"tap" into the console output of a python script that launches /etc/rc.local
Hello all
I have a python script that receives UDP packets and then talks to my arduino sketch over serial connection and works great, the script also prints information to the console.
If I launch the script at a ssh window from the linux command line I can see my "print" commands for debugging purposes.
But when I launch the script by adding oit to /etc/rc.local I loose the ability to see the print commands from the python script. ANd I cannot run another instance by sshing to the yun because the first one is running automatically
Can I ssh and "tap" into the output of the script that was ran automatically at startup and see the output of the script without modifying my arduino sketch?
Thank you
Best regards
Rodolfo
Pipe it to log file:
foo.py >/var/log/foo.log
might better pipe error message as well.
foo.py >/var/log/foo.log 2>&1
1 is stdout. 2 is stderr.
Hello Sonnyyu
Thank you for your kind answer.
I need to be able to see the messages as they are happening because those are UDP packets that are sent to the arduini sketch for lighting control in realtime.
I was thinking of a way of tapping into maybe a device at the /dev folder maybe with a c program where I can catch the console output of the script that was run by /etc/rc.local
Or just like you suggest instead of piping to a file, is there a way to pipe to a device I can later access to see the output like if I was running on a terminal window?
THANK YOU
Have a great day!
Rodolfo
tail --help
-f              Print data as file grows
tail -f /var/log/foo.log
Thank you Sonny yu
This answer definetly works. I was hoping to find a solution that did not involve files as the process is constantly running and as the Yun's internal memory has a limited life and an USB or micro SD card as well, I cannot use this solution to permamently monitor the python script.
Can you please recommend me a way of implementing a browser based "text dump" application where I just dump from the python script anything I want and then from a browser connected to my yun I watch my debug info?
I will appreciate your help a lot
THANK YOU
Best
Rodolfo
rmagnus: ... This answer definetly works. I was hoping to find a solution that did not involve files as the process is constantly running and as the Yun's internal memory has a limited life and an USB or micro SD card as well, I cannot use this solution to permamently monitor the python script. ...
foo.py >/tmp/foo.log 2>&1
will log to RAM
rmagnus: ... Can you please recommend me a way of implementing a browser based "text dump" application where I just dump from the python script anything I want and then from a browser connected to my yun I watch my debug info? ...
foo.py >/www/foo.log 2>&1
view it at "http://arduino.local/foo.log"
@sonnyyu you are THE MAN
WOW
I love this solution!
So /tmp is ram mounted as a folder?
That is great!
THANK YOU
Best
Rodolfo
rmagnus:
::::SNIP::::
Can I ssh and “tap” into the output of the script that was ran automatically at startup and see the output of the script without modifying my arduino sketch?
::::SNIP::::
@Rodolfo
Redirection, as Sonny has pointed to, is one possible solution. Unix/Linux was made for “streaming” text and data. As such, there is a host of solution. (No pun intened.)
Unix/Linux has three standard stream (standard in, standard out, & standard error), respectively numbered 0,1, & 2. In addition, there are command line symbols that are standard among the many shells available (Yun uses the predecessor to bash, ash.)
The symbols for redirection are:
< standard in redirected
standard out redirected
| piping of standard out.
tee (the program) pipes to a file and standard out at the same time (man tee)
You might do well to redirect or pipe your output, but python can output to a file, AND standard in, standard out, & standard error.
System-specific parameters and functions
https://docs.python.org/2/library/sys.html
Jesse
@sonnyyu
Success! I am logging now to a file stored at /tmp so I have no concern about wearing out flash memory.
Is there a way to access the file with a browser as easy as your example
without copying the file to folder /www?
I am ok if I need to add a file to the www directory that shows the file stored at /tmp folder or if I need to modify the original file that shows files at /www directory but I don’t know where they are.
THANK YOU
Best
Rodolfo
Load an other small http daemon and map "/tmp" to its http root directory.
opkg update
opkg install mini-httpd
nano /etc/mini_httpd.conf
cgipat=cgi-bin/**|**.sh
dir=/tmp
nochroot
pidfile=/var/run/mini_httpd.pid
user=root
port=8080
/etc/init.d/mini_httpd restart
/etc/init.d/mini_httpd enable
View log file at "http://arduino.local:8080/foo.log".
@sonnyyu
It works perfect and it seems to stay working after power off.
This will help me a lot monitoring the correct execution of scripts run by /etc/rc.local by just doing a:
date>/tmp/foo.log
Now I know if a .sh script executed or not
And same goes for a Python script.
Now, one last question:
If I put html files inside /www (before doing this mod you recommended) or /tmp after the mod, can I execute by calling for example:
"http://arduino.local/test.html" if it is under /www
Or "http://arduino.local:8080/test.html"? after changing to /tmp?
THANK YOU!
Have a great weekend
@Jesse THANK YOU
