Hi all!
New to the world of Arduino and new to the forums. I am really enjoying learning to program these board and making my own projects.
I have been working on a project for my car that will have 3 small oled's displaying weather information. As i need 3 oled's and 2 sensors i have chosen to use a multiplexer.
So i have watched a few video tutorials on using the TCA9548A and read a lot of information on it too.
But when i wire it up and run an I2C scanner i get the following:
I2C Scanner
Scanning...
Unknown error at address 0x01
Unknown error at address 0x02
Unknown error at address 0x03
Unknown error at address 0x04
Unknown error at address 0x05
Unknown error at address 0x06
Unknown error at address 0x07
Unknown error at address 0x08
Unknown error at address 0x09
Unknown error at address 0x0A
Unknown error at address 0x0B
Unknown error at address 0x0C
Unknown error at address 0x0D
Unknown error at address 0x0E
Unknown error at address 0x0F
Unknown error at address 0x10
Unknown error at address 0x11
Unknown error at address 0x12
Unknown error at address 0x13
Unknown error at address 0x14
Unknown error at address 0x15
Unknown error at address 0x16
Unknown error at address 0x17
Unknown error at address 0x18
Unknown error at address 0x19
Unknown error at address 0x1A
Unknown error at address 0x1B
Unknown error at address 0x1C
Unknown error at address 0x1D
Unknown error at address 0x1E
Unknown error at address 0x1F
Unknown error at address 0x20
Unknown error at address 0x21
Unknown error at address 0x22
Unknown error at address 0x23
Unknown error at address 0x24
Unknown error at address 0x25
Unknown error at address 0x26
Unknown error at address 0x27
Unknown error at address 0x28
Unknown error at address 0x29
Unknown error at address 0x2A
Unknown error at address 0x2B
Unknown error at address 0x2C
Unknown error at address 0x2D
Unknown error at address 0x2E
Unknown error at address 0x2F
Unknown error at address 0x30
Unknown error at address 0x31
Unknown error at address 0x32
Unknown error at address 0x33
Unknown error at address 0x34
Unknown error at address 0x35
Unknown error at address 0x36
Unknown error at address 0x37
Unknown error at address 0x38
Unknown error at address 0x39
Unknown error at address 0x3A
Unknown error at address 0x3B
Unknown error at address 0x3C
Unknown error at address 0x3D
Unknown error at address 0x3E
Unknown error at address 0x3F
Unknown error at address 0x40
Unknown error at address 0x41
Unknown error at address 0x42
Unknown error at address 0x43
Unknown error at address 0x44
Unknown error at address 0x45
Unknown error at address 0x46
Unknown error at address 0x47
Unknown error at address 0x48
Unknown error at address 0x49
Unknown error at address 0x4A
Unknown error at address 0x4B
Unknown error at address 0x4C
Unknown error at address 0x4D
Unknown error at address 0x4E
Unknown error at address 0x4F
Unknown error at address 0x50
Unknown error at address 0x51
Unknown error at address 0x52
Unknown error at address 0x53
Unknown error at address 0x54
Unknown error at address 0x55
Unknown error at address 0x56
Unknown error at address 0x57
Unknown error at address 0x58
Unknown error at address 0x59
Unknown error at address 0x5A
Unknown error at address 0x5B
Unknown error at address 0x5C
Unknown error at address 0x5D
Unknown error at address 0x5E
Unknown error at address 0x5F
Unknown error at address 0x60
Unknown error at address 0x61
Unknown error at address 0x62
Unknown error at address 0x63
Unknown error at address 0x64
Unknown error at address 0x65
Unknown error at address 0x66
Unknown error at address 0x67
Unknown error at address 0x68
Unknown error at address 0x69
Unknown error at address 0x6A
Unknown error at address 0x6B
Unknown error at address 0x6C
Unknown error at address 0x6D
Unknown error at address 0x6E
Unknown error at address 0x6F
Unknown error at address 0x70
Unknown error at address 0x71
Unknown error at address 0x72
Unknown error at address 0x73
Unknown error at address 0x74
Unknown error at address 0x75
Unknown error at address 0x76
Unknown error at address 0x77
Unknown error at address 0x78
Unknown error at address 0x79
Unknown error at address 0x7A
Unknown error at address 0x7B
Unknown error at address 0x7C
Unknown error at address 0x7D
Unknown error at address 0x7E
No I2C devices found
I have tried several different I2C scanners but get the same result every time. I read that the A0 A1 A2 pins can be put to ground to change the address of the Mux but this makes no difference.
// i2c_scanner
// Version 1
// This program (or code that looks like it)
// can be found in many places.
// For example on the Arduino.cc forum.
// The original author is not know.
// Version 2, Juni 2012, Using Arduino 1.0.1
// Adapted to be as simple as possible by Arduino.cc user Krodal
// Version 3, Feb 26 2013
// V3 by louarnold
// Version 4, March 3, 2013, Using Arduino 1.0.3
// by Arduino.cc user Krodal.
// Changes by louarnold removed.
// Scanning addresses changed from 0...127 to 1...119,
// according to the i2c scanner by Nick Gammon
// http://www.gammon.com.au/forum/?id=10896
// Version 5, March 28, 2013
// As version 4, but address scans now to 127.
// A sensor seems to use address 120.
// Version 6, November 27, 2015.
// Added waiting for the Leonardo serial communication.
// This sketch tests the standard 7-bit addresses
// Devices with higher bit address might not be seen properly.
#include <Wire.h>
Wire.begin();
while (!Serial); // Leonardo: wait for serial monitor
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
// The i2c_scanner uses the return value of
// the Write.endTransmisstion to see if
// a device did acknowledge to the address.
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("I2C device found at address 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Unknown error at address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("No I2C devices found\n");
Serial.println("done\n");
delay(5000); // wait 5 seconds for next scan
I hope i have provided sufficient information. Really appreciate any help i get with this.
Cheers!
