I’m using the Moving Average Library to take the average of readings from a sensor (an air pressure sensor), and display on the monitor if there is a “spike” of more than 2 from the average. But it’s not working -
the code runs, prints the initial reading to the monitor, but nothing more happens. I have tested and the sensor is working fine - what am I doing wrong?
I am trying to record a reading when the reading from the air
pressure sensor jumps suddenly. Pressure Sensor is a MPX5500DP
I am using the movingAvg library to simplify the maths a bit
#include <movingAvg.h> // https://github.com/JChristensen/movingAvg
const uint8_t airSensor(A0); // connect pressure sensor from A0 pin to ground
movingAvg airAvg(10); // define the moving average object
/* setup the average, pullup the air sensor,
* begin the serial monitor and show an initial
* reading so we knnow it is working
airAvg.begin();
pinMode(airSensor, INPUT_PULLUP);
Serial.println("initial reading");
int pc = analogRead(airSensor); // read the sensor
Serial.println(pc); // print it to serial monitor
/* Each loop should comapare the reading against
* the moving average, and if it is greater than
* the specific amount, print this to the monitor
int avg = airAvg.reading(pc); // calculate the moving average
int avgPlus2 = avg + 2; // to simplify conditional below
// if the reading is greater than the average, print it
if (pc > avgPlus2)
Serial.print("reading - ");
Serial.print(pc); // print the individual reading
Serial.print(", avg - ");
Serial.println(avg); // print the moving average
When debugging problems with conditional statements it is often useful to print the values being tested to see whether they look reasonable. Have you tried that ?
cheers for the quick response - I've removed the IF statement so it just runs through what the sensor value is, and what the running average is, and I can trigger the sensor and it all looks fine. I don't understand why the IF statement doesn't seem to be working!
As suggested in reply #1, please add some Serial prints before the conditional statement to verify that the values are what you think. What do the print outs show?
airAvg.begin();
Serial.print(avg); // print the moving average
Serial.print(", avg +2 - ");
Serial.println(avgPlus2);
if (pc > avgPlus2)
