Hi
I was configuring TC5 interrupt.But whenever I am writing to TC5->COUNT16.CC[0].reg & then check for the sync,it never executes afterwards.I simply inserted some breakpoints but i am stuck at Breakpoint4 in TcConfig().Please take a look at the code
int state;
void TcConfig(int sampleRate)
//First configure Generic Clock(GENCTRL related Setting)
GCLK->GENCTRL.reg |= GCLK_GENCTRL_IDC | //50-50 Duty(Though,it will not reflect on any output pin)
GCLK_GENCTRL_GENEN | //Enable generic clock generator
GCLK_GENCTRL_SRC_DFLL48M | //48MHz clock PLL clock as the input
GCLK_GENCTRL_ID(4); //Select GCLK 4
while (GCLK->STATUS.bit.SYNCBUSY);
SerialUSB.println("Braekpoint1");
//Configure Divisor of Input Clock for GENCTRL(GENDIV Related Settings)
GCLK->GENDIV.reg |= GCLK_GENDIV_DIV(48) | //Select clock divisor as 48 i.e GCLK4 output will be 48/48 = 1MHz
GCLK_GENDIV_ID(4); //GCLK4
SerialUSB.println("Braekpoint2");
//Now configure GCLK4 & Feed it's output to TC5(CLKCTRL related settings)
GCLK->CLKCTRL.reg |= GCLK_CLKCTRL_CLKEN | // Enable Generic Clock
GCLK_CLKCTRL_GEN_GCLK4 | // Select GCLK4
GCLK_CLKCTRL_ID(GCM_TC4_TC5); //Feed GCLK4 output to TC5
SerialUSB.println("Braekpoint3");
//Now,configure TC5
TC5->COUNT16.CTRLA.reg &= ~TC_CTRLA_ENABLE; //Disable TC5 before Edit
while (TC5->COUNT16.STATUS.reg & TC_STATUS_SYNCBUSY); //Wait for sync
TC5->COUNT16.CTRLA.reg |= TC_CTRLA_MODE_COUNT16 | //16 Bit Mode
TC_CTRLA_PRESCALER_DIV1024 | //1024 Prescaler
TC_CTRLA_WAVEGEN_MFRQ; //Match Frequency Mode
while (TC5->COUNT16.STATUS.reg & TC_STATUS_SYNCBUSY);// Wait for sync
SerialUSB.println("Braekpoint4");
TC5->COUNT16.CC[0].reg = 500;// Set the CC register
SerialUSB.println("Braekpoint5");
TC5->COUNT16.CTRLA.reg |= TC_CTRLA_ENABLE; //Enable TC5
SerialUSB.println("Braekpoint6");
NVIC_DisableIRQ(TC5_IRQn);
NVIC_ClearPendingIRQ(TC5_IRQn);
NVIC_SetPriority(TC5_IRQn, 0);
NVIC_EnableIRQ(TC5_IRQn);
SerialUSB.println("Braekpoint7");
TC5->COUNT16.INTENSET.bit.MC0 = 1;
SerialUSB.println("Braekpoint8");
void TcStart(void)
TC5->COUNT16.CTRLA.reg |= TC_CTRLA_ENABLE; //set the CTRLA register
void TC5_Handler (void) {
//YOUR CODE HERE
if (state == true) {
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
state = !state;
// END OF YOUR CODE
TC5->COUNT16.INTFLAG.bit.MC0 = 1; //Writing a 1 to INTFLAG.bit.MC0 clears the interrupt so that it will run again
pinMode(LED_BUILTIN, OUTPUT);
SerialUSB.begin(115200);
while (!SerialUSB);
TcConfig(500);
TcStart(); //starts the timer
