I was looking at this video of a Liquivision dive computer.
The electronics is potted with no exposed buttons. The device detects taps on its four sides to interface with its menu system.
I would like to do this on a project I'm working on.
Probably using an accelerometer chip - that gives the ability to discriminate direction that a microphone wouldn't
I think an accelerometer chip would work. However, I wonder if 4 piezos and a modified "knock" example code would do the trick? You would measure all 4 sensors and the one with the highest reading would be the intended action/button.
Here is the example code found with no changes:
/* Knock Sensor
This sketch reads a piezo element to detect a knocking sound.
It reads an analog pin and compares the result to a set threshold.
If the result is greater than the threshold, it writes
"knock" to the serial port, and toggles the LED on pin 13.
The circuit:
* + connection of the piezo attached to analog in 0
* - connection of the piezo attached to ground
* 1-megohm resistor attached from analog in 0 to ground
http://www.arduino.cc/en/Tutorial/Knock
created 25 Mar 2007
by David Cuartielles <http://www.0j0.org>
modified 4 Sep 2010
by Tom Igoe
This example code is in the public domain.
// these constants won't change:
const int ledPin = 13; // led connected to digital pin 13
const int knockSensor = A0; // the piezo is connected to analog pin 0
const int threshold = 100; // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0; // variable to store the value read from the sensor pin
int ledState = LOW; // variable used to store the last LED status, to toggle the light
pinMode(ledPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
// read the sensor and store it in the variable sensorReading:
sensorReading = analogRead(knockSensor);
// if the sensor reading is greater than the threshold:
if (sensorReading >= threshold) {
// toggle the status of the ledPin:
ledState = !ledState;
// update the LED pin itself:
digitalWrite(ledPin, ledState);
// send the string "Knock!" back to the computer, followed by newline
Serial.println("Knock!");
delay(100); // delay to avoid overloading the serial port buffer
Interesting, I will give both a try.
