Taking multiple snapshots and storing into SD using TTL serial Camera
I am working on a home automation project. I am trying to capture snapshots using the TTL camera. The snapshots are event triggered. For ex:
When event 1 occurs, take snapshot, store in SD card When event 2 occurs, take snapshot, store in SD card
The code works fine for event 1. But for latter events, I get an error stating that "Card read failed, or not present".The first highlighted portion runs smoothly the first time around, and when the 2nd event occurs, even though the camera is still running, the SD card fails. Not sure why this is. And this error repeats until I reset the whole thing. Could someone help me figure out why this happens?
I will attach my code here:
#include
#include
#include
#define FORCE_THRESHOLD 400
#define ONBOARD_LED 13
#define FORCE_SENSOR 0
#define chipSelect 10
// Set the XBee serial transmit/receive digital pins
SoftwareSerial XBeeSerial = SoftwareSerial(2, 3);
SoftwareSerial cameraconnection = SoftwareSerial(4, 5);
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
int force_value = 0;
byte force_state = 0;
// for serial window debugging
// for XBee transmission
XBeeSerial.begin(9600);
// set pin for onboard led
pinMode(ONBOARD_LED, OUTPUT);
void SendDeliveryAlert(int force_value, int force_state)
digitalWrite(ONBOARD_LED, force_state ? HIGH : LOW);
if (force_state)
Serial.print("Package delivered, force_value=");
Serial.println(force_value);
XBeeSerial.println("Delivery");
[color=red][color=red][b][glow=yellow,2,300]Serial.println("VC0706 Camera snapshot");
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect))
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  // Try to locate the camera
  if (cam.begin())
    Serial.println("Camera Found:");
    Serial.println("No camera found?");
    return;
  Serial.println("Snap in 3 secs...");
  if (! cam.takePicture())
    Serial.println("Failed to snap!");
    Serial.println("Picture taken!");
 [/glow][/b][/color][/color]
  // Create an image with the name IMAGExx.JPG
  char filename[13];
  strcpy(filename, "IMAGE00.JPG");
  for (int i = 0; i < 100; i++)
    filename[5] = '0' + i/10;
    filename[6] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(filename))
  // Open the file for writing
  File imgFile = SD.open(filename, FILE_WRITE);
  // Get the size of the image (frame) taken
  uint16_t jpglen = cam.frameLength();
  int32_t time = millis();
  pinMode(8, OUTPUT);
  // Read all the data up to # bytes!
  byte wCount = 0; // For counting # of writes
  while (jpglen > 0) {
    // read 32 bytes at a time;
    uint8_t *buffer;
    uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
    buffer = cam.readPicture(bytesToRead);
    imgFile.write(buffer, bytesToRead);
    if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
      Serial.print('.');
      wCount = 0;
    //Serial.print("Read ");  Serial.print(bytesToRead, DEC); Serial.println(" bytes");
    jpglen -= bytesToRead;
  imgFile.close();
  time = millis() - time;
  Serial.println("done!");
Serial.print("Package removed, force_value=");
XBeeSerial.println("Empty");
[color=yellow]Serial.println("VC0706 Camera snapshot");
delay(2000);
    return;
  if (cam.begin())
    return;
  }[/color]
  Serial.println("Snap in 1 secs...");
  char filename[13];
  pinMode(8, OUTPUT);
    uint8_t *buffer;
      Serial.print('.');
      wCount = 0;
  imgFile.close();
// wait a second each loop iteration
// poll FLEX_SENSOR voltage
force_value = analogRead(FORCE_SENSOR);
switch (force_state)
case 0: // check if package was delivered
if (force_value >= FORCE_THRESHOLD)
force_state = 1;
SendDeliveryAlert(force_value, force_state);
case 1: // check if package was removed
if (force_value < FORCE_THRESHOLD)
force_state = 0;
bavinay: I get an error stating that "Card read failed, or not present".
Judging by the source, I suspect the actual error is actually "Card failed, or not present". You are initialising the SD interface each time you try to save an image, which is probably not required; since your code doesn't try to do anything after that error, we have no idea whether the rest of your code works when called repeatedly. It might do.
I suggest you put this sketch aside for a moment and write a test sketch that just opens and writes to a sequence of files on the SD so that you understand how to use the SD card; once you have that working, you can go back to your original sketch and implement the solution there.
Perhaps you could try calling SD.begin(chipSelect) just once in setup().
^^^Thank You so much. The code works perfectly now. Appreciate your help
Does anyone know a way to accomplish this directly over USB without the SD card reader?
What do you want to do over USB? Read the snapshot from the camera?
