i have a tb6560 single axis stepper motor driver
problem: the motor shaft does not rotate but remains fixed on a position.
if I connect one phase there are strong vibrations and turns jerky.
connection:
Clk- cw- en- GND arduino mega
Clk+ (digital output arduino) (pulse)
Cw+ digital output arduino
En+ digital output arduino
A+ A- B+ B- motor
input voltage 15 V (or 12)
Firstly you must never disconnect a stepper driver from the stepper when the board is powered up,
that risks burning out the driver.
Secondly you need to verify all the connections to the motor are correct - each winding is intact
(use a multimeter to measure resistance) and that one winding goes to A+ and A-, and the other
to B+ and B-.
You need to set the output current to 1A for this motor - stepper drive boards normally have
a trimmer to set the current - consult any documentation for how to do this. Start with the
adjustment turned down to low current so you don't risk burning out the windings (you'll smell
this if it happens!)
If the power is applied to the driver its normal for the motor to activate immediately and hold position
strongly - check this.
MarkT:
to B+ and B-.
i have verified the connection with a multimeter. i have tried with 0.5 0.8 1 Ampere but nothing
Robin2:
What happens if you write the Enable pin HIGH?
...R
motor is disabled
jcallen:
From the link you posted:
Item
Rated Voltage DC 24V
Working Voltage DC 21.6~26.4V
Rated Current/Phase 1A(PEAK)
No. of Phase
Coil DC Resistance 4.6Ω/phase±7%
Step Angle
Excitation Method
Insulation Class
Holding Torque
Pull-out Torque
Pull-in Torque
Max. Pull-out Pulse Rate 2,150pps (465 uS)
Max. Pull-in Pulse Rate 430pps (2326uS)
it works with another stepper driver(l298n) with 15V motor input voltage
what is the difference between pull-out pulse rate and pull-in pulse rate?
Have you verified by testing that the motor behaves in a disabled state when the Enable pin is HIGH?
Or are you just inferring that from what you have read?
I'm no stepper motor expert, but I would think if the max pull-in pulse rate were exceeded the motor wouldn't go any faster and if Max. Pull-out Pulse Rate were exceeded the motor would lose torque, but don't take that to the bank.
thank you all for the answers. I solved. I connected one phase at a time to the board and I checked the direction of rotation so I reconnected the two phases in the correct way. rotation works with 5000 us delay even if there are vibrations. Now I would like to understand how to control the speed
