Error message
E (365249) task_wdt: Task watchdog got triggered. The following tasks did not reset the watchdog in time:
E (365249) task_wdt: - async_tcp (CPU 0/1)
E (365249) task_wdt: Tasks currently running:
E (365249) task_wdt: CPU 0: IDLE0
E (365249) task_wdt: CPU 1: IDLE1
E (365249) task_wdt: Aborting.
abort() was called at PC 0x400ddad3 on core 0Backtrace: 0x4008c434:0x3ffbe170 0x4008c665:0x3ffbe190 0x400ddad3:0x3ffbe1b0 0x40084771:0x3ffbe1d0 0x4014c107:0x3ffbc100 0x400dee83:0x3ffbc120 0x4008a361:0x3ffbc140 0x40088b7d:0x3ffbc160
Rebooting...
ets Jun 8 2016 00:22:57rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Setting AP (Access Point)…dhcps: send_nak>>udp_sendto result 0
AP IP address: 192.168.1.1
dhcps: send_offer>>udp_sendto result 0
As you can see in the program below, I tried adding vTaskDelay(10);
in void loop as an attempt to solve the problem. Maybe it should be in other places?
The program works fine with less images. It just triggers the watchdog timer with more than 4-5 images. Is there a way to disable rebooting from the watchdog timer trigger?
#include <WiFi.h>
#include <ESPAsyncWebServer.h>
#include <SPIFFS.h>
const char* ssid = "Wireless Controller";
const char* password = "12345678";
AsyncWebServer server(80);
void notFound(AsyncWebServerRequest *request)
request->send(404, "text/plain", "Not found");
void action(AsyncWebServerRequest *request)
Serial.println("ACTION!");
int params = request->params(); // amount of params
for (int i = 0; i < params; i++)
AsyncWebParameter* p = request->getParam(i);
Serial.printf("POST[%s]: %s\n", p->name().c_str(), p->value().c_str());
request->send(SPIFFS, "/index.html", String(), false);
IPAddress IP(192, 168, 1, 1);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
Serial.begin(115200); // debugging
Serial2.begin(9600, SERIAL_8N1, 16, 17); // Send data on pin 17
// Initialize SPIFFS
if (!SPIFFS.begin(true))
Serial.println("An Error has occurred while mounting SPIFFS");
return;
// Connect to Wi-Fi network with SSID and password
Serial.print("Setting AP (Access Point)…");
// Remove the password parameter, if you want the AP (Access Point) to be open
WiFi.softAP(ssid, password);
delay(2000);
WiFi.softAPConfig(IP, gateway, subnet);
IPAddress IP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(IP);
// Route to load style.css file
server.on("/style.css", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/style.css", "text/css");
// Index.HTML NAVIGATION BUTTIONS ************************************************
server.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
server.on("/action", HTTP_POST, action);
// Pictures *****************************************************************
server.on("/0all.png", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/0all.png", "image/png");
server.on("/1circle.png", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/1circle.png", "image/png");
server.on("/2fspiral.png", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/2fspiral.png", "image/png");
server.on("/3ped.png", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/3ped.png", "image/png");
server.on("/4clover.png", HTTP_GET, [](AsyncWebServerRequest * request) {
request->send(SPIFFS, "/4clover.png", "image/png");
server.onNotFound(notFound);
server.begin();
// May not need once loop contains something:
vTaskDelay(10); //https://github.com/espressif/arduino-esp32/issues/595
