Hi everyone, I have a question: I have created this project (GitHub - campidelli/tap-tempo-metronome: An Arduino/ESP32 tap tempo metronome.) to create a tap tempo metronome pedal (there is a demo video in the GitHub repository).
It works, sort of. The problem is that the tempo drifts a little bit after a while. For example, if I put another tap tempo metronome side by side, they start syncing but after some seconds I start hearing the difference. What could it be?
This is the code, in case you didn't check the Github repo:
#include "Arduino.h"
#include "ArduinoTapTempo.h"
#include "ESP32_C3_TimerInterrupt.h"
#define LED_PIN 8
#define TAP_TEMPO_SWITCH_PIN 5
#define TIMER1_INTERVAL_MS 20
#define PWM_AUDIO_OUTPUT_PIN 4
#define PWM_CHANNEL 0
#define PWM_FREQ 4000 // Frequency in Hz
#define PWM_RESOLUTION 8 // 8-bit resolution (0-255)
ESP32Timer ITimer1(1); // Timer to check the button state every TIMER1_INTERVAL_MS
ArduinoTapTempo tapTempo; // Used to calculate the BPM
unsigned long lastClickTime = 0; // Last time a click sound was played
volatile bool buttonPressed = false; // Flag to indicate if the button is pressed
bool IRAM_ATTR TimerHandler1(void * timerNo) {
if (digitalRead(TAP_TEMPO_SWITCH_PIN) == LOW && !buttonPressed) {
buttonPressed = true;
if (digitalRead(TAP_TEMPO_SWITCH_PIN) == HIGH) {
tapTempo.update(buttonPressed);
return true;
pinMode(TAP_TEMPO_SWITCH_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
// Set up PWM on the audio output pin
ledcSetup(PWM_CHANNEL, PWM_FREQ, PWM_RESOLUTION);
ledcAttachPin(PWM_AUDIO_OUTPUT_PIN, PWM_CHANNEL);
// Attach timer interrupt to check the button state every TIMER1_INTERVAL_MS
if (ITimer1.attachInterruptInterval(TIMER1_INTERVAL_MS * 1000, TimerHandler1)) {
Serial.println("Timer interrupt started.");
Serial.println("Failed to start timer interrupt.");
float bpm = tapTempo.getBPM();
unsigned long interval = 60000 / bpm; // Interval in milliseconds for each beat
// Click sound and LED blink if it's time for a beat
if (bpm > 0 && millis() - lastClickTime >= interval) {
Serial.print(F("Current BPM: "));
Serial.println(bpm);
digitalWrite(LED_PIN, LOW);
ledcWrite(PWM_CHANNEL, 200); // Set a moderate duty cycle
delay(20);
ledcWrite(PWM_CHANNEL, 0); // Stop sound
digitalWrite(LED_PIN, HIGH);
lastClickTime = millis(); // Update the last click time
Cheers!
