TCA9548A Multiplexer with TSL2591 Light Sensor
I am trying to hook up the TSL2591 light sensor to the TCA9548A multiplexer to the Arduino Uno. I have un the default multiplexer scanner and it found the device.
TCA Port #0
Found I2C 0x29
When I try to run the light sensor example code with the following code added in, before the if statement in the setup, it is not detecting the sensor.
Wire.beginTransmission(0x70);
Wire.write(1 << 0);
Wire.endTransmission();
Here is the code I am currently using.
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_TSL2591.h>
#define TCAADDR 0x70
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
Adafruit_TSL2591 tsl = Adafruit_TSL2591(2591);
void displaySensorDetails(void)
  sensor_t sensor;
  tsl.getSensor(&sensor);
  Serial.println("------------------------------------");
  Serial.print  ("Sensor:       "); Serial.println(sensor.name);
  Serial.print  ("Driver Ver:   "); Serial.println(sensor.version);
  Serial.print  ("Unique ID:    "); Serial.println(sensor.sensor_id);
  Serial.print  ("Max Value:    "); Serial.print(sensor.max_value); Serial.println(" lux");
  Serial.print  ("Min Value:    "); Serial.print(sensor.min_value); Serial.println(" lux");
  Serial.print  ("Resolution:   "); Serial.print(sensor.resolution); Serial.println(" lux");
  Serial.println("");
void setup(void)
  tcaselect(0);
  if(tsl.begin())
    Serial.println("Found a TSL2591 sensor!");
    Serial.println("No sensor found ...");
  displaySensorDetails();
void loop(void)
If anyone has any feedback or tips it would be greatly appreciated!
I see two different I2C addresses there.
I had the 0x70 device which is the multiplexer and I am using that address to scan. From there I and scanning and finding a device at 0x29 (the light sensor). Is this what you mean? If I only need to use one of the two address then can you give me some example code, or make corrections to the code that I added into my post?
I found what I was missing! In my setup at the very beginning i needed the following line of code.
Wire.begin();
