hey guys im trying to make a lcd tachtometer and im using this as example :
only thing that is diffrent is the arduino i use (arduino ragepip) and a diffrent sensor. the problem i have right now is that the lcd is only showing some blocks and no numbers or words i hopethat somone is able to help me.
p.s sorry for the bad english
here is the code im using
#include<LiquidCrystal.h>
LiquidCrystal lcd(12,11,6,5,4,3);
int pwm=9;
int pot=A0;
float value=0;
int percent;
float rev=0;
int rpm;
int oldtime=0;
int time;
void isr() //interrupt service routine
rev++;
lcd.begin(16,2); //initialize LCD
attachInterrupt(0,isr,RISING); //attaching the interrupt
detachInterrupt(0); //detaches the interrupt
time=millis()-oldtime; //finds the time
rpm=(rev/time)*60000; //calculates rpm
oldtime=millis(); //saves the current time
rev=0;
value=analogRead(pot); //reads the speed control POT
value=value/4;
analogWrite(pwm,value); //sets the desired speed
percent=(value/255)*100; //finds the duty cycle %
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
lcd.print(“TACHOMETER”);
lcd.print(rpm);
lcd.print(" RPM");
lcd.print(" “);
lcd.print(percent);
lcd.print(”%");
