TCD1705D ccd linear arduino
i am new to use ccd linear sensor, i dont know hoe to connect each pin of TCD1705D to arduino except groun and Vcc.
anyone could help me ?
Thank you
datasheetTCD1705D.pdf (406 KB)
Purwalaksana: i am new to use ccd linear sensor, i dont know hoe to connect each pin of TCD1705D to arduino except groun and Vcc.
Thank you
What makes you think it will work with the Arduino ?
because i thought arduino could give pulse to sensor from pwm pin.
Page 2 of the data sheet will show you what pins you need to pulse. It also tells you that pins OS1 and OS2 are outputs from the sensor. Page 7 shows you how to waggle those output pulses in order to get the data out.
However that output signal requires being fed to an A/D converter, and it is coming out far too fast for the Arduino to cope with. It also shows you it is outputting 3725 x 2 elements of data, which is far too many to store in the Arduino.
