`#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
#define beep_pin 8
#define green_pin 7
#define red_pin 6
MFRC522 mfrc522(SS_PIN, RST_PIN); // Creamos Sensor De Tarjeta MFRC522 Instancia
LiquidCrystal_I2C lcd(0x27,16,2); // Creamos Pantalla LCD Instancia
Serial.begin(9600); // Initiate a serial communication
pinMode(beep_pin,OUTPUT);
digitalWrite(beep_pin,LOW);
pinMode(green_pin,OUTPUT);
digitalWrite(green_pin,LOW);
pinMode(red_pin,OUTPUT);
digitalWrite(red_pin,LOW);
lcd.begin(16, 2);
lcd.setCursor(3, 1);
lcd.backlight();
lcd.print("Bienvenido!!");
lcd.setCursor(0, 0);
lcd.print("Programa Listo");
delay(1500);
lcd.clear();
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
Serial.println("Acerca la tarjea al sensor porfavor...");
digitalWrite(beep_pin, LOW);
lcd.clear();
lcd.print("Pase La Tarjeta");
lcd.setCursor(0, 1);
lcd.print("Porfavor....");
delay(300);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content= "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
if (content.substring(1) == "B3 4F BB 20") //change here the UID of the card/cards that you want to give access
digitalWrite(beep_pin,HIGH);
lcd.print("ID : ");
lcd.print(content.substring(1));
lcd.print("Acceso Autorizado");
Serial.println("Acceso Autorizado");
digitalWrite(green_pin, HIGH);
delay(700);
delay(700);
digitalWrite(green_pin, LOW);
else {
lcd.print("ID : ");
lcd.print("Accesso Denegado");
Serial.println(" Accesso Denegado");
digitalWrite(red_pin, HIGH);
delay(700);
delay(700);
digitalWrite(red_pin, LOW);
Hola, tengo un problema el sensor al conectarlo a la luz me funciona pero al tenerlo en la pc no lee ni funciona de ninguna manera, solo al pasar el dato, posible solucion, y tambien alguna recomendacion de como puedo almacenar los datos de las tarjetas leidas.
