TCA9548A ISSUE? OR CODE ISSUE?
So iv been going out of my mind trying to figure this out, iv had 2 other arduino coders (amateur at best) go over it, and the code verifies with no errors!! i have 2 oled displays (128x64 1.3") connected to a TCA9548A on the sd0/sc0 and sd1/sc1 bus lines.. i have the multiplexer connected to an UNO via sda and scl on a4 & a5.. power and grounds are all shared..(see pic attached)
this issue i have is that 1 screen will show all the data requested on bus SD1/SC1 but the screen on SD0/SC0 shows only a white screen... i checked wiring, and the code at least 20Xs and even swapped the screens, made no difference...can anyone go thru my code and tell me what i screwed up ? or is it a hardware issue ? also if it can be made simpler, please advise....
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SH1106.h>
#if (SH1106_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SH1106.h!");
#endif
#define OLED_RESET 4
// Create an object for each OLED display
Adafruit_SH1106 display0(OLED_RESET);
Adafruit_SH1106 display1(OLED_RESET);
//-------------------TPS data begin -------------------------
const float referenceVolts = 5.0;        // the default reference on a 5 volt board
const int TPSPin = A0;                // signal from Sensor is connected to analog pin 0
float battv;                             // floated for decimal useage
float percent;                           // floated for decimal useage
int TPSMin = 95;
int TPSMax = 950;
//----------------------END TPS data-------------------------------
//---------------------boost data begin----------------------------
const int BoostPin = A1;                //reads from analog input pin 1
const float ReferenceVolts = 5.0;   // the default reference on a 5 volt board
float PSI;
float Volts;
int BoostMin = 0;   // change this to adjust low reading   // integer of sensed voltage
int BoostMax = 1023;  // change this to adjust high reading   // integer of sensed voltage
                      // use the serial monitor to get sensor integers
//----------------------END boost data------------------------------------
void TCA9548A(uint8_t bus)       //multiplexer commanded to transmit
  Wire.beginTransmission(0x70);  // TCA9548A address is 0x70
  Wire.write(1 << bus);          // send byte to select bus
  Wire.endTransmission();
  //Serial.begin(9600);  // initialize serial communication at 9600 bits per second:
  Wire.begin();  // Start Wire library for I2C
  // Set multiplexer to channel 0 and initialize OLED-0 with I2C addr 0x3C
  TCA9548A(0);
  display0.begin(SH1106_SWITCHCAPVCC, 0x3C);
  // Set multiplexer to channel 1 and initialize OLED-1 with I2C addr 0x3C
  TCA9548A(1);
  display1.begin(SH1106_SWITCHCAPVCC, 0x3C);
  display0.display();   // turns off splash screen when commented out
  delay(4000);
  display1.display();   // turns off splash screen when commented out
  delay(4000);
  // Clear the buffer.
  display0.clearDisplay();
  display1.clearDisplay();
  // boot TPS text display
  display0.setTextSize(2);
  display0.setTextColor(WHITE);
  display0.setCursor(45, 0);
  display0.println("TPS");
  display0.setCursor(5, 18);
  display0.println("MONITOR v1");
  display0.setTextSize(1);
  display0.setCursor(0, 50);
  display0.println("By Johnathan Oey");
  display0.display();
  delay (4000);
  // boot BOOST text display
  display1.setTextSize(2);
  display1.setTextColor(WHITE);
  display1.setCursor(10, 0);
  display1.println("BOOST PSI");
  display1.setTextSize(1);
  display1.setCursor(40, 18);
  display1.println("MONITOR v1");
  display1.setCursor(0, 50);
  display1.println("By Johnathan Oey");
  display1.display();
  delay (4000);
  /* DIAGNOSTICS section is for value reading only.
     comment out this section and line 22 when diagnostics are done. */
            // DIAGNOSTICS
//  int sensorValue = analogRead(A0);              // read the input on analog pin 0
//  Serial.print ("Integer Value ");               // print out the values name on the serial monitor
//  Serial.println(sensorValue);                   // print out the value you read on the serial monitor as an integer
//  float voltage = sensorValue * (5.0 / 1023.0);  // convert the analog reading to a voltage
//  Serial.print ("volts ");                       // print out the values name on the serial monitor
//  Serial.println(voltage);                       // print out the value you read on the serial monitor in volts
//  delay(500);                                    // delay in between reads for stability
            // END OF DIAGNOSTICS
  // text TPS display
  display0.setCursor(32, 0);
  display0.println("TPS MONITOR");
  display0.setCursor(0, 14);
  display0.println("Volts");
  display0.setCursor(0, 30);
  display0.println("Percent");
  display0.display();
  checkbatt();
  display0.setTextColor(WHITE, BLACK);
  display0.setCursor(40, 10);
  display0.print (battv);
  display0.println("v");
  Percent();
  display0.setTextSize(3);
  display0.setCursor(35, 40);
  display0.print (percent, 0);
  display0.println(" % ");
//----------------END TPS---------------
// text BOOST display
  display1.setCursor(35, 0);
  display1.println("BOOST");
  display1.display();
  Pressure();
  display1.setTextSize(3);
  display1.setTextColor(WHITE, BLACK);
  display1.setCursor(20, 35);
  display1.print(PSI);
  display1.setCursor(92, 40);
  display1.print("psi");
//---------------END BOOST-----------------
void checkbatt()
  battv = (analogRead(TPSPin) / 1023.0) * referenceVolts;           // read the value from A0 Sensor monitoring pin
        // Divides by 1023 to get an integer, then multiplies by the ref voltage.
void Percent()
  percent = map(analogRead(TPSPin), TPSMin, TPSMax, 0, 100);            // reconfigures the voltage low and high readings at pin A0 to be integer percent(%) from 0 - 100%
void Pressure()
  Volts = (analogRead (BoostPin) / 1023.0) * ReferenceVolts;                 // read the value from A1 Sensor monitoring pin
  PSI = map(analogRead(BoostPin), BoostMin, BoostMax, 0, 14.7);            // reconfigures the voltage low and high readings at pin A1 to be actual boost readings
ok so i rewrote the code and by doing so i now get both screens to display.. however, they dont do the correct functions.. by that i mean, they are both supposed to show a bootup screen but only 1 will.. then they are both to show some version information, but only 1 will, then the 2nd screen will suddenly show all the data at the same time that both screens are supposed to individually have and then the 1st screen will do the same...so now, i have 2 screens showing the same info and its overlaying all the info..
in the progression of how it should be
screen 1 & 2 == show bootup screen
screen 1 & 2 == show version info
screen 1 == show specific data to TPS
screen 2== show specific data to BOOST
screen 1 == known as display0
screen 2== known as display1
all connections show to be correct and working since the multiplexer is now turning on channel 0 and 1.. but the info is not displaying correctly...
thoughts?
before, the code i posted only allowed 1 channel on the multiplexer to work... so i fixed that.. so heres the new code...
please be kind, im new to coding and this has been a long learning curve for me as i have no real help..
#include <Wire.h>             //i2c library
#include <Adafruit_GFX.h>     // graphics library
#include <Adafruit_SH1106.h>  //oled library
#endif
void displayBatt(float battv) {
void displayPercent(float percent){
int TPSMin = 95;
int TPSMax = 950;
//-----------------------START BOOST DATA----------------------------
void displayBoost(float PSI) {
  display1.setCursor(40, 10);
  display1.print (PSI);
  display1.println("psi");
  TCA9548A(0);
  delay(4000);
  display0.clearDisplay();   // Clear the buffer.
  TCA9548A(1);
  delay(4000);
  display0.display();
  delay (3000);
  display1.display();
  delay (3000);
  // text TPS display
  display0.display();
  float battv = (analogRead(TPSPin) / 1023.0) * referenceVolts;           // read the value from A0 Sensor monitoring pin
  float Percent = map(analogRead(TPSPin), TPSMin, TPSMax, 0, 100);            // reconfigures the voltage low and high readings at pin A0 to be integer percent(%) from 0 - 100%
TCA9548A(0);
  displayBatt(battv);
  displayPercent(Percent);
  display0.display();
  display1.display();
  float PSI = map(analogRead(BoostPin), BoostMin, BoostMax, 0, 14.7);
  TCA9548A(1);
  displayBoost(PSI);
  display1.display();
