I'm looking to position two sets of break beams or similar about 1FT apart to calculate the speed of an object going through it. It would need to be up to 3 ft high and have beams about 2CM apart at a minimum - I do not need to know if it hit a upper beam or a lower beam. Using the exact time each beam was broken, I should be able to get a very accurate speed.
What would be the best way to approach this given the height requirement?
Sorry I wasn't clear - I'm trying to see if there is a sensor that is available somewhere that is 'tall'. Otherwise to cover 3ft (~90cm) for an object ~2cm, I would need 45 sensors (x2 for a pair to figure out sped) and was hoping for a less complicated solution.
