TC35 GSM Module - Serial communication (2.65v level?)
Hello!
I am trying to use a Siemens TC35 GSM module with my Arduino Duemilanove.
The manual says:
The data interface is implemented as a serial asynchronous transmitter and receiver
conforming to ITU-T RS-232 Interchange Circuits DCE. It operates at CMOS level (2.65V).
All RS-232 signals on the ZIF connector are low active.
The GSM engine is designed for use as a DCE. Based on the conventions for DCE-DTE
connections it communicates with the customer application (DTE) using the following
signals:
• Port TxD @ application sends data to /TxD0 of the GSM engine
• Port RxD @ application receives data from /RXD0 of the GSM
The data interface is configured for 8 data bits, no parity and 1 stop bit, and can be operated
at bitrates from 300bps to 115kbps. Autobauding supports bit rates from 4.8kbps to 115kbps
(except for 14.4kbps and 28.8kbps). Hardware handshake using the RTS0 / CTS0 signals
and XON/XOFF software flow control are supported.
In addition, the modem control signals DTR0*)
, DSR0, DCD0 and RING0 are available. The
modem control signal RING0 (Ring Indication) can be used to indicate, to the cellular device
application, that a call or Unsolicited Result Code (URC) is received. There are different
modes of operation, which can be set with AT commands.
The DTR0 signal will only be polled once per second from the internal firmware of
TC35/TC37.
How can I use this device with Arduino? I am not sure what kind of interface chips/curcuits I need...
Best regards,
Cherry
Which Arduino?
On a Mega2560 (like mine) I would just attach it to the Second Serial Port, -- the RX1, TX1 pair. The voltages are in range.
Look on this site for a library that you can use directly or modify for GSM hookup.
Many of them might not use the hardware handshaking indicated -- but that should be no big deal to hook up.
As I wrote at the top of my post, I am using a Duemilanove.
I don't want to use a Mega since firstly I don't have one here and secondly there is not enough space for it, all the other hardware has already been mounted.
I don't need a library either, because I am perfectly fine talking to the modem using AT commands. I tested everything using a RS-232 connection to my computer (I bought a development board where the TC35 is connected to a MAX232).
However I am not sure how to connect the TX0/RX0 pins of the TC35 to the TX/RX pins on my Arduino. I am confused because the documentation says something about "RS-232 signals", so I don't know if I need to invert the signal somehow, plus it says the voltage level is 2.65v, and as far as I know, Arduino's serial interface uses 5v. Maybe 2.65v signals work on Arduino's RX pin too, but I am afraid that pushing 5v signals into the TC35's RX0 pin might damage it. I already tried using a voltage divider like this: Arduino TX ---- 10k resistor ---- TC35 RX0 ---- 10k resistor ---- GND, so the TC35 should get ~2.5v, but it didn't work. It looks like the Arduino can't even receive data (maybe 2.65v are really too low)...
Use MAX232 IC. RS232 Converter DIP - MAX232 MAX3232 - COM-00316 - SparkFun Electronics
Here is a short tutorial about the difference RS232 vs TTL signals: RS-232 vs. TTL Serial Communication - SparkFun Electronics
Now I am confused.
I thought, the MAX232 converts 5V/0V to RS232 (-12V/+12V)? I need to convert 5V/0V to 2.65V/0V (and vice-versa)!
Alright, solved.
It's working well now!
Hey Cherry.
I'm looking at buying the same GSM module to use in a little project of mine.
Did you manage to get it to work, -and how.?
Cheers /David
