Talk between Arduino and PC wirelessly? Questions.
I want to have Arduino connected to a Nordic transceiver/antenna:
I have Transceiver nRF24L01+ Module with Chip Antenna from SparkFan
Then I want to have the data generated on Arduino board to be send to PC wirelessly using Nordic trasceiver/antenna.
How can I do this? Do I need to have another board to receive those packages (also connect with Nordic t/a and then connected by USB to PC)? Or can I avoid this and somehow receive the data sent by Nordic on PC?
YES
How can I check if Nordic is configured correctly on one Arduino without having another board (I didn't buy it yet, just have one Nordic transceiver)?
Here is a PIC program of mine which checks the SPI comms between the MCU and the Nordic chip:
** test.c
** SPI test program for PIC18F4520 and nRF24L01 or nRF24L01+
** Checks SPI comms between PIC and wireless chip
** RA0      LED (output)
** RA1      PB (input)
#include <p18f4520.h>
#include <spi.h>
//function prototypes
unsigned char spi_Send_Read(unsigned char);
void dly(void);
// Defines
#define SPI_SCK            LATCbits.LATC3            // Clock pin, PORTC pin 3
#define SPI_SO            LATCbits.LATC5            // Serial output pin, PORTC pin 5
#define SPI_SI            PORTCbits.RC4            // Serial input pin, PORTC pin 4
#define SPI_CSN            LATCbits.LATC2            // CSN output pin, PORTC pin 2
#define SPI_CE            LATCbits.LATC1            // CE output pin, PORTC pin 1
#define SPI_IRQ            PORTBbits.RB0            // IRQ input pin, PORTB pin 0
#define SPI_SCALE      4                          // postscaling of signal
#define LED                  LATAbits.LATA0
#define PB                  PORTAbits.RA1
// Macros
#define nop() _asm nop _endasm
void main(void)
      unsigned char status = 0;
      unsigned char data[5];
      int i;
      // run internal oscillator at 8 MHz
      OSCCON = OSCCON | 0b01110000;
      while (!OSCCONbits.IOFS)      // wait for IOFS to go high
      OpenSPI(SPI_FOSC_16, MODE_00, SMPMID); //open SPI1
      PORTA = 0x00;
      ADCON1 = 0x0F;            // set up PORTA to be digital I/Os
      TRISA = 0x02;            // PORTA<7.2,0> outputs PORTA<1> input
      TRISCbits.TRISC3 = 0;      // SDO output
      TRISCbits.TRISC5 = 0;   // SCK output
      TRISCbits.TRISC2 = 0;      // CSN output
      TRISCbits.TRISC1 = 0;      // CE output
      SPI_CSN = 1;            // CSN high
      SPI_SCK = 0;            // SCK low
      SPI_CE      = 0;            // CE low
      nop();
      //write TX_ADDRESS register
      SPI_CSN = 0;                  //CSN low
      spi_Send_Read(0x30);
      spi_Send_Read(0x11);
      spi_Send_Read(0x22);
      spi_Send_Read(0x33);
      spi_Send_Read(0x44);
      spi_Send_Read(0x55);
      SPI_CSN = 1;                  //CSN high
      //read TX_ADDRESS register
      //Check that values are correct using the MPLAB debugger
      status = spi_Send_Read(0x10);
      data[0] = spi_Send_Read(0x00);      // 0x11
      data[1] = spi_Send_Read(0x00);      // 0x22
      data[2] = spi_Send_Read(0x00);      // 0x33
      data[3] = spi_Send_Read(0x00);      // 0x44
      data[4] = spi_Send_Read(0x00);      // 0x55
      while (1)
unsigned char spi_Send_Read(unsigned char byte)
      SSPBUF = byte;
      while(!DataRdySPI())
      return SSPBUF;
It uses the Microchip SPI library.
The code should work on the Arduino with a few changes. You don't have a debugger so you will have to send the results back to the PC via the serial monitor.
Thank you.
What can I use to talk to wifi on PC directly? Can Xbee do this?
The cheapest method of talking to an arduino wirelessly is with bluetooth using this bluetooth shield:
http://iteadstudio.com/store/index.php?main_page=product_info&cPath=18&products_id=179
I haven't actually used this shield, but it seems like it should work. You may need a bluetooth dongle on your PC.
Most other methods require two arduinos, or two xbees, or an expensive wifi shield.
If there is a less expensive method, I'd like to hear about it.
-transfinite
A WiFi shield.
eg: WiShield 2.0
