Tcp_bind() fails after object delete/re-create RP2040 Philhower Core
I am using the Philhower RP2040 core, version 4.4.3, and a WIZNet W5500 Ethernet chip. Rather than creating a global reference to Wiznet5500lwIP, I am using a pointer that I allocate and free as the system starts and stops. (In case you are wondering why, it's because I also plan to send commands to the WIZNet W5500 Ethernet chip to turn it off/put it in low power mode and then back on). I have run into a situation where tcp_bind() fails and I can't properly control the cleanup of the internal data structures that cause the problem.
Attached is sample code that should demonstrate the issue. I am using an HTTP server based on HTTP by Giuseppe Masino. I have included an earlier version of that library because I couldn't get the most recent (7 years old) to compile. So, don't install the HTTP library into Arduino IDE, just use the included code.
MAC address and IP settings are near the beginning of the .ino file - adjust for your network. I hard coded the IP address settings because the network connection starts faster.
To run the example code you'll need a Raspberry Pi Pico, a WIZnet W5500 board, and a pushbutton. The WIZnet is connected to CS 17 and SPI0. The button can be connected to any available pin - I used pin 28. To debug, I use a PicoProbe.
The project setup is mostly defaults. Optimize is turned off to allow set of breakpoint at tcp_bind() result:
  • Board: Raspberry Pi Pico
  • Debug Level: "None"
  • Debug Port: "Disabled"
  • C++ Exceptions: "Disabled"
  • Flash Size: "2MB (no FS)"
  • CPU Speed: "133 MHz"
  • IP/Bluetooth Stack: "IPv4 Only"
    - Optimize: Disabled (-O0)
  • Profiling: "Disabled"
  • RTTI: "Disabled"
  • Stack Protector: "Disabled"
  • Upload Method: "Picoprobe/Debugprobe (CMSIS-DAP)"
  • USB Stack: "Pico SDK"
After the code is built and running, press the button to start the Ethernet chip and servers. Notice that ping of DemoOfFailedTCPBind.local works and a browse to http://DemoOfFailedTCPBind.local returns the demo web page.
If the button is pressed again, the servers are stopped and the Ethernet object is closed and deleted. Now ping and the demo web page are no longer available.
Here is the problem: If the button is pressed again, which starts Ethernet and the webserver again, the tcp_bind() that is called by the webserver begin() will fail. To see this, set a breakpoint in arduino15/packages/rp2040/hardware/rp2040/4.4.3/libraries/WiFi/src/WiFiServer.cpp, line 68.
Note these observations: tcp_bind() will always succeed if (a) I never refresh the web page http://DemoOfFailedTCPBind.local, (b) I restart the debugger, or (c) if I wait EXACTLY 2 minutes or more after the web client closes.
Can anyone help me solve this issue? Am I using the client code correctly? Is there a re-init function for the W5500lwIP code?
I also don't see how the translation layer lwip_wrap.cpp in the Philhower core is built - the functions with names like __real_lwip_init() and __real_tcp_bind().
Any feedback would be appreciated.
(I will attach the code when Arduino.cc doesn't consider me a new user. In the meantime I'll have to include it as part of this message. What I find odd is that I originally created my Arduino.cc account on 6 December 2022 and even received an updated Privacy Policy/Terms of Service on 3 December 2024. When I tried to log in today, 10 February 2025, the account had been deleted)
Directory structure:
DemonstrateFailedTCPbind/
 +- src/
 |   +-HTTP/
 |       +- httpHeader.cpp
 |       +- httpMessage.hpp
 |       +- httpServer.hpp
 |       +- httpHeader.hpp
 |       +- httpRequestHandler.hpp
 +- DemonstrateFailedTCPbind.ino
 +- HTTPInterface.cpp
 +- HTTPInterface.h
DemonstrateFailedTCPbind.ino:
#include <W5500lwIP.h> // Or W5100lwIP.h or ENC28J60.h
#include <LEAmDNS.h>
#include "src/HTTP/httpServer.hpp"
#include "HTTPInterface.h"
#define FRONT_PANEL_SWn 28
Wiznet5500lwIP *pEth = NULL;
byte macAddress[6] { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED } ;
IPAddress myIP(192,168,199,215);
IPAddress myGW(192,168,199,1);
IPAddress myNetMask(255,255,255,0);
IPAddress myDNS1(192,168,199,1);
IPAddress myDNS2(8,8,8,8);
static char *MDNSname = "DemoOfFailedTCPBind";
    pinMode(FRONT_PANEL_SWn, INPUT_PULLDOWN);
enum Test_State
    ETHERNET_START = 1,
    ETHERNET_STARTING,
    ETHERNET_RUN,
    ETHERNET_STOP,
Test_State currentState = ETHERNET_STOP;
EthernetLinkStatus linkStatus = Unknown;
wl_status_t connectionStatus = WL_IDLE_STATUS;
// Create an HTTP reference pointer
http::Server *pHttpServer = NULL;
// Create a HTTP Server reference pointer
HTTP_NETWORK_SERVER_CLASS * _server = NULL;
#define HTTP_PORT 80
void http_server_init(void)
    // Create the HTTP server
    _server = new HTTP_NETWORK_SERVER_CLASS(HTTP_PORT);
    if (NULL != _server)
        // start the HTTP server
        _server->begin();
        // Initialize the HTTP server library
        pHttpServer = new http::Server();
        if (NULL != pHttpServer)
            // Use the default http request handler
            // (although returnTestPage is the default handler, the assignment here is just for clarity)
            //pHttpServer->GET_requestHandler = http::requestHandler::returnTestPage;
void http_server_loop(void)
    HTTP_YIELD();
    if ( (NULL != pHttpServer) && (NULL != _server) )
#if(HTTP_NETWORK_TYPE == NETWORK_ESP8266) || (HTTP_NETWORK_TYPE == NETWORK_ESP32) || (HTTP_NETWORK_TYPE == NETWORK_RP2040)
        while(_server->hasClient())
#endif
    // store new connection
#if(HTTP_NETWORK_TYPE == NETWORK_WIFI_NINA)
            HTTP_NETWORK_CLASS * tcpClient = new HTTP_NETWORK_CLASS(_server->available());
#else
            HTTP_NETWORK_CLASS * tcpClient = new HTTP_NETWORK_CLASS(_server->accept());
#endif
            if(!tcpClient)
                DEBUG_HTTP("[HTTP-Client] creating Network class failed!");
                return;
            handleNewClient(tcpClient);
            // Then pass the object to the server
            pHttpServer->replyTo(*tcpClient);
#endif
void http_server_terminate(void)
        httpServerdisconnect();  // pHttpServer->disconnect();
        delete pHttpServer;
        pHttpServer = NULL;
#if(HTTP_NETWORK_TYPE == NETWORK_ESP8266) || (HTTP_NETWORK_TYPE == NETWORK_RP2040)
        _server->close();
#elif(HTTP_NETWORK_TYPE == NETWORK_ESP32)
        _server->end();
#else
    // TODO how to close server?
#endif
        delete _server;
        _server = NULL;
uint32_t previousMillis = 0;
    uint32_t currentMillis = millis();
    uint32_t timeDifference = 0;
    if (currentMillis < previousMillis)
        // Overflow has occurred
        timeDifference = UINT32_MAX - previousMillis + currentMillis;
        // No overflow
        timeDifference = currentMillis - previousMillis;
    if (timeDifference >= 10)
        static uint32_t delayms = 0;
        // This routine is called every AMP_POWER_CALL_PERIOD ms.
        if (delayms > 0)
            delayms--;
        switch (currentState)
            case ETHERNET_START:
              pEth =  new Wiznet5500lwIP(SS); // Parameter is the Chip Select pin
              pEth->config(myIP, myGW, myNetMask, myDNS1, myDNS2);
              pEth->begin(macAddress);
              currentState = ETHERNET_STARTING;
            case ETHERNET_STARTING:
                linkStatus = pEth->linkStatus();
                connectionStatus = pEth->status();
              if ( (LinkON == linkStatus) && (WL_CONNECTED == connectionStatus) )
                    if (MDNS.begin(MDNSname))
                        Serial.println("MDNS responder started");
                    http_server_init();
                    delayms = 50;  // 50*10ms debounce
                    currentState = ETHERNET_RUN;
            case ETHERNET_RUN:
                if (WL_CONNECTED == connectionStatus)
                    http_server_loop();
                    // This runs the Bonjour module. CALL THIS PERIODICALLY, preferably, call it once per loop().
                    MDNS.update();
                if (0 == delayms)
                    // Check for Front Panel or Trigger initiated power off
                    bool FP_instantaneous_value = digitalRead(FRONT_PANEL_SWn);
                    if (FP_instantaneous_value == 0)
                        delayms = 50;  // 5*10ms debounce
            case ETHERNET_STOP:
                if (NULL != pEth)
                    MDNS.end();
                    http_server_terminate();
                    pEth->end();
                    // Delete the Ethernet class
                    delete pEth;
                    pEth = NULL;
                if (0 == delayms)
                        currentState = ETHERNET_START;
HTTPInterface.h:
#include <WebSockets.h>
#define HTTP_NETWORK_CLASS WEBSOCKETS_NETWORK_CLASS
#define HTTP_NETWORK_SERVER_CLASS WEBSOCKETS_NETWORK_SERVER_CLASS
#define HTTP_NETWORK_TYPE WEBSOCKETS_NETWORK_TYPE
#define HTTP_YIELD WEBSOCKETS_YIELD
#define DEBUG_HTTP DEBUG_WEBSOCKETS
#define HTTP_TCP_TIMEOUT WEBSOCKETS_TCP_TIMEOUT
#define HTTP_SERVER_CLIENT_MAX (2)
typedef enum {
    HTTP_NOT_CONNECTED,
    HTTP_HEADER,
    HTTP_BODY,
    HTTP_CONNECTED
} HTTPclientsStatus_t;
typedef struct
    HTTPclientsStatus_t status = HTTP_NOT_CONNECTED;
    HTTP_NETWORK_CLASS * tcp = nullptr;
} HTTPclient_t;
HTTPclient_t* newClient(HTTP_NETWORK_CLASS * TCPclient);
void handleNewClient(HTTP_NETWORK_CLASS * tcpClient);
bool clientIsConnected(HTTPclient_t * client);
void dropNativeClient(HTTPclient_t * client);
void clientDisconnect(HTTPclient_t * client);
void httpServerdisconnect(void);
HTTPInterface.cpp:
HTTPclient_t _clients[HTTP_SERVER_CLIENT_MAX];
    HTTPclient_t * client;
    // search free list entry for client
    for(uint8_t i = 0; i < HTTP_SERVER_CLIENT_MAX; i++)
        client = &_clients[i];
        // look for match to existing socket before creating a new one
        if(clientIsConnected(client))
#if(HTTP_NETWORK_TYPE == NETWORK_W5100)
            // Check to see if it is the same socket - if so, return it
            if(client->tcp->getSocketNumber() == TCPclient->getSocketNumber())
                return client;
#endif
            // state is not connected or tcp connection is lost
            client->tcp = TCPclient;
            client->isSSL = false;
            client->tcp->setNoDelay(true);
#endif
            // set Timeout for readBytesUntil and readStringUntil
            client->tcp->setTimeout(HTTP_TCP_TIMEOUT);
            client->status = HTTP_HEADER;
#ifndef NODEBUG_HTTP
            IPAddress ip = client->tcp->remoteIP();
#endif
            DEBUG_HTTP("[HTTP-Server] new client from %d.%d.%d.%d\n", ip[0], ip[1], ip[2], ip[3]);
#else
            DEBUG_HTTP("[HTTP-Server] new client\n");
#endif
            return client;
    return nullptr;
 * Handle incoming Connection Request
    HTTPclient_t * client = newClient(tcpClient);
    if(!client)
        // no free space to handle client
        IPAddress ip = tcpClient->remoteIP();
#endif
        DEBUG_HTTP("[HTTP-Server] no free space new client from %d.%d.%d.%d\n", ip[0], ip[1], ip[2], ip[3]);
#else
        DEBUG_HTTP("[HTTP-Server] no free space new client\n");
#endif
        // no client! => create dummy!
        HTTPclient_t dummy = HTTPclient_t();
        client           = &dummy;
        client->tcp      = tcpClient;
        dropNativeClient(client);
    HTTP_YIELD();
 * get client state
 * @param client HTTPclient_t *  ptr to the client struct
 * @return true = connected
    if(!client->tcp)
        return false;
    if(client->tcp->connected())
        if(client->status != HTTP_NOT_CONNECTED)
            return true;
        // client lost
            DEBUG_HTTP("[HTTP-Server] client connection lost.\n");
            // do cleanup
            clientDisconnect(client);
    if(client->tcp)
        // do cleanup
        DEBUG_HTTP("[HTTP-Server] client list cleanup.\n");
    return false;
 * Discard a native client
 * @param client HTTPclient_t *  ptr to the client struct contaning the native client "->tcp"
    if(!client)
        return;
    if(client->tcp)
#if (HTTP_NETWORK_TYPE != NETWORK_ESP32) && (HTTP_NETWORK_TYPE != NETWORK_RP2040)
            client->tcp->flush();
#endif
            client->tcp->stop();
#if(HTTP_NETWORK_TYPE == NETWORK_WIFI_NINA) || (HTTP_NETWORK_TYPE == NETWORK_SAMD_SEED)
        // does not support delete (no destructor)
#else
        delete client->tcp;
#endif
        client->tcp = NULL;
 * Disconnect an client
    client->status = HTTP_NOT_CONNECTED;
    DEBUG_HTTP("[HTTP-Server] client disconnected.\n");
 * disconnect all clients
httpHeader.cpp:
#include "httpHeader.hpp"
#include <vector>
const String requestMethodString[]
    "INVALID",  // Internally used value
    "OPTIONS",
    "GET",
    "HEAD",
    "POST",
    "PUT",
    "DELETE",
    "TRACE",
    "CONNECT"
const String responseString[]
    "100 CONTINUE" ,
    "101 SWITCHING PROTOCOLS ",
    "102 PROCESSING ",
    "200 OK" ,
    "201 CREATED ",
    "202 ACCEPTED ",
    "203 UNOFFICIAL INFO ",
    "204 NO CONTENT ",
    "205 RESET CONTENT ",
    "206 PARTIAL CONTENT ",
    "207 MULTI STATUS ",
    "300 MULTIPLE CHOICES " ,
    "301 MOVED PERMANENTLY ",
    "302 FOUND ",
    "303 SEE OTHER ",
    "304 NOT MODIFIED ",
    "305 USE PROXY ",
    "306 TEMPORARY REDIRECT ",
    "307 PERMANENT REDIRECT ",
    "400 BAD REQUEST " ,
    "401 UNAUTHORIZED " ,
    "402 PAYMENT REQUIRED " ,
    "403 FORBIDDEN " ,
    "404 NOT FOUND " ,
    "405 METHOD NOT ALLOWED " ,
    "406 NOT ACCEPTABLE ",
    "407 PROXY AUTH REQUIRED ",
    "408 REQUEST TIMEOUT ",
    "409 CONFLICT ",
    "410 GONE ",
    "411 LENGHT REQUIRED ",
    "412 PRECONDITION FAILED ",
    "413 ENTITY TOO LARGE ",
    "414 URI TOO LONG ",
    "415 UNSUPPORTED MEDIA TYPE ",
    "416 REQUESTED RANGE NOT SATISFIABLE ",
    "417 EXPECTATION FAILED ",
    "418 I AM A TEAPOT ",
    "420 ENHACE YOUR CALM" ,
    "422 UNPROCESSABLE ENTITY" ,
    "426 UPGRADE REQUIRED" ,
    "429 RETRY WITH" ,
    "451 UNAVAILABLE FOR LEGAL REASONS"
http::Request_t::operator String() const
    return requestMethodString[ (uint8_t) requestId ];
http::Request_t::operator Request() const
    return requestId;
http::Request http::Request_t::operator = ( const Request & newRequest )
    requestId = newRequest;
    return * this;
http::Response_t::operator String() const
    return responseString[ ( uint8_t ) responseId ];
http::Response_t::operator Response() const
    return responseId;
 * Main serialization function for HTTP header classes
 * Here is where much of the job is done
 * @param fieldN        numeber of fields available in the HTTP header
 * @param fieldArray    pointer to the fieldArray member of the HTTP header object
String headerToString( std::vector<http::Field> & vec )
    // String that holds the serialized header
    String header;
    /* NOTE:
    * pragma is a special field that is used to store all the actual pragma paramaters
    * It is known to be the first element of fieldArray
    * This reference is made for convenience
    * As it needs to be processed in a different way than other fields,
    * all loops that iterate over fields start at index 1 to not touch it
    const http::Field pragma = vec[0];
    // Local function that serializes the header field at index n of fieldArray
    auto serializeField = [ & ]( const uint8_t n )
        const http::Field field = vec[n];
        return field.value.length() > 0 ? field.tag + " " + field.value + "\n" : "";
    // Begin header serialization
    /* NOTE:
    * The first row serialization method changes if this
    * is for a response or a request, so delegate this
    * to the proper function overloads.
    * Instead, the other fields will be serialized here
    * NOTE2:
    * The serializeField function is used only in the following loop
    * but in this way the whole thing is more expressive
    for( auto n = 1; n < vec.size(); ++ n )
        header += serializeField(n);
    // Serialize and append pragma parameters to the header
        uint8_t subStrCount = 0;
        uint8_t newStrCount = 0;
        /* NOTE: ( pragma field structure )
        * The pragma field value is a concatenation of the values of
        * all the actual pragma fields, each terminated with a \n
        // Count the \n terminated substrings and create an array that can hold them
        for( auto ptr = pragma.value.begin(); ptr < pragma.value.end(); ++ptr )
            if( * ptr == '\n' ) ++subStrCount;
        String pragmaArray[ subStrCount ];
        // Extract the individual pragma field values
            pragmaArray[ newStrCount ] += *ptr;
            if( *ptr == '\n' ) ++newStrCount;
        // Once extraction is complete, serialize them all
        for( newStrCount = 0; newStrCount < subStrCount; ++newStrCount )
            header += pragma.tag + pragmaArray[ newStrCount ];
    // Field serialization complete
    // Append header termination sequence
    header += "\r\n";
    return header;
/// Serialization method for HTTP response header classes
http::ResponseHeader::operator String() const
    std::vector<Field> fieldVector = getFieldVector();
    String partialHeader = headerToString( fieldVector );
    String response = "HTTP/" + version + " " + ( String ) responseCode + "\n";
    return response + partialHeader;
/// Serialization method for HTTP request header classes
http::RequestHeader::operator String() const
    String request = ( String ) requestMethod + " " + requestTarget + " " + version + "\n";
    return request + partialHeader;
#if 0
http::ResponseHeader & http::ResponseHeader::operator = ( const ResponseHeader & other )
    for( auto n = 0; n < fieldN; ++ n )
        //// fieldArray[ n ]->value = other.fieldArray[ n ]->value;
        if ("" == other.fieldArray[ n ]->value)
            return * NULL;
    return * this;
http::RequestHeader & http::RequestHeader::operator = ( const RequestHeader & other )
    return * this;
#endif
httpHeader.hpp:
 * @file
 * @brief Header file containing HTTP header related structures and functions
#pragma once
#include <Arduino.h>
namespace http
    enum class Request;
    enum class Response;
    class Request_t;
    class Response_t;
    struct Field;
    struct ResponseHeader;
    struct RequestHeader;
 * Enum class representing a HTTP request method
 * It is intended to be used only as an assignment parameter for http::Request_t
enum class http::Request
    INVALID = 0, // Internally used value
    OPTIONS,
    GET,
    HEAD,
    POST,
    PUT,
    DELETE,
    TRACE,
    CONNECT
 * Enum class representing a HTTP response code
enum class http::Response
        // Informational
        CONTINUE = 0 ,
        SWITCHING_PROTOCOLS ,
        PROCESSING ,
        // Successful
        OK ,
        CREATED ,
        ACCEPTED ,
        UNOFFICIAL_INFO ,
        NO_CONTENT ,
        RESET_CONTENT ,
        PARTIAL_CONTENT ,
        MULTI_STATUS ,
        // Redirection
        MULTIPLE_CHOICES ,
        MOVED_PERMANENTLY ,
        FOUND ,
        SEE_OTHER ,
        NOT_MODIFIED ,
        USE_PROXY ,
        TEMPORARY_REDIRECT ,
        PERMANENT_REDIRECT ,
        // Client error
        BAD_REQUEST ,
        UNAUTHORIZED ,
        PAYMENT_REQUIRED ,
        FORBIDDEN ,
        NOT_FOUND ,
        METHOD_NOT_ALLOWED ,
        NOT_ACCEPTABLE ,
        PROXY_AUTH_REQUIRED ,
        REQUEST_TIMEOUT ,
        CONFLICT ,
        GONE ,
        LENGHT_REQUIRED ,
        PRECONDITION_FAILED ,
        ENTITY_TOO_LARGE ,
        URI_TOO_LONG ,
        UNSUPPORTED_MEDIA_TYPE ,
        REQUESTED_RANGE_NOT_SATISFIABLE ,
        EXPECTATION_FAILED ,
        I_AM_A_TEAPOT ,
        // Server Error
        ENHACE_YOUR_CALM ,
        UNPROCESSABLE_ENTITY ,
        UPGRADE_REQUIRED ,
        RETRY_WITH ,
        UNAVAILABLE_FOR_LEGAL_REASONS
 * Wrapper class for http::Request
 * it provides a strong type for representing a HTTP request method
 * in addition to conversion operators to String and to enum type
class http::Request_t
    public:
        Request_t( const Request & request ) : requestId( request ) {};
        operator String() const;
        operator Request() const;
        Request operator = ( const Request & );
    private:
        Request requestId = Request::INVALID;
 * Wrapper class for http::Response
 * it provides a strong type for representing a HTTP response code
class http::Response_t
    public:
        Response_t( const Response & response ) : responseId( response ) {};
        Response_t operator = ( const Response & newResponse )
            responseId = newResponse;
            return * this;
        operator Response() const;
    private:
        Response responseId;
 * A http header field
 * This struct is intended to use only in http header classes
 * The tag can only be defined at the time of the instantiation,
 * while the value can be assigned at any time by the assignment operator
struct http::Field
    explicit Field( const String & tag_ ) : tag( tag_ ) {}
    Field( const String & tag_, const String & value_ ) : tag( tag_ ), value( value_ ) {}
    Field operator = ( const String & newValue )
        value = newValue;
        return * this;
    const String tag;
    String value;
 * A struct representing a HTTP response header
 * It can be serialized by conversion to String
struct http::ResponseHeader
    ResponseHeader & operator = ( const ResponseHeader & );
    String version;
    Response_t responseCode = Response::OK;
    Field pragma                { "Pragma:"             };
    // Control data fields
    Field age                   { "Age:"                };
    Field cacheControl          { "Cache-Control:"      };
    Field expires               { "Expires:"            };
    Field date                  { "Date:"               };
    Field location              { "Location:"           };
    Field retryAfter            { "Retry-After:"        };
    Field vary                  { "Vary:"               };
    Field warning               { "Warning:"            };
    // Validator fields
    Field ETag                  { "ETag:"               };
    Field lastModified          { "Last-Modified:"      };
    // Authentication Challenges fields
    Field WWWAuthenticate       { "WWW-Authenticate:"   };
    Field proxyAuthenticate     { "Proxy-Authenticate:" };
    // Response Context fields
    Field acceptRanges          { "Accept-Ranges:"      };
    Field allow                 { "Allow:"              };
    Field server                { "Server:"             };
    Field connection            { "Connection:"         };
    Field encoding              { "Content-Encoding:"   };
    Field type                  { "Content-Type:"       };
    Field length                { "Content-length:"     };
    std::vector<Field> getFieldVector() const
        std::vector<Field> fieldVector = {pragma, age, cacheControl, expires, date, location, retryAfter,
                                          vary, warning, ETag, lastModified, WWWAuthenticate, proxyAuthenticate,
                                          acceptRanges, allow, server, connection, encoding, type, length};
        return fieldVector;
 * A struct representing a HTTP request header
struct http::RequestHeader
    RequestHeader & operator = ( const RequestHeader & );
    Request_t requestMethod = Request::INVALID;
    String requestTarget;
    String version;
    // Control fields
    Field expect                { "Expect:" };
    Field host                  { "Host:" };
    Field maxForwards           { "Max-Forwards:" };
    Field range                 { "Range:" };
    Field textEncodings         { "TE:" };
    // Conditional fields
    Field ifMatch               { "If-Match:" };
    Field ifNoneMatch           { "If-None-Match:" };
    Field ifModifiedSince       { "If-Modified-Since:" };
    Field ifUnmodifiedSince     { "If-Unmodified-Since:" };
    Field ifRange               { "If-Range:" };
    // Content negotiation fields
    Field acceptedTypes         { "Accept:" };
    Field acceptedCharset       { "Accept-Charset:" };
    Field acceptedEncoding      { "Accept-Encoding:" };
    Field acceptedLanguage      { "Accept-Language:" };
    // Authentication credentials fields
    Field authorization         { "Authorization:" };
    Field proxyAuth             { "Proxy-Authorization:" };
    // Context request fields
    Field from                  { "From:" };
    Field referrer              { "Referer:" };
    Field userAgent             { "User-Agent:" };
        std::vector<Field> fieldVector = {pragma, connection, cacheControl, expect, host, maxForwards, range,
                                          textEncodings, ifMatch, ifNoneMatch, ifModifiedSince, ifUnmodifiedSince,
                                          ifRange, acceptedTypes, acceptedCharset, acceptedEncoding, acceptedLanguage,
                                          authorization, proxyAuth, from, referrer, userAgent};
        return fieldVector;
httpMessage.hpp:
 * @file
 * @brief Header file containing HTTP message related structures and functions
#pragma once
namespace http
    struct RequestMessage;
    struct ResponseMessage;
/// Struct representing a whole HTTP request message
struct http::RequestMessage
    RequestHeader header;
    String payload;
    bool parsingFailed = false;
/// Struct representing a whole HTTP response message
struct http::ResponseMessage
    ResponseMessage(const ResponseHeader & header_ ,
                    const String & payload_ = "" ,
                    const bool & parsingFailed_ = false,
                    const bool & skipWrite_ = false) : header( header_ ), payload( payload_ ), parsingFailed( parsingFailed_ ), skipWrite( skipWrite_ )
    ResponseHeader header;
    String payload;
    bool parsingFailed;
    bool skipWrite;
        return ( String ) header + payload + "\n";
httpRequestHandler.hpp:
 * @file
 * @brief Header file containing default HTTP request handlers
#pragma once
#include "httpMessage.hpp"
 * Helper macro that simplifies the creation of a request handler
 * @param name The name of the handler with eventual namespace scoping
#define IMPLEMENT_HTTP_REQUEST_HANDLER(name) \
    void name ( \
            const http::RequestMessage & requestMessage , \
            http::ResponseMessage & responseMessage , \
            WiFiClient & client \
namespace http
    namespace requestHandler
        IMPLEMENT_HTTP_REQUEST_HANDLER( returnDefaultHeader );  ///< Default HEAD handler
        IMPLEMENT_HTTP_REQUEST_HANDLER( returnTestPage      );  ///< Default GET  handler
// ACTUAL IMPLEMENTATION BELOW
IMPLEMENT_HTTP_REQUEST_HANDLER( http::requestHandler::returnDefaultHeader )
    // Do nothing, as the default response message already has
    // the default header and empty payload
IMPLEMENT_HTTP_REQUEST_HANDLER( http::requestHandler::returnTestPage )
    const auto & target = requestMessage.header.requestTarget;
    responseMessage.payload =
        " Hello from Arduino ! \n"
        "\n"
        " The request target was " + target + "\n"
        "\n"
        " This test page is offered by the returnTestPage Handler\n"
        " part of the Arduino_HTTP/1.1 library by qub1750ul\n"
        "\n"
        " https://github.com/qub1750ul/Arduino_HTTP\n\n";
httpServer.hpp:
 * @file
 * @brief Header file containing the HTTP Server class and the HTTP parser
#pragma once
#include "httpRequestHandler.hpp"
namespace http
    class Server;
    RequestMessage parseRawMessageFrom( WiFiClient );
/// The HTTP Server Class, managing the requests from remote clients
class http::Server
    public:
        Server();
        void replyTo( WiFiClient );
        ResponseHeader defaultResponseHeader;
        // Callback functions for HTTP requests
        #define DECLARE_REQUEST_HANDLER_PTR(name) \
        IMPLEMENT_HTTP_REQUEST_HANDLER( ( * name ) ) = nullptr
        DECLARE_REQUEST_HANDLER_PTR( OPTIONS_requestHandler );
        DECLARE_REQUEST_HANDLER_PTR( GET_requestHandler     );
        DECLARE_REQUEST_HANDLER_PTR( HEAD_requestHandler    );
        DECLARE_REQUEST_HANDLER_PTR( POST_requestHandler    );
        DECLARE_REQUEST_HANDLER_PTR( PUT_requestHandler     );
        DECLARE_REQUEST_HANDLER_PTR( DELETE_requestHandler  );
        DECLARE_REQUEST_HANDLER_PTR( TRACE_requestHandler   );
        DECLARE_REQUEST_HANDLER_PTR( CONNECT_requestHandler );
        #undef DECLARE_REQUEST_HANDLER_PTR
// * IMPLEMENTATION *
http::Server::Server()
    // Set default header
    defaultResponseHeader.version       = "1.1";
    defaultResponseHeader.connection    = "close";
    defaultResponseHeader.server        = "Arduino_HTTP/1.0.0 Arduino";
    // Set default request handlers
    GET_requestHandler  = requestHandler::returnTestPage;
    HEAD_requestHandler = requestHandler::returnDefaultHeader;
 * Method used to reply to remote client requests
 * The request type and the appropriate handler are automatically deduced from
 * the request header
 * @param Client_t    The class representing the socket of the transport layer
 * @param client        A RemoteClient object representing the remote client
void http::Server::replyTo( WiFiClient client )
    if( ! client.available() ) return;
    RequestMessage inboundMessage = parseRawMessageFrom( client );
    ResponseMessage responseMessage( defaultResponseHeader );
    if( inboundMessage.parsingFailed )
        responseMessage.header.responseCode = Response::BAD_REQUEST;
        const Request & requestMethod = inboundMessage.header.requestMethod;
        // Select the appropriate function to handle the request
        auto requestHandler =
        requestMethod == Request::OPTIONS   ? OPTIONS_requestHandler    :
        requestMethod == Request::GET       ? GET_requestHandler        :
        requestMethod == Request::HEAD      ? HEAD_requestHandler       :
        requestMethod == Request::POST      ? POST_requestHandler       :
        requestMethod == Request::PUT       ? PUT_requestHandler        :
        requestMethod == Request::DELETE    ? DELETE_requestHandler     :
        requestMethod == Request::TRACE     ? TRACE_requestHandler      :
        requestMethod == Request::CONNECT   ? CONNECT_requestHandler    : nullptr;
        if( requestHandler == nullptr )
            requestHandler( inboundMessage, responseMessage, client );
    if (responseMessage.skipWrite)
        // Reset the value
        responseMessage.skipWrite = false;
        client.write( String(responseMessage).c_str() );
    client.stop();
 * The parsing function used to deserialize incoming HTTP messages
http::RequestMessage http::parseRawMessageFrom( WiFiClient client )
    RequestMessage requestMessage;
    // Manually read the first byte to let getNextWord and accessNextField
    // work as expected
    char charBuffer = client.read();
    auto getNextWord = [ & ]() -> String
        String word;
        // Read from the buffer until a word-terminating char or field end is encoutered
        while( charBuffer != ' ' && charBuffer != '\n' )
            word += charBuffer;
        // This is necessary to not get stuck on next call
        if( charBuffer == ' ' )
        return word;
    auto accessNextField = [ & ]() -> void
        // Discard all chars until the next field
        while( charBuffer != '\n' )
        // Begin reading the new field, so getNextWord doesn't get stuck
    // Parse first line
    // Parse request method
        String requestMethod = getNextWord();
        #define ifMatchesThenAssign(x) requestMethod == ( Request_t ) x ? x
        requestMessage.header.requestMethod =
        ifMatchesThenAssign( Request::CONNECT   ) :
        ifMatchesThenAssign( Request::DELETE    ) :
        ifMatchesThenAssign( Request::GET       ) :
        ifMatchesThenAssign( Request::HEAD      ) :
        ifMatchesThenAssign( Request::OPTIONS   ) :
        ifMatchesThenAssign( Request::POST      ) :
        ifMatchesThenAssign( Request::PUT       ) :
        ifMatchesThenAssign( Request::TRACE     ) : Request::INVALID;
        #undef ifMatchesThenAssign
    requestMessage.header.requestTarget = getNextWord();
    requestMessage.header.version       = getNextWord();
    if ( requestMessage.header.requestMethod == Request::INVALID ||
         requestMessage.header.requestTarget == "" )
        requestMessage.parsingFailed = true;
        return requestMessage;
    // Parse header fields until the header-payload separator or end-of-message is encoutered
    while( charBuffer != '\r' && client.available() )
        accessNextField();
        // Get the field name
        const String parsedTag = getNextWord();
        /* As HTTP/1.1 specification states, if a field starts with a space ignore it
        * IMPLEMENTATION NOTE:
        * Since getNextWord() stops extracting the word on every whitespace
        * if the field begins with a whitespace the first word extracted
        * for that field will be empty
        if( parsedTag == "" ) continue;
        std::vector<Field> fieldVector = requestMessage.header.getFieldVector();
        // Go through all the header fields to find one with a matching name
        // if no one is found the current field is ignored
        for( uint8_t n = 0; n < fieldVector.size(); ++ n )
            Field & field = fieldVector[n];
            if( field.tag != parsedTag ) continue;
            // Read the field value, appending eventual spaces discarded by getNextWord()
            for( String parsedValue = getNextWord(); parsedValue != ""; parsedValue = getNextWord() )
                field.value += parsedValue + ( charBuffer == ' ' ? " " : "" );
    // Read the payload
    accessNextField();
    /* IMPLEMENTATION NOTE :
    * This method allows to correctly read the payload even when using
    * keep-alive connections
        const String nextWord = getNextWord();
        if( nextWord == "" ) accessNextField();
        else requestMessage.payload += nextWord + ( charBuffer == ' ' ? " " : "" );
