Thanks for the reply, I have posted the code below: The processing code works as a stand alone program and does display the counter on screen. Arduino doesn't respond when uploading it's own code though.
The notes are from the book (not my own) and was pasted over from www.makezine.com
Proceesing code first - Arduino code follows:
Processing:
// Example 08A: Arduino networked lamp
// parts of the code are inspired
// by a blog post by Tod E. Kurt (todbot.com)
// Copy and paste this example into an empty Processing sketch
import processing.serial.*;
String feed = "http://blog.makezine.com/index.xml";
int interval = 10; // retrieve feed every 60 seconds;
int lastTime; // the last time we fetched the content
int love = 0;
int peace = 0;
int arduino = 0;
int light = 0; // light level measured by the lamp
Serial port;
color c;
String cs;
String buffer = ""; // Accumulates characters coming from Arduino
PFont font;
size(640,480);
frameRate(10); // we don't need fast updates
font = loadFont("HelveticaNeue-Bold-32.vlw");
fill(255);
textFont(font, 32);
// IMPORTANT NOTE:
// The first serial port retrieved by Serial.list()
// should be your Arduino. If not, uncomment the next
// line by deleting the // before it, and re-run the
// sketch to see a list of serial ports. Then, change
// the 0 in between [ and ] to the number of the port
// that your Arduino is connected to.
//println(Serial.list());
String arduinoPort = Serial.list()[0];
port = new Serial(this, arduinoPort, 9600); // connect to Arduino
lastTime = 0;
fetchData();
void draw() {
background( c );
int n = (interval - ((millis()-lastTime)/1000));
// Build a colour based on the 3 values
c = color(peace, love, arduino);
cs = "#" + hex(c,6); // Prepare a string to be sent to Arduino
text("Arduino Networked Lamp", 10,40);
text("Reading feed:", 10, 100);
text(feed, 10, 140);
text("Next update in "+ n + " seconds",10,450);
text("peace" ,10,200);
text(" " + peace, 130, 200);
rect(200,172, peace, 28);
text("love ",10,240);
text(" " + love, 130, 240);
rect(200,212, love, 28);
text("arduino ",10,280);
text(" " + arduino, 130, 280);
rect(200,252, arduino, 28);
// write the colour string to the screen
text("sending", 10, 340);
text(cs, 200,340);
text("light level", 10, 380);
rect(200, 352,light/10.23,28); // this turns 1023 into 100
if (n <= 0) {
fetchData();
lastTime = millis();
port.write(cs); // send data to Arduino
if (port.available() > 0) { // check if there is data waiting
int inByte = port.read(); // read one byte
if (inByte != 10) { // if byte is not newline
buffer = buffer + char(inByte); // just add it to the buffer
else {
// newline reached, let's process the data
if (buffer.length() > 1) { // make sure there is enough data
// chop off the last character, it's a carriage return
// (a carriage return is the character at the end of a
// line of text)
buffer = buffer.substring(0,buffer.length() -1);
// turn the buffer from string into an integer number
light = int(buffer);
// clean the buffer for the next read cycle
buffer = "";
// We're likely falling behind in taking readings
// from Arduino. So let's clear the backlog of
// incoming sensor readings so the next reading is
// up-to-date.
port.clear();
void fetchData() {
// we use these strings to parse the feed
String data;
String chunk;
// zero the counters
love = 0;
peace = 0;
arduino = 0;
try {
URL url = new URL(feed); // An object to represent the URL
// prepare a connection
URLConnection conn = url.openConnection();
conn.connect(); // now connect to the Website
// this is a bit of virtual plumbing as we connect
// the data coming from the connection to a buffered
// reader that reads the data one line at a time.
BufferedReader in = new
BufferedReader(new InputStreamReader(conn.getInputStream()));
// read each line from the feed
while ((data = in.readLine()) != null) {
StringTokenizer st =
new StringTokenizer(data,"\"<>,.()[] ");// break it down
while (st.hasMoreTokens()) {
// each chunk of data is made lowercase
chunk= st.nextToken().toLowerCase() ;
if (chunk.indexOf("love") >= 0 ) // found "love"?
love++; // increment love by 1
if (chunk.indexOf("peace") >= 0) // found "peace"?
peace++; // increment peace by 1
if (chunk.indexOf("arduino") >= 0) // found "arduino"?
arduino++; // increment arduino by 1
// Set 64 to be the maximum number of references we care about.
if (peace > 64) peace = 64;
if (love > 64) love = 64;
if (arduino > 64) arduino = 64;
peace = peace * 4; // multiply by 4 so that the max is 255,
love = love * 4; // which comes in handy when building a
arduino = arduino * 4; // colour that is made of 4 bytes (ARGB)
catch (Exception ex) { // If there was an error, stop the sketch
ex.printStackTrace();
System.out.println("ERROR: "+ex.getMessage());
Arduino Code:
// Example 08B: Arduino Networked Lamp
// Copy and paste this example into an empty Arduino sketch
#define SENSOR 0
#define R_LED 9
#define G_LED 10
#define B_LED 11
#define BUTTON 12
int val = 0; // variable to store the value coming from the sensor
int btn = LOW;
int old_btn = LOW;
int state = 0;
char buffer[7] ;
int pointer = 0;
byte inByte = 0;
byte r = 0;
byte g = 0;
byte b = 0;
Serial.begin(9600); // open the serial port
pinMode(BUTTON, INPUT);
val = analogRead(SENSOR); // read the value from the sensor
Serial.println(val); // print the value to
// the serial port
if (Serial.available() >0) {
// read the incoming byte:
inByte = Serial.read();
// If the marker's found, next 6 characters are the colour
if (inByte == '#') {
while (pointer < 6) { // accumulate 6 chars
buffer[pointer] = Serial.read(); // store in the buffer
pointer++; // move the pointer forward by 1
// now we have the 3 numbers stored as hex numbers
// we need to decode them into 3 bytes r, g and b
r = hex2dec(buffer[1]) + hex2dec(buffer[0]) * 16;
g = hex2dec(buffer[3]) + hex2dec(buffer[2]) * 16;
b = hex2dec(buffer[5]) + hex2dec(buffer[4]) * 16;
pointer = 0; // reset the pointer so we can reuse the buffer
btn = digitalRead(BUTTON); // read input value and store it
// Check if there was a transition
if ((btn == HIGH) && (old_btn == LOW)){
state = 1 - state;
old_btn = btn; // val is now old, let's store it
if (state == 1) { // if the lamp is on
analogWrite(R_LED, r); // turn the leds on
analogWrite(G_LED, g); // at the colour
analogWrite(B_LED, b); // sent by the computer
analogWrite(R_LED, 0); // otherwise turn off
analogWrite(G_LED, 0);
analogWrite(B_LED, 0);
delay(100); // wait 100ms between each send
int hex2dec(byte c) { // converts one HEX character into a number
if (c >= '0' && c <= '9') {
return c - '0';
} else if (c >= 'A' && c <= 'F') {
return c - 'A' + 10;
Thanks for your help
