Tapping into the Amp without 3.5 Aux
Hi Everyone! I have a few of these laying around
and a few of these as well
http://mcartorlaw.com/Plug-3-watt-Speakers-2Pcs-4-ohm-Degraw-DIY-Speaker-Kit-320254/
I tried to probe the Aux jack on this board to find what wires to soilder but I am uncertain if I am to expect a DC voltage out from any of the 5 solider points on the board. Judging from the looks only two of the pins are used I assume Tip and Ring and the others are just for joining it to the board itself.
There’s a video here showing a guy doing the same thing but I am unsure if a direct connection to my speakers would work. Does anyone know what chip they are using on this board? I can’t seem to find the datasheet for it anywhere.
Thank you!!
Sometimes those pins are ground and sometimes they are just for mounting.
The easiest way to check is to plug-in a cable and "ohm it out" from the other end of the cable.
There's a video here showing a guy doing the same thing but I am unsure if a direct connection to my speakers would work.
Without any specs it's hard to know but a direct connection to the 4 or 8 Ohm speakers probably won't work. Line outputs are nominally 10K Ohms and they'll often work down to 1K but a few Ohms is really "pushing it". A headphone-output* is usually good down to around 30 Ohms.
Have you tried those speakers with your computer?
Have you tried them with the normal cable connection before you start "hacking"?
  • The voltage out of headphone jack is about line level, and there's always a volume control on a headphone-out so you can adjust it. It's perfectly OK to plug headphone-out to line-in. For example, you can plug powered computer speakers (line level) with a 10K input impedance into the headphone jack on your phone or laptop.
