Hey i'm new on the forum and i have a problem with the talkie library. I control it with a IR Remote Control, but after i trigger the Command, nothing works anymore. I can't trigger other commands or the same again and i don't know why. I link the code below and sorry for my bad english.
#include "Talkie.h"
#include "Vocab_US_TI99.h"
#include "Stepper.h"
#include "IRremote.h"
/*----- Variablen, Pins -----*/
#define STEPS 32 // Number of steps per revolution of Internal shaft
int Steps2Take; // 2048 = 1 Umdrehung
int receiver = 12; // Signal Pin von Empfänger auf Pin 6
/*-----( Objekte deklarieren )-----*/
// Setup of proper sequencing for Motor Driver Pins
// In1, In2, In3, In4 in the sequence 1-3-2-4
Stepper links_stepper(STEPS, 0, 2, 1, 3);
Stepper rechts_stepper(STEPS, 4, 6, 5, 7);
Stepper zunge_stepper(STEPS, 8, 13, 9, 10);
IRrecv irrecv(receiver); // Kreiert instanz von 'irrecv'
decode_results results; // Kreiert instanz von 'decode_results'
irrecv.enableIRIn(); // Startet Empfänger
void reden() {
Talkie voice;
voice.say(spt_DO);
voice.say(spt_YOU);
voice.say(spt_HAVE);
voice.say(spt_THINGS);
voice.say(spt_YOU);
voice.say(spt_WANT);
voice.say(spt_TO);
voice.say(spt_GIVE);
voice.say(spt_ME);
void fahrenlinks() {
links_stepper.setSpeed(500); //Max 500
Steps2Take = 50 ;
links_stepper.step(Steps2Take);
void fahrenrechts() {
rechts_stepper.setSpeed(500);
Steps2Take = 50;
rechts_stepper.step(Steps2Take);
void fahrengerade() {
Steps2Take = 1;
int timer;
for(timer = 0; timer <= 200; timer++) {
Steps2Take = 1;
void zunge() {
zunge_stepper.setSpeed(500);
Steps2Take = 1024;
zunge_stepper.step(Steps2Take);
void fahrenlinksreset() {
Steps2Take = -50;
void fahrenrechtsreset() {
Steps2Take = -15;
void fahrengeradereset() {
int timer;
Steps2Take = -1;
void zungereset() {
Steps2Take = -1024;
if (irrecv.decode(&results)) // checkt ob signal
switch(results.value)
case 0xFF22DD: // dreht sich links
fahrenlinks();
case 0xFFC23D: // dreht sich rechts
fahrenrechts();
case 0xFF629D: //fährt geradeaus
fahrengerade();
case 0xFFE01F: // stopt links drehen
fahrenlinksreset();
case 0xFF906F: // stop rechts drehen
fahrenrechtsreset();
case 0xFF02FD: // stop fahren
fahrengeradereset();
case 0xFF30CF: //1
zunge();
case 0xFF18E7: //2
zungereset();
case 0xFF7A85: //reden
reden();
irrecv.resume();
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(0, LOW);
digitalWrite(1, LOW);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
}/* --ende von main loop -- */
after i trigger the "reden" function(german for talking) i can't trigger other functions anymore
ps: i changed the timer in the IRremoteInt.h ( in the ir remote library). i don't think that causes problems but i wanted to mention it.
Talkie uses Timer1 and Timer2. IRremote uses a timer. It might not be possible to use both in the same sketch on an Arduino UNO. If you switch to an Arduino MEGA you might be able to configure the IRremote library to use one of the additional timers.
Thats why changed the timer in the IRremote library. At first i got an error message that both use the timer. After i changed it, i didn't g got one anymore so i thought its okay.
#include "Talkie.h"
Talkie voice;
void reden() {
voice.say(spt_DO);
voice.say(spt_YOU);
voice.say(spt_YOU);
voice.say(spt_TO);
voice.say(spt_ME);
Steps2Take = 50 ;
Steps2Take = 50;
Steps2Take = 1;
int timer;
Steps2Take = 1;
void zunge() {
Steps2Take = 1024;
Steps2Take = -50;
Steps2Take = -15;
int timer;
Steps2Take = -1;
void zungereset() {
Steps2Take = -1024;
fahrenlinks();
fahrenrechts();
fahrengerade();
fahrenlinksreset();
case 0xFF30CF: //1
zunge();
case 0xFF18E7: //2
zungereset();
reden();
irrecv.resume();
digitalWrite(8, LOW);
digitalWrite(9, LOW);
digitalWrite(10, LOW);
digitalWrite(11, LOW);
digitalWrite(13, LOW);
I took the Tallkie voice
out of the "reden" funtion and put it after the #include at the very beginning. After i trigger the function "reden" with the remote control, all the other funtions are frozen. Nothing ahppens when i push the buttons. I think it doesnt matter where "Talkie voice" is defined.
Most people should be able to learn how the timers are programmed. Study of the processor data sheet and the timer sections of the source code you intend to use (the libraries) is essential.
Or buy an Arduino with more timers, and but first make sure that all the libraries support it.
Just because you don't get an error does not me there isn't a conflict. I told you that the Talkie library used both Timer1 and Timer2. Which timer did you tell the IRremote library to use?
You can comment out this line in 'talkie.cpp' and it will set up the timers every time you call voice.say():
` setup = 1;'
You will have to find a way to get the IRremote library to re-initialize the timer after you are done talking.
