Taylor series for Arduino
Hello everyone,
I'm trying to develop a system to calculate the moisture present in a seed.
My project is:
I have several samples of seeds that I know humidity (ranging from 0 to 100%). I scan these seeds with a sensor connected to my Arduino, and I save these values ??in a table. Once this data is obtained, Arduino calculates me an equation of the form ax ² + bx + c with which I can calculate the moisture in any seed.
The problem is as follows:
I do not know how to write a program to calculate an equation of the form ax ² + bx + c, I know Taylor's theorem facilitate my job, but I do not know at all how to write in C.
Can someone help me to transcribe the Taylor formula in C?
Thank you in advance for your response. ;)
“An equation in the form ax2 + bx + c” is useless, unless you define what a, b, c, and x represent.
Solving a quadratic equation is trivial, when you know what to substitute for a, b, c, and/or x.
The more specific your question, the better we can answer.
Which Arduino board do you have, or do you want to use ? Should the result be displayed on the serial monitor or on a LCD display ? Can you give a link to the sensor (just copy the url).
This is about Taylor theorem, https://en.wikipedia.org/wiki/Taylor%27s_theorem
Calculating with floating point numbers is not hard.
float result, x, a, b, c;
result = (a * (x * x)) + (b * x) + c;
Do you want to get the polynomial regression from your set of values in form of
ax2 + bx + c
or to interpolate the samples with a polynomial (ie. Taylor's polynomial)? http://en.wikipedia.org/wiki/Polynomial_regression http://en.wikipedia.org/wiki/Polynomial_interpolation http://en.wikipedia.org/wiki/Taylor_polynomial
What is wrong with the simple:-
