Tank beeps and takes an eternity to take a new command
Hello everybody,
I have an Arduino Uno R3 + WiFi shield + L293D Dual H-bridge. That's what I use to control and move a tank. It's working, but not really good: It takes a whole second to close the connection between the Arduino and my laptop, also it beeps when the motors move. Here's my code:
#include <SPI.h>
#include <WiFi.h>
char ssid[] = "MAHNETWORK";     //  your network SSID (name)
char pass[] = MAHPASSWORD";    // your network password
char ssid2[]="Arduino Tank"; // My hotspot on my laptop to be able to control the tank everywhere
char pass2[]="wowmuchawesome"; // The password for that
WiFiServer server(3178);
int pin1=3; //LED for the transistor that controls the forward speed of the left motor
int pin2=5; //LED for the transistor that controls the backward speed of the left motor
int pin3=6; //Same like pin1 but for right
int pin4=9; //Same like pin2 but for right
int led=13;
int netz=0; // which network, 0-none, 1-homenetwork, 2-Arduino Tank (hotspot)
boolean go=false; // So it only starts to add chars when I already got a "G" because of "GET"
long time=0; // for timeout
int run=60001; // I don't want to check the connection all the time
int currenttime=0;
int duration=3000;
String relativex=""; //Left speed
String relativey=""; //Right speed (variable names stayed although I changed the way I control it, ignore)
String currentLine=""; //The current received line
int status = WL_IDLE_STATUS;     // the Wifi radio's status
char floatbuf[8]; //For converting chars in flaot
float speedlinks=0.0; //speed left
float speedrechts=0.0; //speed right
  pinMode(pin1, OUTPUT);
  pinMode(pin2, OUTPUT); // I just see that I forgot to add the other two pins, how the hell could the work?!
  pinMode(pin3, OUTPUT);
  pinMode(pin4, OUTPUT);
  pinMode(led, OUTPUT);
    if (WiFi.status()!=WL_CONNECTED) {
      digitalWrite(led,LOW);
      tryconnect();
      digitalWrite(led,HIGH);
      webserver();
if (millis()-currenttime>duration) {
  currenttime=millis();
  analogWrite(pin1,0);
  analogWrite(pin2,0);
  analogWrite(pin3,0);
  analogWrite(pin4,0);
void tryconnect() {  // works like a charm
  Serial.println("Trying to connect.");
  if (int num=WiFi.scanNetworks()>(-1)) {
    for (int thisNet = 0; thisNet<num; thisNet++) {
      if (WiFi.SSID(thisNet)=="NerdtechCorporation") {
        netz=1;
      else if (WiFi.SSID(thisNet)=="Arduino Tank") {
        netz=2;
      else {
        netz=0;
      Serial.println("Attempting to connect to Arduino Tank...");
      if (netz==2) {
        status = WiFi.begin(ssid2, pass2);
      if ( status != WL_CONNECTED) {
        Serial.println("Couldn't connect to Arduino Tank.");
        Serial.println("Attempting to connect to NerdtechCorporation...");
        if (netz=1) {
          status = WiFi.begin(ssid, pass);
          Serial.println("Couldn't connect to NerdtechCorporation.");
        else {
          Serial.println("Connected to NerdtechCorporation.");
          server.begin();
          printWifiStatus();
      else {
        Serial.println("Connected to Arduino Tank.");
        server.begin();
        printWifiStatus();
    else {
      Serial.println("Already connected");
void webserver() {
  WiFiClient client = server.available();
  if (client) {
    time=millis();  //stores the beginning time
    Serial.println("new client");
    currentLine = "";
    while (client.connected()) {
      if (millis()-time>5000) {  // if it took 5 seconds timeout so stop everything and go back to loop()
        Serial.println("Timeout.");
        client.flush();
        client.stop();
        return;
      if (client.available()) {
        char c = client.read();  // reads incoming stuff
        Serial.print(c);
        currentLine+=c;
        if (c == '\n') {
            currentLine = "";
            Serial.println("Blanked current line");
if (currentLine.substring(0,5)=="GET /"&&currentLine.indexOf("HTTP")!=-1) {  // if the beginning is "GET /" and it contains "HTTP", it also contains the speed of the motors
    currentLine=currentLine.substring(5,currentLine.length()-1);
    Serial.println(currentLine);
    currentLine=currentLine.substring(0,currentLine.indexOf(" "));
    relativex=(currentLine.substring(0,currentLine.indexOf("x")));
    relativey=(currentLine.substring(currentLine.indexOf("x")+1,currentLine.length()));
    Serial.println(relativex);
    Serial.println(relativey);
    relativex.toCharArray(floatbuf,sizeof(floatbuf));
    speedlinks=atof(floatbuf)*255;
    relativey.toCharArray(floatbuf,sizeof(floatbuf));
    speedrechts=atof(floatbuf)*255;
    Serial.println(speedlinks);
    Serial.println(speedrechts);
    if (speedrechts<0) {  // if it's backwards, stop the forward transistor (or so) and start the backwards one
      analogWrite(pin4,speedrechts*(-1));
    else {  //else stop the backwards one and start the forwards one
      analogWrite(pin3,speedrechts);
    if (speedlinks<0) {  //same for left
      analogWrite(pin2,speedlinks*(-1));
    else {
      analogWrite(pin1,speedlinks);
    Serial.println("Finished speed thing");
        client.println("Content-Type: text/html");
        client.println("Connection: close");
        client.println();
        client.println("Banana");
        Serial.println("Sent response");
        client.flush();
        Serial.println(millis());
        client.stop();
        delay(10);
        Serial.println("Delay over");
        return;
    Serial.println("Going to stop client manually");
    client.stop();
    Serial.println("client disconnected");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("SSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
  // print where to go in a browser:
  Serial.print("To see this page in action, open a browser to http://");
  Serial.println(ip);
I connected everything according to this video: - YouTube
Can someone help me with these problems?
First, it looks like you are sending a value between 0.0 and 1.0 to define the speed. Then, you convert that to an int. It would be far simpler to simply send the int in the first place.
That's not unreasonable. That's why opening and closing the connection each time is not recommended. You should be looking at either UDP or persistent connections, or, even better, other forms of wireless communication, like XBee.
It does, huh? It is is a pronoun that has no referent. What beeps? The Arduino doesn't have anything that can make a beeping noise.
Nope, I directly send a value between -255 and 255 for each motor.
I'm trying UDP now, I really hope that this works...
The beeping stopped, I don't know where it came from.
Then what is this about?
That's my (I guess stupid) way to translate the incoming stuff into integers.
