert the value in angle. Depends of the angle max we want
    if((value_degree > previous+2))        // Compare to previous+2 to avoid very little change
      degree_rotation = value_degree-previous;
      stepper.rotateDegrees(degree_rotation);
    else if(value_degree < previous-2)
      degree_rotation = previous-value_degree;
  stepper.run();
  previous = value_degree;
The major problem I had is the speed update. In this example I put a delay of 1s to update the analog input. But if I have big change on my analog input (for example 1v to 5V, so 4V gap) the motor will not move 288 degree but less.
I don’t know how to fix it. Does anyone has an idea?
Thansk
